» Sponsors
» Sponsors
Go Back   Toyota Forums :: Toyota Nation > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Gen 5 & 6
Register Home Forum Active Topics eBay Marketplace Photo Gallery Blogs Mark Forums Read
Gen 5 & 6 Toyota Camry Discussion for years: 2002-2006 & 2007+ Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
Please Visit our Site Sponsors
Thread Tools Display Modes
Old 04-26-2008, 03:54 AM   #1
outgoingbot3
Trader Rating: (0)
View outgoingbot3's Photo Gallery
Compiled Working Instructions for 5.1, 6.1 and 7.1 OVERRIDE Camry 2007, 2008, 2009
Works my 2009 Camry SE with 7.1 DISK
Read Instructions Below. (thanks durham2atl and pillpusher84 and others)
This will allow you use all of the touchscreen function even while in motion. This makes using the GPS and selecting audio files from MP3 Cds much easier.
Requirements:
Hardware:
A moderately powerful computer running windows XP or Vista
16 Gygabytes of free Harddrive space (7.5 gigs for the folder, 7.5 gigs for the ISO file)
Memorex DVD+R DL (DOUBLE LAYER/DUAL LAYER) other may work.
Double Layer DVD Burner ( I use an LG burner Any should work)
Software:
Imgburn – will be used to make the ISO and burn the ISO(freeware, download link below)
http://www.imgburn.com/index.php?act=download
Files:
Original 5.1, 6.1 or 7.1 Stock Navigation DVD
Downloaded 5.1 LOADING.KWI file (download link below)(thanks pillpusher84)
http://rapidshare.com/files/13127620...g.kwi.zip.html
Tools:
Ratchet Set or Crescent Wrench or Pliers
Creating the hybrid DVD,
1. Create a folder on you Desktop named camry_dvd
2. Put the Original Navigation 5.1, 6.1 or 7.1 DVD into the DVD Burner (yes, burner)
3.Open My computer, then double click on the DVD Drive that has the Original Disk in it.
4. in the main/root folder of the original dvd goto Edit and select “select all” then in the same menu press copy.
5. Open the Folder on the Desktop called camry_dvd
6. Goto Edit and select paste (this will take a while, 10-40 mins, maybe more)
7.Once completed, delete the file in the camry_dvd folder named LOADING.KWI
8. Navigate to where the 5.1 LOADING.KWI file was downloaded.
9. Right click on the LOADING.KWI file and select Copy.
10. Open the camry_dvd folder and goto Edit and select Paste
Next we build the ISO using ImgBurn 2.4.1.0 (ISO = disk image file),
1. Open ImgBurn after it is installed.
2. From Mode menu, select Build.
3. In the Source panel, click the Browse for a Folder icon. Right side, graphic button looks like a folder and a magnifying glass. A Browse for Folder dialog box appears.
4. Navigate to the desktop, click once on the folder named camry_dvd, then Click OK.
5. In the Destination panel, click the Browse for a file icon. The Save As dialog box appears. Click the Desktop button then enter camry_iso for the name.
6. Click Save.
7. We are about to create an 8 Gig file, make sure to have room. Close all programs that aren’t needed. This could take an hour. Once we start don’t touch your computer even if it looks crashed. Just wait.
8. Click the Icon below the destination field that looks like a “folder, arrow, and DVD on paper”
9. If you get a popup about root folder Choose YES
10. If you get a second popup about the dvd name Choose YES
11. If you get a third popup about files Choose OK
12. Once finished you will have an file named camry_iso.ISO and another name camry_iso.MDS.
Next, We will burn the ISO to a Memorex DVD+R DL DVD,
1. From ImgBurn, select the Mode menu, and then select Write.
2. In the Source panel, click the Browse for a File icon. A Browse for File dialog box appears.
3. Navigate to the Desktop, Click on camry_iso.MDS
4. Click Open.
5. Don’t change any settings
6. Put your Memorex DVD+R DL DVD into your burner
7. Click the Write icon. (looks like a “folder, arrow, and DVD on)
Congratulations –
you should have your hybrid DVD.
Finally, we install the firmware,
1.Put the key in the car and turn to ON (we never start the engine for the entire Install)
2.Eject the Map DVD if any.
3.Insert the Newly burned Memorex DVD+R DL DVD
4.Close the Navigation Screen back to its normal position
5.Roll Down the Driver side window
6.take the key out of the ignition, then slide it back into the ignition BUT DO NOT TURN IT!
7.Pop the hood of the car.
8.Disconnect the Negative/Black Battery Terminal. DO NOT TOUCH THE POSITIVE/RED TERMINAL!
9.Wait 5 Minutes
10.Reconnect the Negative Battery Terminal.
11.Close the Hood
12.Get in the Car and turn the Key To ON.
13.DO NOT TURN OFF THE CAR!
14.Wait 5 minutes the screen may say “no dvd found” but give it time.
15.It will load up the GPS map if all was done correctly.
The Code,
To enable the over ride you must, EVERY TIME THE CAR IS STARTED, enter a “code”
  • Press the hard ‘MENU’ button on the left side of the Nav screen.
  • Press the volume Icon
  • Here is where we enter the “code” by pressing on the left 2 corners of the screen.
  • Upper left corner, lower left corner, upper left corner, lower left corner,
  • You are now in the Service Menu
  • Here press and hold the ‘override’ button until it beeps.
  • press upper right hand corner to exit
  • ALL DONE! Don’t fuking crash
Trouble Shooting:
If you play with too many settings in the Service Menu then you will probably crash your navigation system. If it used to work, but then after trying to exit, reset then locked up. You are OK. Just turn off the car. Turn it back on. Press the eject hard button. Then press the DVD Map eject button. The screen will slide open. If the dvd doesn’t come out. Press the eject icon on the screen again, even though the screen is open and hard to see.
Also, If you have a hybrid Camry I guess you dont have a battery under the hood. If this is the case then you need to remove the power fuse that is connected to the head unit for 5 minutes. Then put it back in. do everything the same except the part where you disconnect the battery, wait, then reconnect it.
Video of Entering Code: http://www.youtube.com/watch?v=BiYekr8vJqY
outgoingbot3 is offline   Reply With Quote
Old 04-26-2008, 04:37 AM   #2
xfyre
kooler than da kool-aid
xfyre's Avatar
Trader Rating: (0)
View xfyre's Photo Gallery
wow...looks like you put in a lot of work for this...
good work!
xfyre is offline   Reply With Quote
Old 04-26-2008, 12:28 PM   #3
dcemureviews
Engaged - 03.22.09
dcemureviews's Avatar
Trader Rating: (11)
View dcemureviews's Photo Gallery
Sounds like this but more detailed - http://www.toyotanation.com/forum/sh...57&postcount=9
However the installing of firmware part with removing the terminals is optional but a definite fix. But from the link I just posted, it never mentioned about the code having to be entered everytime the car is started.
CarDomain - CCFL Cathode Trunk Light Toyota Honda Acura Lexus
Cathode Light Kit - FOR SALE
dcemureviews is offline   Reply With Quote
Old 04-26-2008, 01:57 PM   #4
outgoingbot3
Trader Rating: (0)
USA
All it is is a more detailed version. step by step. 100% confirmed to work with 2009 camry with 7.1 disk. just trying to do my part.
few images:
the I Agree nag Screen
press the 'Menu' hard button to get to this screen
Press the volume icon to get to this screen
enter "code" to get to this screen
notice the ROM is 5532 and the disk is 7.05.10. this means the ROM/Firmware is 5.x and the MAP Data is 7.x
disk info
load/eject screen
one of a few different error screen
I will be trying to improve this hack.
I will try to remove the 'I Agree' nag Screen
I will try to make 'OVERRIDE' enable by default
I will try to Personalise the software so it is cooler.
I will attempt this by modifying the LOADING.KWI file. If I am sucessful I will post it here. check back soon.
Old 04-26-2008, 02:36 PM   #5
dcemureviews
Engaged - 03.22.09
Trader Rating: (11)
I'm not complaining. Just informing those that this is a more detailed version and with pictures. I appreciate it as I will be needing this when I get mine. Hopefully the 2010 version will not have a modified nav system.
Keep us posted on the override default and personalizing it.
I dont remember reading this on the other thread but than again, I could be wrong since there is so many posts. Can those who have already done this confirm that you have to do this override everytime you start up the car. It is annoying if you have to do this all the time.
Old 04-27-2008, 02:34 AM   #6
SiKKNiKK
SiKKNiKK's Avatar
Trader Rating: (0)
View SiKKNiKK's Photo Gallery
Wow~~~ Great Work!!!
I'd love to see the navi screen with cooler interface!!!
Keep up the good work~~~~!!!!
2007 CAMRY XLE BLACK with NAVI.
SiKKNiKK is offline   Reply With Quote
Old 06-22-2008, 02:33 PM   #7
jbggreen
Trader Rating: (0)
View jbggreen's Photo Gallery
Smile 5.1 & 6.1 combined disk
I followed the instructions downloading the loading.kwi 5.1 file and then using my 6.1 disk with imgburn (free version) and my hp dvd writer (does double layer). I used memorex double layer +r disks from radio shack ($4.99 for a 3 pack) and the disk works perfectly. I just removed the radio fuse for a couple of minutes and it loaded fine. Tested it today - all works as it should. Hope it works also with the next upgrade for the map!
jbggreen is offline   Reply With Quote
Old 06-22-2008, 03:18 PM   #8
2k4CamThrilla
Bootyologist
Trader Rating: (1)
View 2k4CamThrilla's Photo Gallery
Is that the OEM factory headunit? Cuz i heard they made a newer headunit with more features that you can have installed.
www.myspace.com/djkraz
2009 Toyota Camry SE-(BLK LEATHER,NAVI,Debaged,Blue LED shifter mod,20% Tint)
2004 Toyota Camry LE(SOLD)
1989 Ford Tempo AWD(SOLD)
2k4CamThrilla is offline   Reply With Quote
Old 07-21-2008, 02:19 AM   #9
outgoingbot3
Trader Rating: (0)
reposted the 5.1 loading.kwi download link in 1st post
Old 07-21-2008, 05:58 AM   #10
2k4CamThrilla
Bootyologist
Trader Rating: (1)
I think for the 09's or atleast the headunit i have can be updated by uploading the data onto the SD thats provided. Correct me if I'm wrong
Old 07-26-2008, 11:50 PM   #11
outgoingbot3
Trader Rating: (0)
what is the SD? im not sure what ur post is saying. i am interested.
Old 07-27-2008, 12:35 AM   #12
dcemureviews
Engaged - 03.22.09
Trader Rating: (11)
SD - Secure Digital card.
Old 07-27-2008, 01:43 AM   #13
jcotero
jcotero's Avatar
Trader Rating: (0)
View jcotero's Photo Gallery
I was able to make the hybrid disc but it seems the nav works slow and sometimes will just freeze up until I turn the car off and back on. I also have noticed that this usually happens when the region for the map is not selected. Instead of showing a map with the region seleceted it just empty no map or anything. Any body else having trouble like this
2008 SE V6
Debaged, LED lights, K&N Intake, Tint
Megan Coilovers by summer 2010!!!
jcotero is offline   Reply With Quote
Old 07-27-2008, 04:21 PM   #14
dcemureviews
Engaged - 03.22.09
Trader Rating: (11)
Originally Posted by outolunch View Post
Available for those who dont want to waste a lot of disks and want it to work right with the new 8.0 map data for $75.00 at cruisin@live.com
Thank you for spamming and ripping us off.
Old 07-27-2008, 09:33 PM   #15
dcemureviews
Engaged - 03.22.09
Trader Rating: (11)
You sound like a LOW life scum bag.
Whos the one charging $75? Not me. So yea, whos the low life scum bag?
Of your 29 or so posts, 99% of it is all spam and advertising.
vB code is On
Forum Jump
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
