So it has finally come time for the 4A-GE to go in after my misfortune that happened on tuesday, my 3E developing a very loud rod knock, but luckly i made it home from Kitchener, I started some work today taking it apart but im still waiting to hear back from a buddy for this engine lif, so here is where it ends for today
so now that the 3E is pooped it gives me an excuse to throw this engine in sooner than expected, just need to buy some more parts, but for the most part the engine is complete,
The 3E
And the old/new engine for this car, bought the whole setup for 250$ from s1495 about a year ago
Engine is 91 Corolla GTS, the Hi-comp version of the 4A-GE, im looking forward to getting more work done very soon,
Good swap choice. Keep in mind the 91 came with the small port head so a later mod might be a head swap. Won't you have to notch the passenger side frame rail?
Yep i was thinking of going that route if i were to go turbo, i have a bigport bluetop sitting under the bench if i ever do decide to go that way,
Yes i was thinking of cutting the drivers rail but i want to keep the Tercel axles because i heard that custom axles are a bit pricey, so im gunna drill and tap some holes in the C52 and use the Tercel axles and cut the passenger frame rail, id like to get the engine mounted this week, then my buddy whos a Toyota Tech is gunna help me out with the wiring:clap:
yeah the axles will fit the way i plan to do it, so i wont have to worry about them, im just gunna run N/A for a little while, im gunna get some GZE pistons for it when i rebuild the engine, but for now im just running how it is, im also curious what a stock 4ag in a Tercel would do in a 1/4 mile
The Corolla transmission bolts up to the stock Tercel mounts in most cases however the engine is slightly longer so a little clearance is needed on the passenger side. You wouldn't want to relocate the transmission because that would call for custom axles.
By the way, look at Paseo axles when you stop by a parts store. I've heard they are slightly beefier than Tercel axles but fit in place.
looks like a dirty project haha !! Nice to see your project moven along tho !! LMK if you need GT-S axles, ive been wanting mine to go to a good home, ever since i pulled umm.. LMK if you need anything else !! lol an is that my thingamajig on there ?
Haha your thinganijig is on my GZE in the AE86, ill post pics laterz, today im gunna try getting the holes drilled in the trans to fit the trans on the stock tercel mounts
Did some quick work before the sun went down, I drilled out the holes and tapped them in the C52 and fitted the Tercel mount, also i chopped half the crank harmonic with a hack saw to gain some more clearance before i cut the frame, hope fully tomorrow or friday the engine will be at home in the bay
These photos are for the noobs, so they know where to drill and tap holes to make the transmission bolt-in
Shes comin along nicely now, after i get paid i need to buy some stuff for it and replace a bunch of seals, because i aint having another engine that leaks oil,
i cant see the pics cause my work blocks everything and anything, but i just wanted to say, best of luck..
and yes the paseo axes and cvs are larger than the tercels
last thing, when positioning in the bay, allow room for motor movement as when those mounts wear out a little, you will get quite a bit of movement when the motor revs up cause of torquing..
good to know, im going to molest the firewall with a hammer when i drop the engine back out to replace all the seals, i just dropped 4 bills on OEM seals, gaskets, dizzy cap, rotor and an oil pan, and a 20v header that i have to mod to fit, what happened to the swap thread on tercelonline? or is it still there?
Paseo axles will be a later upgrade, but for now i need my daily driver back
for me the trans was just fine, but for other prople maybe not lol, i dont mind some cluinking going into gears, the car was doing it all 50000klms i drove it
Related Threads
Ask a question
Ask a question
Toyota Nation Forum
6.2M posts
587K members
Since 2001
