» Sponsors
» Sponsors
Go Back   Toyota Forums :: Toyota Nation > Toyota Truck, SUV and Van Forums > Toyota Pick Up and Hilux Forum > 89-95 Toyota Pickup/Hilux
Register Home Forum Active Topics eBay Marketplace Photo Gallery Blogs Mark Forums Read
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Please Visit our Site Sponsors
Thread Tools Display Modes
Old 04-16-2009, 03:40 PM   #1
toyinhawaii
Trader Rating: (0)
View toyinhawaii's Photo Gallery
Hard To Steer..power Steering Pump Ques.
Hey All,
I gotta 93,3vze,4x4,auto excab, 160,000 miles...My problem is the steering is hard to steer,when i got the truck i noticed it leaking from the seal (on the power steering pump)..and the truck was hard to steer..unitil i could get to it i added power steering fluid...i finally changed the seal and for what ever reason made me do it...i just checked the manual for the fluids and sh#$...it takes dextron atf..well i flushed the system twice and added dextron atf...and still is hard to steer...also when i drained the system i found very fine shavings..not to much though ..jus a lil...i know on trannys this is normal...but on P.S. pumps????..also when the engine is cold and the rpms are about 1000..it steers fine, after warming up to normal its steers hard,,,is it time to repair the pump w/ the kit...replace it???... or can i adjust the steering box??..i dont think the box adjustment is nessesary..jus cause when it idles high its fine ...i think the pump is going????
thanks
toyinhawaii is offline   Reply With Quote
Old 04-16-2009, 03:53 PM   #2
V62WDLongbed
Trader Rating: (0)
View V62WDLongbed's Photo Gallery
Power steering fluid is essentially clear ATF without all the additives that aren't needed in a P/S system. I've used both and never had problems.
V62WDLongbed is offline   Reply With Quote
Old 04-16-2009, 04:53 PM   #3
fourwd1
out on bail
fourwd1's Avatar
Trader Rating: (0)
View fourwd1's Photo Gallery
Originally Posted by toyinhawaii View Post
...also when the engine is cold and the rpms are about 1000..it steers fine, after warming up to normal its steers hard...i dont think the box adjustment is nessesary..jus cause when it idles high its fine ...
thanks
So it works fine anytime except normal idle?
Just tech info
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, x-over steering, etc ...
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks, etc ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 04-16-2009, 05:34 PM   #4
toyinhawaii
Trader Rating: (0)
FOURWD1.....Yea...thats right..it seems like theres not enough pressure going through the system at a low rpm..like turning from a dead stop, pulling into a parking spot..when i do this, i have to give it a little gas and brake at the same time to turn more easy...so this makes me think somethings wrong internally...rotor,vane,seal damage etc....
Old 04-17-2009, 02:01 AM   #5
sb5walker
sb5walker's Avatar
Trader Rating: (0)
View sb5walker's Photo Gallery
When you replaced the seal, did you by any chance clean the filter screen in the bottom of the reservoir? That can get clogged with those metal shavings and bits of rubber, and the pump will cavitate and can't pump fluid. You really have to pull the reservoir off to clean it, and you'll need a new o-ring when you reinstall.
If the filter screen isn't clogged, you may be in the market for a reman pump. That would be a drag after you just replaced the seal in yours - hopefully a new one is not needed.
If you do need a reman pump, there's a big range of price/quality. Autozone sells 'em cheap; and cheap may well be what you get. Rock Auto sells a few - I would avoid the Cardone remans, as they don't have a great rep. The Beck/Arnley, on the other hand, is probably a premium rebuild. Most of the parts they sell for our trucks are made in Japan and are of excellent quality. Autohausaz sells a pump from a mfr I've not heard of ("Maval"), and more $$ than the B/A, but autohausaz typically only sells premium quality parts, so it's probably a safe bet.
You may want to consider putting a filter in the return line - I've used a magnetic one for a couple years and the steering has worked fine, though I haven't drained off any fluid to check the performance of the filter. I also use Mobil 1 Synthetic ATF and have had good luck with that, too.
The magnetic filter is sold under the "Magnefine" name, and Cardone sells the identical filter with their label. They are intended for use with either Power Steering or Automatic Transmissions. They have a bypass valve in case they get clogged, unlike the screen in the reservoir.
Normally about $30, you can get the Cardone from rockauto for $20 (I think our return lines are 3/8"). Magnefines are often sold on ebay for even less.
Here info on 'em:
http://www.emergingent.com/subpage1Magnefine.htm
Good luck, and let us know what you find.
89 4x4 X-Cab V6 5spd 281,000, Borla cat-back, K&N Filtercharger, 30x9.5 Bridgestone Dueler A/T Revo
sb5walker is offline   Reply With Quote
Old 04-20-2009, 05:48 PM   #6
toyinhawaii
Trader Rating: (0)
Sb5walker- Actually This Weekend What I Did Was,,,in Addition To Ur Sugsestion I Troubeshot It By Doing The Changeing Fluid Again Sr-41 Procedures ,in The Online Service Manual When I Drained The Fluid I Saw The Screen And Instead Of Takeing The Resivoir Off I Used The Wet/dry Vacum With A Rubber Tube Attached And Sucked All The Debri From The Screen...there Was Really None..jus A Bit..after I Did The Sr-41 Procedure The Steering Did Feel A Bit Better At Idle For A While But It Went Back To Being A Bit Difficult After A While...there Is Still A Couple More Procedures I Can Do Though..from The Manual...i'll Try Those...hopefully I Dont Need A Pump...but If I Do Then ..well... I Guess Its Gotta Be Done..thanks
Last edited by TrailDust : 07-13-2009 at 02:52 PM. Reason: Service manual link deleted.
vB code is On
Forum Jump
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
