FS: Parts for 98-02 Corolla and more, Toronto
15K views 23 replies 11 participants last post by  G_gazoo
Toronto area, all prices in C$.
All parts are for gen 8 (98-02) Corollas unless otherwise noted. Pics on request.
Relatively small parts can be shipped on your expense. Shipping within Canada or to US is minimum $20 estimated. I'll clean them to my best ability before delivery.
ONE 14x5.5" steelie, for any Toyotas with 4x100 bolt pattern - 88-02 Corolla, Tercel, Echo, Yaris... Needs new valve stem. $20
98-00 bumper, 3M5 sanddrift metallic, no damage beyond normal wear. Includes the styrofoam behind it. $300 PICK UP ONLY
98-00 headlights. Left is Toyota and complete, right is Depo and missing the rubber boot at back. Both includes bulb. $100 for left, $40 for right.
98-00 Toyota OEM back up lights that goes on the trunk. No damage, also fits 01-02 if you want a new look or are in a pinch. $80/pair
Two passenger assist "Oh shit" :D bars, gray complete w/ hardware $10 each * Fits Corollas and gen4 Camrys *
Tan color auto floor shifter with overdrive switch, shift lock ECU and bulb $100
Cable to connect above to tranny $50
Three gen 8 Corolla / gen 4 Camry door switches $10 each
Wiper stalk, intermittent, no variable, includes the screws C$10
Engine ECU for 98/99 Corolla with 4-speed auto $50
Engine ECU for 98/99 Corolla with 5-speed manual $50
Six Siemens relays, Toyota PN 90080-87010 $5 each
Instrument panel junction box (82732-02010, the fuse panel going behind coin holder) $50
Stop light switch, should work with any Toyota. Works. Includes the pins needed to make cruise control work $10
Interior light dimmer rheostat, two available, $5 each
Clockspring aka spiral cable $10, frame sold
* Fits gen 4 Camrys too *
Brown Integration Relay 82641-AB030 $50
This guy controls your car's "body functions" including seat belt reminder and power door locks, and is needed for PDL retrofit
Canadian-spec DRL main relay (brain) $50 Dealer wants hundreds of $ for this
Storage box, brown color, can be installed in a 7th gen too :D cup holder sold, box $15, brackets $5/pair
Tan interior door handle, PASSENGER SIDE, rear or w/o power door lock on door handle $10 each
Rear console box from 98 CE with lid, beige interior. $50
01-02 Fog light hole cover. I have both left and right. Block off that gaping hole! $10 each
STUFF FOR RETROFITTING 98-02 COROLLA FACTORY OPTIONS
Automatic headlight
Automatic headlight retrofit kit for Canadian 98-02 Corollas SOLD
Meant for Canadians, this kit replaces the DRL system in your car with the US version that turns headlight on automatically when dark.
Includes US-spec DRL main relay, light sensor, uncut wires and instructions produced by yours truly.
Cruise control retrofit
Cruise control actuator, pigtail and throttle cable attached, mounting bracket bent $60
Brake switch with cruise control contacts $10
Cruise control brain box $80
Cruise control stalk and bottom steering wheel shell, tan $15
Power door locks and power windows
Power window switch for rear doors, bone/tan interior C$10
Complete, unadulterated power window+power door lock wires for rear doors. $40 each obo
Power mirror
Power mirror switch $30
Yes. Updated. But in a few months if I don't get any bites nor me getting any snow tires... :lol: :facepalm:
will rear console box fit gen 7? this is the "armrest" correct?
That's the piece. As for fitment into 7th I'm curious too. The airbag brain is underneath where the console box is. This fitment is critical if one is to retrofit the entire 8th gen interior into a 7th.
bump
You have insufficient privileges to reply here.
