» Sponsors
» Sponsors
Go Back   Toyota Forums :: Toyota Nation > Toyota Truck, SUV and Van Forums > Toyota Pick Up and Hilux Forum > T-100
Register Home Forum Active Topics eBay Marketplace Photo Gallery TN Arcade Blogs Mark Forums Read
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Please Visit our Site Sponsors
Thread Tools Display Modes
Old 05-18-2004, 09:29 AM   #1
codylabrador
Trader Rating: (0)
View codylabrador's Photo Gallery
Question 95 T100 2WD Lift Question
I have a 1995 bottom-of-the-line T100 with the 4cyl and a 5 speed. It has been a great truck - stays parked most of the time but it will haul a hell of a load and go 75-80 MPH while still getting 22-24 MPG.
I put a set of SR5 alloys and tires on it. It looks pretty good but the front tires occassionally rub when I go over driveway curbs.
Can any of you recommend a front end lift kit that is not too expensive or involved? I would like to lift it 2-4 inches if possible.
Thanks.
codylabrador
1995 Camry LE Wagon, 1995 T-100, 2000 Lexus LS 400, 2009 Prius.
codylabrador is offline   Reply With Quote
Old 04-22-2005, 12:49 PM   #2
crain
Trader Rating: (0)
View crain's Photo Gallery
I just brought my second T100, a '96 2WD with 150K miles. I wish I never got rid of my '97 five years ago. If you want to maintain your factory ride, find a spindle lift kit or do a body. If all you want is to raise the front end 2", you can do it by cranking the torsion bars about 4 turns, but I would only recommend half that for 1" because if you crank the torison bars too much (2" or more), it will stiffen the ride and the stock torsion bars can't handle much more than 2" without need an after market A-Arm. On my '97, I attempted to raise my truck 3.5" with a beefed up aftermarket torision bar and much bigger control A-Arms from Fabtech and I hated it. I used an added a lift spring in the rear to raise it 1 1/2" to level the truck out. It looked like a 4X4 but the ride was a little harsh, not bad necessarily, but I really like the stock ride. With my '96 I just got, I turned the stock t-bars two full turns on each side to raise the truck about an inch. It's near level but still has a slight dip, but the factory ride is not affected. After lifting an F150 with ProComp's 3" spindle lift and 2" blocks in the rear, that's the only way I would do a full lift on any 2WD to keep the factory ride. I know several guys that want to raise the front only 2-3" to level their truck out will go with a Daystar front end spacer to is not supposed to affect the ride. I don't know if Daystar makes the spacer for our truck but you can check their website by doing a search for Daystar suspension products.
Good luck.
crain is offline   Reply With Quote
vB code is On
Forum Jump
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Page generated in 0.07642 seconds with 13 queries
