» Sponsors
» Sponsors
Go Back   Toyota Forums :: Toyota Nation > Toyota Truck, SUV and Van Forums > Toyota Pick Up and Hilux Forum > T-100
Register Home Forum Active Topics eBay Marketplace Photo Gallery TN Arcade Blogs Mark Forums Read
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Please Visit our Site Sponsors
Thread Tools Display Modes
Old 08-17-2005, 09:47 AM   #1
davet100
Trader Rating: (0)
View davet100's Photo Gallery
T100 MT Shifts Hard
Hi everyone;
Just purchased a clean 1995 T100 4WD 3.4 L Manual Transmission w/ 72,000 K mi. Its overdue for a timing belt so its going into the shop right away.
Problem is, it shifts hard. To get it in first gear almost always requires double clutching and 2nd...5th needs to be eased in. On the other hand the clutch feels good, no chatter, releases at mid travel, etc.
Does anyone have experience with this? Do I need a new clutch, or could it be an adjustment / fluid level problem? The dealer quoted me $300 for the timing belt and $1200-1500 for a clutch job. I'd like to postpone the clutch for a while if possible.
Dave P.
davet100 is offline   Reply With Quote
Old 08-17-2005, 06:57 PM   #2
reb
Trader Rating: (0)
View reb's Photo Gallery
From a Toyota manual:
1) check the clutch pedal freeplay.
2) bleed the hydraulic line. Might be air in it.
3) Master cylinder might be damaged
4) Release cylinder might be damaged
5) Input bearing worn or damaged
6) Bad clutch disc or diaphgram
You should be able to find a competent mechanic to replace the clutch, it that is what it needs, for less than that quote.
Good luck
reb is offline   Reply With Quote
Old 08-17-2005, 10:51 PM   #3
Sidney
Trader Rating: (0)
View Sidney's Photo Gallery
Shift lever pilot bushing # 33548-31010 (green)=$7 CDN
Shift lever seat # 33505-35020 or 33505-35030 (white)=$16 CDN
Note: the 2 above #’s fit all trannies:G,R,W series (22R,R-E,3VZE)84-95.5,no need for entire shift lever retainer (85-95.5 pre-Tacoma)
http://www.4runners.org/articles/shift/
http://www.off-road.com/toyota/tech/shifter/index.html
http://www.marlincrawler.com/docs/sh...eat/index.html
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:sidneybek@yahoo.com
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 245 000 KM
http://www.iwaynet.net/~nesda/May02/May18.html
http://www.iwaynet.net/~nesda/SonyAudMod.html
http://www.newark.com/product-detail...ge/32-9495.jpg
http://www.iwaynet.net/~nesda/Oct02/Oct028.html
http://www.iwaynet.net/~nesda/Oct02/Oct029.html
http://www.iwaynet.net/~nesda/Oct04/Oct041.html
O
|\ __O
_|_| \
Sidney is offline   Reply With Quote
Old 08-18-2005, 01:25 PM   #4
davet100
Trader Rating: (0)
Thanks Guys
Thanks for the information. On this basis I'll steer the dealer away from the shifting problem when he replaces the timing belt. It may only need a lever bushing/seat .
Thanks again
Dave
Old 08-18-2005, 05:42 PM   #5
Paper
Old Fart
Trader Rating: (0)
View Paper's Photo Gallery
I replaced my clutch for less than $400 without turning a wrench..
I bought a new clutch on eBay for $160 and a local mech put it in for $300..
Waitin' for my box..
Paper is offline   Reply With Quote
Old 08-22-2005, 01:21 PM   #6
davet100
Trader Rating: (0)
Cracked Bracket
I checked some other websites and evidently this model is susceptable to cracking the clutch mounting bracket, causing shifting problems.
http://www.4x4wire.com/forums/showfl...&Number=231519
Lo and behold, I found that the mounting bracket was cracked. Furthermore, if left unattended the firewall then cracks causing a BIG problem.
(If this happens to every T100 manual shift, why wasn't there a recall??)
I'll go after this first, then replace the shift lever bushings as suggested.
Dave P
Old 08-25-2005, 11:53 AM   #7
Paper
Old Fart
Trader Rating: (0)
I think they were waiting for enough complaints about the seat belt retracters, first...
Old 09-08-2005, 02:23 PM   #8
davet100
Trader Rating: (0)
Followup
Gents;
Finally got the cracked bracket replaced. That was the problem, 100% improvement. At first, I thought I might be getting in too deep, ending up with a tow to the dealer to bail me out. But the dealer wanted $455 for labor to get started,.. that got me motivated. Aside from ordering parts (~ $85) and research...it took 2- two hour evenings and plus some minor linkage adjustments and all was done using standard hand tools.
Lost a lot of pedal due to the added backing plate, and I also added internal reinforcement washers as the replacement bracket actually looks inferior to the original. Both plate and washers tending to push the master cylinder away from the clutch pedal. I've only got 5 threads made up on the adjustment shaft, but does the trick for now.
I'm going to post a step-by-step when I get a chance, maybe on a separate thread.
Thanks again for your input.
Old 09-11-2005, 06:16 AM   #9
mert
Trader Rating: (0)
View mert's Photo Gallery
nice to hear its fixed, not only about the recall on it that just came up....
mert is offline   Reply With Quote
vB code is On
Forum Jump
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Page generated in 0.12741 seconds with 13 queries
