Hello TN members,
I would like to contribute to this forum by compiling all the info I have found regarding remote programming. This might help clarify some doubts about programming the different versions of RS3000. This IS NOT my own writting, but rather, I took it from some other forum/website. I take no responsibilities regardless of what happens to your vehicle or the consequences/result of these programming instructions. I am just being kind to compile and share my findings. Please feel free to add anything that I have missed out, or correct the instructions provided if it wrong.
Here you go & good luck trying:
99,98,97 Camry VIP RS3000 alarm (dealer installed 2 button remote)
system. (FCC ID BAB237131-022)
1. Insert key into ignition, turn it to on(not acc)
2. On your ECU unit, gently push the button with the
tip of a paper clip, pen, etc, for about 3 seconds until the light on
the TOYOTA SECURITY panel lights up. You now have about 30 seconds to
press the button on your new remote once) to tell the car to
recognize it.
3. remove key from ignition
4. step out of car and test your remote
For a full manual for this RS3000 system, please refer to skewe's post, link is below:
http://toyotanation.com/forum/t93291.html
99,98,97 Camry VIP RS3000 alarm (factory installed 3 button remote)
system. (FCC ID GQ43VT7T)
1) With the key OUT of the ignition switch, locate and disconnect the power mirror control switch from the vehicle harness.
2) Using a suitable jumper wire (paper clip works), connect terminal 2 (Purple wire) to terminal 10 (White/Black wire).
The vehicle will cycle the locks once to confirm programming mode. If the vehicle doesn't respond - this prcendure will not work!
3) Press and release any buton on the remote. The vehicle will cycle the locks once to confirm code received.
4) Program additional remotes by repeating step 3
5) Disconnect the jumper to exit programming mode.
6) Reconnect and reinstall the mirror switch
terminal 2 is the second from left, top row terminal (the connecting side of the wiring harness facing you). Terminal 10 is the first terminal from right, bottom row. I hope this helps. Do let us know if you are successful in programming.
For RS3000, yr 2000 Camry, gen4.5
1)All doors unlocked, drivers door open
2)Insert key and remove(do not turn)
3)Lock and unlock doors with button on drivers door 5 times(1 sec intervals)
4)Close drivers door, Open drivers door
5)Lock and unlock doors with button on drivers door 5 times
6)Take key insert and turn to On position then to lock Twice, remove key
7) Locks should cycle lock to unlock by themselves if you completed the sequence properly and it is equipped with keyless entry
In the next 10 secs or so complete the next step :
8) Take the remote and hold lock and unlock buttons at the same time for
about a sec and then press either lock or unlock for a sec. If the
locks cycle the programming was a success.
For SECURIKEY+ system
PROGRAMMING ADDITIONAL or REPLACEMENT TRANSMITTERS
Each SECURIKEY+ system can be operated by up to four (4) different
SECURIKEY+ transmitters. The system is supplied from the factory with two
(2) transmitters included, and additional transmitters are available through
parts distribution. Any new or replacement transmitters will need to be
programmed to the main control module before they will activate the system.
The SECURIKEY+ main control module uses a six (6) channel radio frequency
receiver; each channel controlling a different function of the SECURIKEY+
system. Each transmitter button can be programmed to only one of the
receiver channels (e.g., the GREEN button cannot be programmed to operate
the headlight feature and remote start option; it can operate only one or
the other feature). The following is a list of each receiver channel, and
the function of each channel.
CHANNEL # FEATURE CONTROLLED BY THIS CHANNEL
1 Lock
2 Unlock
3 Trunk Release (optional kit required; not available on all models)
4 30 second headlight activation (only if required by GREEN button)
5 Remote panic (only if required by GREEN button instead of LOCK
button)
6 Remote start (optional kit required; not available on all models)
To program new or additional transmitters, or when adding options to
existing SECURIKEY+ transmitters, follow the step by step programming
instructions found below. When programming, it is important to complete each
step of the procedure within 15 seconds, or the system will terminate the
programming mode. If this happens, simply start again.
Be sure that the SECURIKEY+ system is disarmed, and the lighted valet switch
is in the off (out) position before you begin.
Turn the vehicle's ignition key to the on position.
Press then release the L.E.D. valet switch 6 times.
CHANNEL 1: LOCK & Panic Feature Horn Chirps 1 Time L.E.D. Flashes 1 Time
To program the LOCK button on the transmitter, press and hold the LOCK
button until the vehicle's horn sounds one loud chirp. Repeat this for all
transmitters that need the LOCK button programmed (up to four transmitters).
After the LOCK button on all transmitters have been programmed, press and
release the L.E.D. valet switch 2 times to advance to the next receiver
channel.
CHANNEL 2: UNLOCK Feature Horn Chirps 2 Times L.E.D. Flashes 2 Times
To program the UNLOCK button on the transmitter, press and hold the UNLOCK
transmitters that need the UNLOCK button programmed (up to four
transmitters).
After the UNLOCK button on all transmitters have been programmed, press and
channel.
CHANNEL 3: TRUNK RELEASE Option Horn Chirps 3 Times L.E.D. Flashes 3
Times
To program the TRUNK RELEASE option on the transmitter, press and hold the
GREEN option button until the vehicle's horn sounds one loud chirp. Repeat
this for all transmitters that need the GREEN option button programmed (up
After the TRUNK RELEASE button on all transmitters have been programmed,
press and release the L.E.D. valet switch 2 times to advance to the next
receiver channel.
CHANNEL 4: 30 SECOND HEADLIGHT Feature Horn Chirps 4 Times L.E.D.
Flashes 4 Times
To program the HEADLIGHT option on the transmitter, press and hold the GREEN
option button until the vehicle's horn sounds one loud chirp. Repeat this
for all transmitters that need the GREEN option button programmed (up to
four transmitters).
After the HEADLIGHT button on all transmitters have been programmed, press
and release the L.E.D. valet switch 2 times to advance to the next receiver
channel.
CHANNEL 5: Separate PANIC Button Feature Horn Chirps 5 Times L.E.D.
Flashes 5 Times
To program the PANIC option on the transmitter, press and hold the GREEN
four transmitters).
After the PANIC button on all transmitters have been programmed, press and
channel.
CHANNEL 6: REMOTE START Feature Horn Chirps 6 Times L.E.D. Flashes 6
Times
To program the REMOTE START option on the transmitter, press and hold the
After the REMOTE START button on all transmitters have been programmed,
press and release the L.E.D. valet switch 2 times to advance to terminate
programming mode, or simply turn the ignition key to the off position to
terminate the transmitter programming mode.
PROGRAMMING THE SELECTABLE FEATURES
The SECURIKEY+ system offers a number of selectable features that can be
changed, allowing you to custom fit the system to your customer. The
following is a list of the features that are selectable and can be changed
using the valet switch and any transmitter that is programmed to the system
installed in the vehicle.
FEATURE # FUNCTION 1 CHIRP 2 CHIRPS
1 Headlights on for 20 seconds during disarm ON or OFF
2 Headlights on for 20 seconds during arm ON or OFF
3 Automatic ignition controlled door lock ON or OFF
4 Automatic ignition controlled door unlock ON or OFF
5 Auto unlock driver's door only or all doors Driver's door or
All doors
6 Active or Passive arming Passive or Active
7 Active or Passive door locks Passive or Active
8 Trunk release output - 1 second or latched 1 second or
Latched
9 Panic on lock button or option button Option or Lock
10 Trunk Release Hold - 1 second or 2 presses Hold 1 Sec or
2 Times
To change the selection of any of these features, follow the step by step
programming procedures, and do not allow more then 15 seconds to pass
between any two steps or the system will terminate the programming mode.
There is no need to complete the entire programming sequence. After the
appropriate features have been changed, simply turn the ignition key off to
Immediately turn the ignition key off then back on.
FEATURE 1 LED Flashes 1 Time
1 chirp = Headlights ON During Disarm Horn Chirps either 1 or 2 Times
2 Chirps = Headlights OFF During Disarm
To change the selection, press and release the lock button on the
transmitter, which will be indicated by the appropriate 1 or 2 chirp signal
from the horn. If you do not want to change this feature, simply press and
release the L.E.D. valet switch 2 times to advance to programmable feature
number 2.
FEATURE 2 LED Flashes 2 Times
1 chirp = Headlights ON During Arm Horn Chirps either 1 or 2 Times
2 Chirps = Headlights OFF During Arm
number 3.
FEATURE 3 LED Flashes 3 Times
1 chirp = Ignition controlled door locks ON Horn Chirps either 1 or 2
Times
2 Chirps = Ignition controlled door locks OFF
number 4.
FEATURE 4 LED Flashes 4 Times
1 chirp = Ignition controlled unlock ON Horn Chirps either 1 or 2 Times
2 Chirps = Ignition controlled unlock OFF
To change the selection, press the lock button on the transmitter, which
will be indicated by the appropriate 1 or 2 chirp signal from the horn. If
you do not want to change this feature, simply press and release the L.E.D.
valet switch 2 times to advance to programmable feature number 5.
FEATURE 5 LED Flashes 5 Times
1 chirp = Ignition controlled unlock DRIVER'S DOOR Horn Chirps either 1
or 2 Times
2 Chirps = Ignition controlled unlock ALL DOORS
valet switch 2 times to advance to programmable feature number 6.
FEATURE 6 LED Flashes 6 Times
1 chirp = PASSIVE ARMING (Automatic Arming) Horn Chirps either 1 or 2
Times
2 Chirps = ACTIVE ARMING (Arm by Remote Only)
valet switch 2 times to advance to programmable feature number 7.
FEATURE 7 LED Flashes 7 Times
1 chirp = PASSIVE DOOR LOCKS Horn Chirps either 1 or 2 Times
2 Chirps = ACTIVE DOOR LOCKS
valet switch 2 times to advance to programmable feature number 8.
FEATURE 8 Do not change this feature selection. It should be left in the
factory preset (1 chirp) mode. Press and release the L.E.D. valet switch 2
times to advance to programmable feature 9.
FEATURE 9 LED Flashes 9 Times
1 chirp = Remote Panic / GREEN transmitter button Horn Chirps either 1 or
2 Times
2 Chirps = Remote Panic / LOCK transmitter button
valet switch 2 times to advance to programmable feature number 10.
FEATURE 10 LED Flashes 10 Times
1 chirp = Trunk Release HOLD GREEN BUTTON 1 SECOND Horn Chirps either 1
or 2 Times
2 Chirps = Trunk Release PRESS GREEN BUTTON 2 TIMES
valet switch 2 times to exit the programming mode.
For RS3200
If for some reason, your gen 4 has a rs3200, Click on the link below:
http://www.geocities.com/toyota_speed2003/keyless_entry.html
Additional Information:
Toyota security systems are made by a company called Fujitsu Ten. If the info above did not help solve your problem, you can use this info:
For anyone who needs the fujitsu 10 faxback number here it is:
310-327-9905
you will need a fax machine/number to recieve fax back from them.
Hopefully this information helps
Credit dedication: Thanks to Skewe and nodrogkam, as well as lenjack to have contributed towards the knowledge and database of this compilation.
recognize it.
1 Lock
2 Unlock
button)
channel.
transmitters).
channel.
Times
receiver channel.
Flashes 4 Times
four transmitters).
channel.
Flashes 5 Times
four transmitters).
channel.
Times
All doors
Latched
2 Times
number 2.
number 3.
Times
number 4.
or 2 Times
Times
2 Times
or 2 Times
For RS3200
310-327-9905
