» Sponsors
» Sponsors
Go Back   Toyota Forums :: Toyota Nation > Toyota Passenger and Sports Car Forums > Supra Forum
Register Home Forum Active Topics eBay Marketplace Photo Gallery TN Arcade Blogs Mark Forums Read
Supra Forum Forum for all Toyota Supra generations.
Please Visit our Site Sponsors
Thread Tools Display Modes
Old 11-08-2005, 06:45 PM   #1
glish_dreams
Toyota Fiend
Trader Rating: (0)
View glish_dreams's Photo Gallery
Supra Specs and time frames?
I was just wondering the spec on all GENs .. like HP torque .. Valves,Cams, liters, L6 or V6 .. and what GTE GTTE means.. i understand the T TT is turbo twin turbo.. im guessing E is engine .. and i was wondering the GEN time frames..
a friend of myne told me in 85 ..that was the first year supra was just supra.. not celica supra... is that true.. its my bday..and it means something to me..and id like to have a 85 if thats true..
motors i no ..7M, 1JZ, 2JZ .. GE GTE GTTE..
thank you...
glish_dreams is offline   Reply With Quote
Old 11-08-2005, 08:49 PM   #2
glish_dreams
Toyota Fiend
Trader Rating: (0)
i found most my info on another post.. thats crazy and amazing that it was always L6
MAN... MAN! WHAT THE HECK! LOL
1979-80: 4M-E, inline-6 2.6L SOHC 12-valve engine
1981: 5M-E, inline-6 2.8L SOHC 12-valve engine
1982-86: 5M-GE, inline-6 2.8L DOHC 12-valve engine
1986.5-1992: 7M-GE, inline-6 3.0L DOHC 24-valve engine
1987-1992: 7M-GTE, inline-6 3.0L DOHC 24-valve turbocharged engine
1993-1998: 2JZ-GE, inline-6 3.0L DOHC 24-valve engine
1993-1998: 2JZ-GTE, inline-6 3.0L DOHC 24-valve turbocharged engine
That's for North America Only.
In Japan the Supra had a Turbocharger earlier, though it was called a Celica XX from 79-86, not a Supra. The 82-86 Celica XX/Supra had many more engines than we got (we only had the 5M-GE). Worldwide, the MK2 had the 5M-E, 5M-GE, 6M-GE, M-TE, 1G-GTE, and possibly others. The M-TE and 1G-GTE are both turbocharged 2.0L inline-6 engines. The 1G-GTE is twin-turbocharged.
The MK3, worldwide, had the following engines: 1G-E, 1G-FE, 1G-GE, 1G-GTE, 7M-GE, 7M-GTE, and 1JZ-GTE. The 1JZ-GE was never sold in the Supra, and the 7M-GE was NOT sold in the Supra in Japan.
The MK4 only had the 2JZ-GE and 2JZ-GTE, though in 1998 the 2JZ-GE got VVT-i, and in 1999 the 2JZ-GTE got VVT-i as well, but we never got the Supra in North America past 1998. It was sold in Japan until 2002.
Hope that helps a bit.
Old 11-09-2005, 10:38 AM   #3
Jeeves
Got Hardass?
Jeeves's Avatar
Trader Rating: (0)
View Jeeves's Photo Gallery
What The **** is an L6?
The VVTi 1JZ-GTE's use a single turbo but are only found in the 97+ JZX100 Chasers & 97-00 JZZ30 2.5GT-T Soarers. There are no VVTi 1JZ-GTE's with a factory twin turbo configuration.
The VVTi 2JZ-GTE was still twin turbo but incorporated the same overall changes otherwise when it went VVTi. (MAF, wastespark, etc)
2JZ's always had twin turbos (and of course, N/A's) and 7M's had a single turbo (and the N/A as well). There was never a real (see: Factory) '7M-GZE' as some pictures around the web suggest. As for TT MA70's (Mk3 Supras), The only ones in existance were not offered stateside. The ones that were offered were either the 2.5L TT (1JZ-GTE) engine or the 2.0L TT (1G-GTE) motor not the 3.0L 7M-G(T)E motor we're all used to seeing.
(I'm just throwing all this out so that hopefully when the next noob wanders into the forum, they'll search and find this post. Obviously it's not all On Topic info.)
There are several TT manifolds in existance for the 7M, however due to the potential of a larger single, it's often the chosen power path. I know blitz made one, HKS made one, the 5M TT manifold which bgreiger has is from HKS IIRC... The authentic ones (not clones) are rare to find in most cases.
For future reference, this site has a lot of information about the import and export models of the Mk4 Supra: http://mkiv.supras.org.nz/specs.htm
As far as names are concerned, 2JZ-GTTE is really a nickname, the actual motor code is 2JZ-GTE regardless of how many turbos it has. Since the topic has arisen, here's a primer on Toyota Enginge Codes:
Toyota engine codes are split into two sections:
1. Before the dash - Which represents the family or series of the engine (i.e. 7M-GTE.)
2. After the dash - Which represents the engine features (i.e. 7M-GTE.)
#1 - Before the Dash:
The numbers represents a revision of the bottem end for example bore, stroke, and block.
  • A = A series engine, 4 cyl gasoline. Family of inline-4 configuration engiens with a displacement ranging from 1.3L to 1.8L. Series began in the late 1970s with the 1A, a SOHC with a displacement of 1.5L. In 1998, the 7A-FE was the last A engine in the family, a 1.8L DOHC engine that produced 115 HP.
  • AZ = AZ series engine, 4 cyl, gasoline. Family of straight-4 piston engines. Uses an aluminum engine block & aluminum DOHC cylinder heads. Has MFI FI and 4 valves per cylinder with VVT-i and features forged steel connecting rods.
  • C = C series engine, 4 cyl diesel.
  • G = G series engine, 6 cyl gasoline, family of straight-6 piston engines produced from 1979 through 1998. Only a single displacement, 2.0L was produced in this series. All were belt-driven OHC engines, with multivalve DOHC and even variable valve timing added later. These were used as a lower-displacement alternative to the more-common M family straight-6.
  • JZ = JZ series engine, 6 cyl gasoline, family of straight-6 engines.
  • K = K series engine, 4 cyl gasoline, pushrod. Family of straight-4 engine produced from 1966 through 1998. 2-valve pushrod design, a rarity for the company.
  • M = M series engine, 6 cyl gasoline, family of straight-6 engines used from the 1960s through the 1990s. All M-family engines were OHC designs with a chain-driven camshaft giving way to a belt after 1980. The 4M-E was notable in that it was the first Toyota engine to be equipped with fuel injection. The M family was commonly found on the large Toyota Crown, Celica Supra, and Supra.
  • MZ = MZ series engine, V6 piston driven, aluminum engine block and aluminum DOHC cylinder heads. The cylinders are lined with cast iron. It uses MFI fuel injection, has 4 valves per cylinder and features a one-piece cast camshaft and cast aluminum intake manifold.
  • NZ = NZ series engine, 4 cyl gasoline, family of straight-4 piston engines. The 1NZ uses aluminum blocks and DOHC cylinder heads. It also uses SFI FI, and has 4 valves per cylinder with VVT-i.
  • P = P series engine, 4 cyl gasoline, family of straight-4 engine produced from 1959 through 1979.
  • R = R series engine, 4 cyl gasoline. Family of straight-4 engines produced from 1953 through 1990. Designed for longitudinal use in such vehicles as the Celica and Cressida. OHC versions featured a chain-driven camshaft.
  • RZ = RZ series engine, 4 cyl gasoline, family of straight-4 engines usign a cast iron engine block & aluminum DOHC cylinder heads. Has MFI FI, 4 valves per cylinder and features forged steel connecting rods.
  • S = S series engine, 4 cyl gasoline.
  • T = T series engine, 4 cyl, gasoline, family of straight-4 engines. Began as an OHV design, but a chain-driven DOHC variant came later.
  • U = U series engine, series of flat-twin engines produced in the 1960s and 1970s.
  • UZ = UZ series engine, 8 cyl gasoline, V8.
  • VZ = VZ series engine, 6 cyl gasoline, V6.
  • ZZ = ZZ series engine, 4 cyl gasoline, family of straight-4 piston engines. The series uses an aluminum engine block and aluminum DOHC 4-valve cylinder heads.
Here is a different, more simpler, summation:
(All engines cast iron block, alloy head unless otherwise mentioned.)
  • A series (inline 4, belt, 1.3-1.6L, 1978-): Corolla FWD/RWD, MR2, Tercel FWD
  • AZ series (inline 4, aluminum block ?, chain, 2.0-2.4l, 2000-): RAV4, Previa
  • E series (inline 4, belt, 1.0-1.5L, 1985-): Corolla FWD, Tercel FWD, Paseo
  • F series (inline 6, 3.9-4.3L, cast iron head, 1948-1992)
  • FZ series (6 cylinders, 4.5L, 1993-)
  • G series (inline 6, belt, 2.0L, 1979-): Soarer, Celica Supra, Crown, Cressida, Altezza
  • GZ series (V12, 5.0l, 1997-)
  • JZ series (inline 6, belt, 3.0L, 1993-)
  • K series (inline 4, chain, 1.0-1.5L, 1966-1989+): Corolla RWD, Starlet RWD, Lite-ace
  • M series (inline 6, SOHC & DOHC (pre-80) chain, DOHC (82-) belt, 2.0-3.0L, 1965-1992): Crown, Celica Supra, Supra
  • MZ series (V6 60 degrees, alloy block + head, belt, 3.0l, 1994-)
  • NZ series (inline 4, chain, 1.3l, 1999-): Yaris
  • P series (4 cylinders, 1.0-1.4L, 1959-1979)
  • R series (inline 4, chain, 1.5-2.4L, 1953-1990+): Celica RWD, Cressida RWD
  • RZ series (I4): Tacoma
  • S series (inline 4, belt, 1.9-2.0L, 1982-): Celica FWD/4WD, MR2 RWD, Carina FWD, Camry
  • T series (inline 4, chain, 1.5-1.8L, 1970-1985): Carina RWD, Celica RWD, Corona RWD, Corolla RWD
  • TZ series (I4, chain)
  • U series (boxer 2, 0.7-0.8L, 1961-1976)
  • UZ series (V8 (90 degrees), alloy block, belt, 4.0-4.6L, 1989-)
  • V series (V8 (90 degrees), toothed wheel, 2.6-4.0L, 1963-)
  • VZ series (V6, belt, 2.5-3.0L, 1987-): Camry, Tacoma
  • Y series (4 cylinders, 1.7-2.3L, 1982-)
  • ZZ series (inline 4, aluminum block, chain, 1.8l, 1997-): Corolla
#2 - After the Dash:
  • B - Dual standard carbs (only used on non-twin cam engines, obsolete code)
  • C - Californian pollution control (also most of the world)
  • D - Dual carbs but more powerful than -B
  • E - Electronic Fuel Injection
  • F - Twin Cam (economy). Narrow Agle, Around 22 degrees between the intake and exhaust valves.
  • G - Twin Cam (sports/powerful) with multiple sidedraft carbs (unless EFI). Wide Angle, 45 degrees or more between the intake and exhaust valves.
  • H - Unknown but never combined with -B or -C
  • I - Single point fuel injection
  • II - Unknown - possibly denotes L.A.S.R.E (Lightweight Advanced Super Response Engine)
  • J - Unknown, possibly autochoke, possibly another anti-pollution control
  • L - Transverse mounted engine (seems to be an obsolete code)
  • LPG - LPG fuel
  • M - Phillipines market (details unknown)
  • P - LPG fuel
  • R - Low compression for regular (not super or premium) fuel.
  • S - Swirl intake ports (only a few made in mid '80s)
  • S - Direct injection & swirl pot pistons (starting from '97/98)
  • T - Turbocharged
  • U - Japanese pollution control (introduction of "U"nleaded?), (Engine uses TTC-C, TTC-L or TTC-V).
  • Z - Supercharged
Refer to the list of popular engines below for examples of engines and there codes:
  • 4A-GE: 1.6 DOHC EFI 16V inline four cylinder
  • 4A-GE 20 Valve: 1.6 DOHC EFI 20V inline four cylinder
  • 4A-GZE: 1.6 DOHC EFI 16V supercharged inline four cylinder
  • 7A-FE: 1.8 DOHC EFI 24V intercooled twin turbo inline six cylinder
  • 7M-GTE: 3.0 DOHC EFI 24V turbo inline six cylinder
  • 2JZ-GTE: 3.0 DOHC EFI 24V turbo inline six cylinder
  • 3S-GTE: 2.0 DOHC EFI 16V turbo inline four cylinder
Combining all our above knowledge, we get:
  • 1MZ-FE: MZ series engine, V6 cyl gasoline. Alum Block & Head (DOHC), Fuel Injected, Economy Twin Cam head (22º between I & E Valves), Belt Driven.
  • 7M-GTE (Mk3): M series engine, inline 6 cylinder, DOHC, Belt Driven, Powerful Twin Cam Head(45º between I & E Valves), Turbocharged.
  • 2JZ-GTE: JZ series engine, inline 6 cylinder, DOCH, Belt Driven, Powerful Twin Cam Head(45º between I & E Valves), Turbocharged.
Now, back on topic:
Mk3 3.0 Single Turbo (USDM):
Motor Code: 7M-GTE
Displacement: 3.0L
Number of Turbos: 1
Common Nicknames: GTE, T, Mk3 Turbo, Mk3, etc.
HP/TQ: Pre-1989 -> 230hp/246tq, 1989+ -> 232hp/254tq
Chassis Code: MA70
Driver: LHD
Mk3 2.5 Twin Turbo (JDM):
Motor Code: 1JZ-GTE
Displacement: 2.5L
Number of Turbos: 2
Common Nicknames: 2.5TT, 2.5, 1JZ, etc.
HP/TQ: 280hp/266tq
Chassis Code: JZA70
Driver: RHD
Mk3 2.0 Twin Turbo (JDM) (RARE):
Motor Code: 1G-GTE
Displacement: 2.0L
Number of Turbos: 2
Common Nicknames: 2.0TT, 1G-GTE, etc.
HP/TQ: 185hp/173tq
Chassis Code: GA70
Driver: RHD
Mk4 Twin Turbo:
Motor Code: 2JZ-GTE
Displacement: 3.0L
Number of Turbos: 2
Common Nicknames: GTTE, TT, Twin Turbo, "BPU" (BPU = Basic Performance Upgrades. Intake, Exhaust, Boost Controller), etc.
Chassis Code: JZA80
USDM HP/TQ: 320hp/315tq
JDM HP/TQ: 280hp/323tq
Driver: LHD & RHD (US/J-DM Dependant)
Jesus, at least you searched.
1988 Mk3 Turbo Targa - 17.5psi, 486hp, 494tq.
Who came up with this 500px wide BS?
Jeeves is offline   Reply With Quote
Old 11-09-2005, 01:52 PM   #4
glish_dreams
Toyota Fiend
Trader Rating: (0)
holy ..thats alot of info.. THANKS..
oh L6 is inline six.. its not I6.. thats the incorrect way to show it.. at least thats what my college teacher said...
Old 11-09-2005, 02:39 PM   #5
repinS
5M-GE
repinS's Avatar
Trader Rating: (0)
View repinS's Photo Gallery
Yeah, the technically correct way is L6, it's the convention because people can confuse "I6 for "16".
But I (and many others, including Jeeves) use I6 in real life.
85 Cressida // RIP 11/2003
95 Pontiac Bonneville SSEi | 3800 SC | 225hp/275lb-ft
repinS is offline   Reply With Quote
Old 11-09-2005, 04:26 PM   #6
glish_dreams
Toyota Fiend
Trader Rating: (0)
well non the less the information was great and i printed it out for safe keeping.. thanks.
Old 11-11-2005, 06:40 PM   #7
glish_dreams
Toyota Fiend
Trader Rating: (0)
whts those stand for.. are they something for emissions like VVTL
Old 11-14-2005, 03:45 PM   #8
Jeeves
Got Hardass?
Jeeves's Avatar
Trader Rating: (0)
They are all types of emission controls in Japan.
Old 03-15-2006, 08:51 PM   #9
bowlofturtle
Trader Rating: (0)
View bowlofturtle's Photo Gallery
we have the 230hp on the crank. but what are most of you guys putting to the wheels on your baseline dyno's. generally its about 15% or so with a 5 spd. but i wanted to get idea how much it is on a supra.
96 Camry Le I-4
bowlofturtle is offline   Reply With Quote
Old 03-16-2006, 11:53 AM   #10
Jeeves
Got Hardass?
Jeeves's Avatar
Trader Rating: (0)
Never did a basline dyno, sorta wish I had. My first dyno was 262/315 @ 9psi.
Intake/Exhaust/Boost Controller/Fuel Controller. Timing @ 14ºBTDC.
Old 04-10-2006, 01:39 AM   #11
PpDdAiDdDdYy
Trader Rating: (0)
View PpDdAiDdDdYy's Photo Gallery
Can I put this supra info on my website?
PpDdAiDdDdYy is offline   Reply With Quote
Old 04-10-2006, 10:44 AM   #12
SuprAdam
SuprAdam's Avatar
Trader Rating: (0)
View SuprAdam's Photo Gallery
http://www.ma70.com/bishop92t/differ.html
- 1989 Supra turbo - r.i.p.
- 1986.5 Supra
--->GT40-82 powered 7MGTE, MSII V3.0 w/ VR/EDIS-6, 65 lb/hr inj.
SuprAdam is offline   Reply With Quote
Old 04-10-2006, 11:42 AM   #13
Jeeves
Got Hardass?
Jeeves's Avatar
Trader Rating: (0)
I'd prefer you put a link to this forum, but as it is the web and not my copyrighted information there's nothing I can really do to stop you from doing so.
Originally Posted by SuprAdam
Nice page with some good info, but not as explicit.
Old 04-14-2006, 03:52 PM   #14
PpDdAiDdDdYy
Trader Rating: (0)
IfI link to your page would you do the same for me? And what did you mean by its not as explicit?
Old 04-14-2006, 07:08 PM   #15
Jeeves
Got Hardass?
Jeeves's Avatar
Trader Rating: (0)
It's not as detailed as information that can be found elsewhere. And what are you talking about a link trade? I don't have a website to put a link to you on.
vB code is On
Forum Jump
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Page generated in 0.23693 seconds with 13 queries
