2005+ Tacoma GeneralDiscussion area for all the new Toyota Tacoma owners out there!
That's weird. Is it wired to some kind of switch? You would think that the door buzzer would just be wired into the door pin switch that is mounted on the door frame; not into the actual door.
Is it just a single wire? You could wire an inline switch to it and turn it off when you want to use the stereo. If you wanna get fancy you could put a relay on it that opens when the amp has power.
__________________ Current truck...
2008 Tundra TRD Off-Road DC 4x4
Previous truck...
2005 Tacoma SR5 DC 4x4
There is a much easier way to stop the open door buzzer that requires no wire changing.
Try this:
- Turn key to ON and turn on radio.
- Open the driver's door, the buzzer sounds.
- Shut the door, the buzzer stops.
- Open the door again, the buzzer will not start again.
Try this:
If you leave the key in the ON postion the beeping sound goes away after a few secs wheather the door is open or closed. I don't think this works in ACC position only in ON position.
2005 DBL CAB PreRunner, TRD Off-Road, Super White. Build Date 8/2005.
I think there is also a fuse in the fuse panel under the steering coulmn, you might be able to wire in a switch from there to be placed in your spare switch panels.
Or just install a switch on the back door panel.
Who has the write-up for it? Taking off the rear door panel and the one under the steering column? Anyone???
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
