» Sponsors
» Sponsors
Go Back   Toyota Forums :: Toyota Nation > Toyota Truck, SUV and Van Forums > Toyota Tacoma Forum > 2005+ Tacoma General
Register Home Forum Active Topics eBay Marketplace Photo Gallery TN Arcade Blogs Mark Forums Read
2005+ Tacoma General Discussion area for all the new Toyota Tacoma owners out there!
Please Visit our Site Sponsors
Thread Tools Display Modes
Old 01-08-2006, 01:05 AM   #1
Pb
Surfing TN via iPhone
Pb's Avatar
Trader Rating: (15)
View Pb's Photo Gallery
My Electric Fan Mod is Complete!
I finally got around to replacing the stock clutch fan with a Zirgo electric fan. I used a Zirgo 16" 3300 cfm fan, and adjustable thermostat.
This mod took longer than I thought it would, but it was still way worth it. Now the engine doesn't ROAR to life like it used to. It starts up nice and easy. It's really amazing how quiet the engine is now. I can almost here crickets chirping in the background.
The engine also seems to have more pep. I don't have any dyno numbers, but I'm pretty sure that the engine accelerates and "winds up" faster.
It also warms up quicker, which is nice on a cold night like tonight. It only takes a few minutes of driving to get it up to normal temp. I drove a few miles before the fan came on. I have it set to come on at 195 degrees F. When the fan turns ON it's not that loud. It's certainly quieter than the stock fan, but still audible from the cab.
And if for some reason I need to go through deep water or mud then all I have to do is open the hood and turn the thermostat up to 240 degrees, and the fan will shut off; then I don't have to worry about water or mud tearing up the fan.
Now for the install details:
I removed the grille so I could get a little closer to the engine for reaching down in there. And for mounting the thermostat control.
Take off the engine cover.
Take off the 8 plastic pins that hold the trim piece on top of the radiator and core support. Pop up the center part of the pin with a flat head screw driver.
Pull off the little hose on the reservoir.
To get them out you have to remove the fan and the shroud at the same time. I used a ratcheting wrench to take off the 4 nuts that hold the fan on. I took off two nuts and then started the engine for a second so that the other nuts would spin around to the passenger side of the engine, where they are easier to reach. Just let the fan sit there. Then take out the two bolts that hold the shroud at the top corners. That is all that holds the shroud. The bottom part of the shroud fits into clips on each side. Just pull straight up, and bring the fan up with the shroud at the same time. There is a little nub at the bottom of the shroud that gets hung up on the bottom radator hose. Get under the front of the truck and squeeze the hose and then push up on the shroud. Now it should all come out with a little manuvering and some sweet talkin'.
Put the 4 nuts back on the pulley. The bolt studs aren't threaded all the way because of the mounting flange of the fan/clutch. So you now need to use a washer on each stud to work like a spacer. I then put red Loc-tite on the threads and tightened down the nuts.
To make the fan as efficient as possible you need to seal off any space on the sides of the fan, so that the fan can only pull air straight through the radiator. To fill in this gap I made a "donut" out of a sheet of aluminum. I used an air-shear, but tin snips should work too. I then screwed the fan to the aluminum with 8 screws. Then I bent the aluminum to fit the curves of the inside of the stock shroud. Then used Pop-rivets around the circumference to hold the aluminum to the shroud. It turned out to be pretty solid.
(For rivets that don't tighten down real well, you can place a hammer on the back side of the rivet and then hit the other side with another hammer. This will smash the rivet and make it tighten up on the metal. Stainless steel rivets will anchor down better than aluminum rivets, but they are much harder to use with a pop-rivet tool.)
Then I sealed up the circumference with some silicone to make it more secure and air tight where the aluminum and the shroud meet.
I mounted the thermostat control on the front side of part of the core support, next to the passenger-side headlight. I used an existing hole for the knob to stick through into the engine compartment. The thermostat sensor goes inside the radiator hose. I opened the petcock on the bottom drivers side and drained out a little fluid so that it wouldn't spill all over when I took off the top radiator hose. Put the sensor in, clamped it back down, filled the radiator back up with fluid. You could use a small bucket to catch the fluid underneath, and then pour it back in the top once you are ready. There is a hole in the skid plate right where the fluid drains out of the petcock. It isn't messy at all,
Then I did the wiring. I used a relay, which is connected to the ignition circuit, so that the fan will shut off whenever the engine is off. Otherwise the fan will keep running until the engine is cooled below 180 degrees; which is just a waste of battery power. Then I ran a 12 gauge power wire from the output of the relay to the positive of the fan and then the negative wire runs to the thermostat. These fans can blow either way, depending on how you have the polarity going to the fan. Be sure that the fan is blowing toward the engine, which sucks air through the radiator. This is called a pulling setup. Pulling air cools the radiator better than a pushing setup, where the fan is in front of the radiator.
Here it is all put back together.
I would certainly recommend this mod to anyone that can tackle it. I expect to get better MPG, a few more HP, and better cooling on hot days and in traffic. Oh, and the faster warm-up, and quieter engine is nice too.
Pb is offline   Reply With Quote
Old 01-08-2006, 01:11 AM   #2
SilverStreak05
Self Proclaimed Genius
Trader Rating: (1)
View SilverStreak05's Photo Gallery
Quality work, as usual
Donahoe - Total Chaos - Deaver - Wheelers - Goodyear
SilverStreak05 is offline   Reply With Quote
Old 01-08-2006, 01:12 AM   #3
RningOnFumes
Ninja-rator
RningOnFumes's Avatar
Trader Rating: (5)
View RningOnFumes's Photo Gallery
nice clean install and great write up
< TN Type [R]ice Club> RICERS UNITE!!
Brake lights aren't broken, I just don't brake.
RningOnFumes is offline   Reply With Quote
Old 01-08-2006, 03:44 AM   #4
Turtleboy
Turtleboy's Avatar
Trader Rating: (0)
View Turtleboy's Photo Gallery
wow...great write up. Keep us posted on your MPG reports.
Turtleboy is offline   Reply With Quote
Old 01-08-2006, 03:58 AM   #5
NorCalTacoma
My name is Blake
Trader Rating: (1)
View NorCalTacoma's Photo Gallery
I simply jock.
Creative beyond all reason!
NorCalTacoma is offline   Reply With Quote
Old 01-08-2006, 04:08 AM   #6
rpmspeedyBlue
05 Speedwayblue X-runner
rpmspeedyBlue's Avatar
Trader Rating: (0)
View rpmspeedyBlue's Photo Gallery
Very impressive Pb2theMax!!!!
rpmspeedyBlue is offline   Reply With Quote
Old 01-08-2006, 04:41 AM   #7
Bigblue
Don't mess with the Blue
Bigblue's Avatar
Trader Rating: (1)
View Bigblue's Photo Gallery
very nice job. let us know how the MPG and HP gains are. Good Job.
2006 SpeedwayBlue Tacoma TRD Sport
Bigblue is offline   Reply With Quote
Old 01-08-2006, 08:52 AM   #8
Silver-Bolt
Trader Rating: (0)
View Silver-Bolt's Photo Gallery
Excellent. You should pick up a little power (less rotating mass) and also better fuel economy as well.
06 Taco 4DR TRD-Sport
08 VW R32
04 Subaru STi (377whp)
00 Ford Lightning (528whp)
04 Aprilia Tuono Factory & Aprilia SXV 550
Silver-Bolt is offline   Reply With Quote
Old 01-08-2006, 10:49 AM   #9
lotust
Stupid is stupid does
lotust's Avatar
Trader Rating: (3)
View lotust's Photo Gallery
nice job. But could you have used an 18" fan ? This is a mod I would do to save on gas ans to warm my truck up faster.
remember the ford SHO fan mod in the earlier trucks ? great mod also
08 Dc 5.7 Off road 4x4
JBA SS single Cat back,Incab LEDS all around
35w 5000k HIDs,Curt 2" Front hitch
lotust is offline   Reply With Quote
Old 01-08-2006, 01:25 PM   #10
NESW20
3SGTE & 1GRFE
Trader Rating: (0)
View NESW20's Photo Gallery
nice. curious though, why do you have your fan set to come on at 180F? that's kind of cold for the fan to come on. the thermostat should start opening around then, but the fan should wait until closer to 210F to come on. i've seen some OEM applications where the fan doesn't come on until 230F.
-Mike
1991 MR2 Turbo 2.1L stroker
2006 Tacoma D-cab 4x4 Auto TRD Off Road
NESW20 is offline   Reply With Quote
Old 01-08-2006, 01:45 PM   #11
Pb
Pb's Avatar
Trader Rating: (15)
16" is plenty big for most auto applications. One 16" can easily cool a big V8. Plus a bigger fan is going to need a bigger motor and more electrical current as well. There aren't many 18" electric fans that I could find, and the ones that I did find didn't flow much air. What really matters is the CFM; how much air the fan can move. The speed of the motor and the shape of the fan blades is what matters.
Old 01-08-2006, 01:51 PM   #12
Pb
Pb's Avatar
Trader Rating: (15)
-Mike
Yeah, I agree. I think 180 is too cool. I asked around but couldn't find anybody that knew what temp the coolant is supposed to run at. I don't know much about foreign engines. I guess I could try 210. What do you guys think?
Old 01-08-2006, 04:03 PM   #13
Walters
Trader Rating: (0)
View Walters's Photo Gallery
I personally would not jump up to 210 without researching this. I do agree 180 is low, but somehow 195 or so might be a more reasonable place to start. The fan should only come on while idling hot and only then after a few minutes, not right away. It shouldn't run at all while you are moving and air is moving through the radiator. In cool weather, most electric fans will rarely come on, unless you do extended idling, like a traffic jam where you are not moving.
Walters is offline   Reply With Quote
Old 01-08-2006, 05:20 PM   #14
lotust
lotust's Avatar
Trader Rating: (3)
Pb2theMax do you know off hand the max depth I can use? also do you know the L"xW" ?
Old 01-08-2006, 06:33 PM   #15
movielife
817
movielife's Avatar
Trader Rating: (1)
View movielife's Photo Gallery
Pb2theMax, great install. Nice and work!
movielife is offline   Reply With Quote
vB code is On
Forum Jump
Similar Threads
Electric Fan Brando8844 T-100 3 01-02-2006 07:36 AM
Electric Fan??? One_*_Star 89-95 Toyota Pickup/Hilux 3 12-10-2005 12:24 AM
Installing Electric Fan In 93 V6 Xle bigghek Gen 3 & 4 10 11-20-2005 03:57 PM
anyone complete a stand alone fog mod for the 04 camry van48 Gen 5 & 6 11 10-23-2004 01:04 AM
MK3: electric fan kit vs. flex fan kit supertoy Supra Forum 4 09-14-2004 04:56 PM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Page generated in 0.18648 seconds with 14 queries
