» Sponsors
» Sponsors
Go Back   Toyota Forums :: Toyota Nation > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > General Camry Discussion
Register Home Forum Active Topics eBay Marketplace Photo Gallery TN Arcade Blogs Mark Forums Read
General Camry Discussion Discussion area for every generation of Toyota's family car, the Toyota Camry. Lexus ES250/300 owners welcome! Topics of discussion range from fuel economy, safety, modifications, performance and more.
Please Visit our Site Sponsors
Thread Tools Display Modes
Old 03-16-2006, 06:36 PM   #1
97camryman
97camryman's Avatar
Trader Rating: (3)
View 97camryman's Photo Gallery
How to make a 4-5 psi wastegate actuator!
OK so I needed a wastegate actuator to build boost fast, hold it and run a base pressure of only 4-5 psi while bolting up to the stock mounts on a toyota CT26 turbo. Tall order? Not so much, here is how I made it work;
1. I used a stock wasegate actuator off an MR2 turbo. I tested it with a boost gauge and found that it wouldnt even begin to move until 8 psi. I want to run 4-5 for safe daily driving. (it can always be turned up). The way a actuator works is it is a can that is sealed in the middle with a diaphragm. As boost enters the top part of the can it pushes down on the diaphragm and moves a rod out to work the wastegate flapper. A spring resists this boost until around 8 psi when the boost pressure is enough to begin compressing the spring and pushing the rod down. I said before that the rod could be extended to lower base pressure and this is true but the problem with that is that the flapper will be opened slightly at the start and that leads to slow spool and that is a bad thing. This way allows for the flapper to be held tightly shut until boost reaches 4-5 pounds so there is no sacrifice in spool time.
This is the beginning part.
2. Begin by removing the rubber seal on the bottom. (three screws) Next, we simply want to cut the bottom off the can as low down as possible and use a hand saw to avoid heating the metal up and damaging the diaphragm. (it does live next to the turbo though so it can take some heat!) I choose a hacksaw blade and chucked it up in the vise, the whole unit is under tension so when the bottom comes off it will really come off! Make sure before you do this you mark a line to show how to line the two halves up again.
3. With the can bottom off the spring comes out and the parts can all be seen. Now we either cut the spring shorter, or find a new softer spring. I choose to cut a coil and a half off teh spring. (eliminating the preload.)
4. I now replace the spring and realign the two halves of teh can with the mark I made earlier. I used my good old arc welder to rejoin the halves. I found that the old 80 amp welder lworked perfect with 3016 electrodes.
I cleaned the metal up with a grinder, tacked one side, tacked the other, then removed the clamps. With the clamps off I cleaned all around the cut with the grinder and welded the seam shut with a thinner electrode again.
5. Going slowly with the welding so as not to melt the diaphragm I finished in about 1/2 an hour. Let it cool awhile and then clean up the welds with a grinder. I just ground the welds down flush with the rest of the can and used sandpaper to clean up the rest of the can so I can repaint it later.
6. Here is the finished actuator:
Post test results show that the actuator now holds the flapper shut tight with a little preload but begins opening right at 4.5 psi and is fully open at 9 psi. If I ever want to raise that pressure all I need is a boost controller now. (4-5 pounds is fine for now IMHO)
Home Page: http://www.cardomain.com/memberpage/506928/1
5S-FE Turbocharged @8psi with 5-speed auto to manual swap
97camryman is offline   Reply With Quote
Old 03-16-2006, 08:38 PM   #2
2wickedtoyz
Mad Scientist
2wickedtoyz's Avatar
Trader Rating: (7)
View 2wickedtoyz's Photo Gallery
nice mod i got 2 of those here i'm going to try that
Originally Posted by BLUEMEANIE View Post
Fortune cookie wisdom: He who is continuously a noob at something new is far wiser than he who is expert at only one thing.
PM me if interested in an exhaust setup like mine
2wickedtoyz is offline   Reply With Quote
Old 03-16-2006, 09:03 PM   #3
Hamsterman
spin turbo hammy... SPIN!
Hamsterman's Avatar
Trader Rating: (30)
View Hamsterman's Photo Gallery
finally - now there should be less questions on the subject
good writeup buddy
I feel the love - and it feels like cheese
Hamsterman is offline   Reply With Quote
Old 03-16-2006, 11:45 PM   #4
BlueFusion6851
BlueFusion6851's Avatar
Trader Rating: (3)
View BlueFusion6851's Photo Gallery
That's awesome.
DIY projects that improve stock items rule!
1993 V6 XLE Camry- totalled 10-17-08
Pontiac G6 GT: Daily Beater/Pizza Delivery Vehicle
Infiniti I35: Mod Queen.
BlueFusion6851 is offline   Reply With Quote
Old 03-17-2006, 03:12 AM   #5
project92camry
eSe3
project92camry's Avatar
Trader Rating: (0)
View project92camry's Photo Gallery
great step by step project!
ill use this when i get my ct-26
project92camry is offline   Reply With Quote
Old 03-17-2006, 06:04 AM   #6
RedPhoenix
Lex Zues!
RedPhoenix's Avatar
Trader Rating: (12)
View RedPhoenix's Photo Gallery
thats geat!good info
SC400 - 5sp Swapped > SSR, Bilstein/Hypercoil Coilovers, Supra TT Brakes, Blitz Nur Spec, JDMness, Polarg, E46 Retrofit, Optima
www.MySoarer.com <---Click!
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 03-25-2006, 07:41 PM   #7
The Car Newbie
Trader Rating: (0)
View The Car Newbie's Photo Gallery
why would u want to reduce the boost pressure.
The Car Newbie is offline   Reply With Quote
Old 03-27-2006, 03:59 PM   #8
97camryman
97camryman's Avatar
Trader Rating: (3)
So the rods dont bend, pistons dont lose ringlands, no holes in pistons, no screwed up cylinder walls, blown headgaskets, holes in the block, blown rings, detonation, preignition, knocking, things like that. It has been proven time and time again that running high boost numbers on stock internals results in messed up motors. Since I cannot do anything with my timing it becomes even more essential to me to be able to keep base boost pressures down. Besides you can alwasy raise it back up with a boost controller.
Old 04-17-2006, 07:22 AM   #9
caliboy
Trader Rating: (0)
View caliboy's Photo Gallery
Excellent instructions mate.Just wanna know if I can do the samet to the turbo in GTT Caldina.I think stock is 7psi now,how low can I go?How should I know how much spring to cut to get a certain pressure?
caliboy is offline   Reply With Quote
vB code is On
Forum Jump
Similar Threads
5s-fe turbo install list R94CamryT Hardcore Tech and Competition 32 04-29-2009 02:37 AM
Custom sc for 4agze bsee Archived Corolla threads 21 08-31-2007 02:31 AM
DIY Cold-Air Intake bondobondo Hardcore Tech and Competition 40 11-24-2004 02:41 PM
15 psi phishmale MR2 Forum 7 10-04-2004 03:35 PM
Hyde's takes 2nd in first SCCA Solo1 Hill Climb Event running 23.2 PSI of boost! JekylandHyde MR2 Forum 11 06-30-2004 12:51 PM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Page generated in 0.13131 seconds with 14 queries
