| Register | Home | Forum | Active Topics | eBay Marketplace | Photo Gallery | Blogs | Mark Forums Read |
| Detailing & Car Care Discuss detailing techniques and products for your Toyota here! |
Thread Tools | Display Modes |
#1 |
Surfing TN via iPhone
Gameroom cash: $3300
Trader Rating: (15)
Detailing your vehicle (Exterior)
Washing If there is a single maintenance that offers the biggest benefit to your car's appearance, it's keeping your vehicle clean through regular washing. Washing is the process of removing loose dirt and road film on the top of your car's paint surfaces. That means more than just a good hosing. You have to scrub it with shampoo and a sponge or wash mitt. Which is why I don't visit carwashes much, unless I take my own mitt. Washing can be a double-edge sword, though, as even the mildest soaps can remove the protection from your car's paint, causing oxidation (paint starvation). Detergents can dull your car's finish even faster. A good car wash shampoo should be very gentle on paint, plastic and rubber. Don't use dish washing soap unless you are trying to strip your wax job (Dawn is good for this). A good car wash shampoo provides lubrication to prevent scratching and conditioners to maintain the shine. Be sure to select a quality product that's not counterproductive to your detailing efforts. I'm currently using Adam's car wash. I spray it on with a A towel is a towel, right? Unfortunately, this is not correct. If you grew up in a house like mine, Mom retired the old bath towels to the garage for car and dog duty. What Mom didn't realize is that most bath towels use a backing material that contains heavy polyester thread. The edges of the towel are stitched with polyester thread, too. Pound for pound, polyester is stronger than steel. This is great for long-lasting bath towels, but it's not so good for your Taco's paint. Traditional polyester and polyester blend thread scratches automotive paint finishes. Use paint-safe microfiber towels, like the Adam's Waffle Weave drying towel. Your choice of wash tools is important, too. You should find a wash tool that is comfortable for you to use, but take a few things into consideration. First, your wash tool should hold a lot of soapy water. The more it holds, the more soapy water you can get on your Taco. This is important for lubrication. The lubrication created by soapy water is what prevents dirt from scratching your paint. Use a wash tool that cleans easily, too. If it does not easily release dirt and grit, it's not safe. I like wash tools with a lot of fibers, like a lambs wool mitt, wash pad, or a grout sponge (Lowe's has a good grout sponge). My favorite wash mitt is available at Griot'sGarage.com Griots Sheepskin mitt. Contrary to many beliefs, the natural sea sponge and the boar's hair brush are not good wash tools. Modern wash tools make these items relics things of the past. A paint safe wash brush can be used on the lower body panels, but should not be used above the bottom-of-the-door line. The recent popularity of microfiber has created a large number of microfiber products, including microfiber wash mitts. Personally, I only use microfiber for drying and buffing, not as a wash mitt. I think it holds too much dirt for washing. For drying, a combination of tools may be necessary. The sheepskin chamois have been used for centuries as a towel for drying. This naturally soft leather is very absorbent. All-natural chamois are still a good choice, but they are not as effective or as easy to use as a quality MF drying towel. If you like to dry in a hurry, there are paint-safe squeegies available that will quickly remove 80% of the water from your vehicle with just a few strokes. Follow up with a good towel, and you're done. If you use a paint-safe squeegee, be careful. It only takes one small dirt particle between the blade and your car to create a scratch. Personally, I don't like to use paint squeegies. I have recently changed a few methods to my vehicle washing steps. I now wash the tires and wheels first. If you wash the body first, the water will dry and spot your vehicle before you can finish washing the tires and wheels. Do not use the same wash water on your car's paint as you do your tires and wheels. Throw it out and refill your bucket. Brake dust is metal, and it will leave swirls in your paint if there is brake dust in your mitt or sponge. If it's a cool or overcast day you might be able to get away with washing the wheels last, and not getting any water spots on the body.If possible, work in the shade. A hot surface causes the wash and rinse water to evaporate too quickly, increasing the likelihood of water spotting. One trick is to park on a slight incline. This allows rinse water to run off moldings, trim, and recessed areas better. If you have to work in the sun, work fast and keep the car wet by rinsing often. Start by thoroughly wetting the vehicles finish with a semi-strong spray of water to remove mud, loose grit, and surface dirt. This might be a good time to mention: Take it easy with the powered pressure washers. Except for the wheel wells and undercarriage, I wouldn't use a pressure washer on my vehicle, especially since these newer Tacos seem to have soft paint.Put some shampoo in a bucket. I use a 2 gallon bucket. Then fill 'er up, and try to keep the foam in the bucket or on you mitt. The foam has a lot of lubrication in it. Start washing from the top down and rinse often. I use a small step ladder to reach the roof.ou Never go from the bottom of the truck back up to the top, unless you rinse out your mitt. Frequent rinsing of the body is especially important if you are using a shampoo containing natural oils. While these oils cushion the paint and minimize abrasion they are heavier than water and can leave a film if allowed to sit on the paint. I do a final rinse of free-flowing water, which gives a sheeting action and will reduce water spots. I use an Adam's firemans nozzle. It makes a real difference over regular pistol grip nozzles. There is a lot more control and pressure adjustment. If you have low water pressure at your house, you really should get one of these "firefighter" style nozzles. As the final washing step, You can greatly reduce the amount of water left on your paint by taking the nozzle off of your hose and run some low pressure water over the paint, and let the water gently sheet off. Drying Dry off in the shade if possible. I use a gas leaf blower to knock off a lot of the water and get it out of the nooks and crannies. This will make towel drying go a lot faster. Using a clean waffle weave drying towel or chamois, start at the top of your vehicle and work down, drawing the towel or chamois across the surface in a straight line. If using a natural chamois, use the rough side to dry.Use a terry detailing towel to dry your tires and wheels. Do not use your chamois or good microfiber towels on the tires and wheels, as it will become soiled. Open the doors and dry the door sills and jambs. Wipe under the door and along the door edge, as well. Dry off any tube steps or running boards too. If you ignore these areas you will get water drops streaming down the side of your vehicle when you start driving.Open the hood and wipe down the jams and seals. On the engine, use your damp towel to remove dirt the top of the engine cover and engine compartment surfaces. After working in the engine compartment, put the dirty towel in the wash and don't use it on your vehicle again until you wash it. ![]()
| Sponsored Links | |
Advertisement |
#2 |
CARDS RULE
Gameroom cash: $1500
Trader Rating: (0)
Its here!! Its here!!! All bow down to Pb the Great One!!!!!!!!!!!!
Silver Double Cab, 4x4, TRD Sport K&N/AEM Hybrid Intake Magnaflow Exhaust Split Second PSC1 |
#3 |
Trader Rating: (15)
Polishing
Many people assume that waxing and polishing are synonymous. In fact, they are two different processes. All paints age from exposure to ultraviolet light, pollution and acid rain. Beautiful finishes gradually become dull and chalky. Waxing over these surfaces will only create a temporary gloss over dull paint. To reveal the paint's true vitality, vibrancy, and depth, it must be polished. On newer vehicles polishing might not be real necessary right away. For your first detail job you might want to just use a clay bar to clean the paint. I'll talk about that later. On my Taco I use polish mostly for removing any scratches or swirls. It doesn't need to be a regular practice before waxing. I only give my truck a full polish maybe twice a year. Having a good washing technique will cut down on the damage you inflict on your paint. Most swirls comes from bad washing and drying techniques and equipment. You don't want to get too agressive with the polishing. Because when you are polishing you are actually sanding down the paint a micrometer at a time. It is possible for polish to "sand" down through your clear coat or even the base coat but generally, polishing just deep-cleans the paint and creates a uniform, high-gloss shine. If you polish with an orbital buffer then you don't have much to worry about. Orbitals are very easy on the paint. Rotary buffers are a lot more agressive. Selecting a polish can be intimidating. There are hundreds to choose from, each having different abrasive or cut capability. There are polishes for clear coat and non-clear coat finishes. I find that our vendor, Adam's Polishes, carries a good line of polishes that should cover your needs. You will also need to choose the correct product for hand application or machine application. You'll see faster results with a buffer. Work in a shaded area, out of direct sunlight. If it's impossible for you to get out of the sun then you should try to work in the early morning or evening when the sun is not as intense. Work on one area at a time covering two to four square feet. Once you are familiar with your polish, you can try larger areas. I never do more than half my hood at a time. Work the polish until it starts to disappear or get dusty. Buff off the polish residues as you go. This allows you to discover any problems early before polishing the entire truck. If the polishing residue does not buff off easily, switch to a clean buffing towel. You can also spray the area with a quick detail spray to moisten it up and it should come off. Apply polishes in a back and forth motion, not circular (polishes should take out swirls, not create them… don't polish in circles). If you are creating swirls, you are using a polish that is too abrasive or you need to replace your polishing pad or towels. An orbital buffer does not spin, like you might be thinking. It actually just moves side to side when you apply it to the paint. When you lift it off the paint it will spin, but it shouldn't really spin as you are polishing the paint. Generally, polishing is harder than waxing. It is harder to work and harder to remove. If you are not familiar with polishing or using a buffer, then you might just want to wax your paint the first time to get the feel of it. Then you can polish it later. ![]()
#4 |
Trader Rating: (15)
Claying
I should have put this info right after the Washing/Drying post. You should clay after washing, not after polishing. Watch this video. Clay Bar Paint Saving System and also this Adam's Claying video. When contaminants get a solid grip on your vehicles paint, washing alone may not be enough to remove them. Pre-wax cleaners also may not be able to exfoliate large particles. In this case, you have two choices: use a polishing compound, which removes a lot of paint material, or use a clay bar. Clay isn't a polish or a compound, it is a surface preparation bar that smoothes the paint and exfoliates contaminants. Automotive paint cleaning clay offers many advantages in the removal of surface contamination from paint. Even in the hands of a first-time user, clay is safe and easy to use. Sure, if you use a dirty clay bar, scratches can result. However, compared to machine buffing, compounding, or using harsh chemicals, clay is safer, faster and easier. I like Adam's clay because it's big and easy to hold. You can actually cut it in half and just 4 ounces at a time. AutoZone sells Meguiars and Mother's clay kits, but their clay bars are pretty small. Clay is not a cure-all or a replacement for polishing. It's a tool for quickly and easily removing surface contamination. The clay bar will not last forever. As you use it, it will get full of contaminants. It's up to you when you throw it away. I might do a full clay job 5 times before I throw it away. But if you are claying an older vehicle you might get less life out of the clay. When I can no longer remold clay to get a clean surface, I retire it for use on my windows. The dirty clay will not harm glass, and it's amazing how much dirt film clay can remove from your exterior glass windows. It works very well, and seems to outperform even the best window cleaners. BTW, my favorite window cleaners are Adam's, Megs NXT, or Stoners window cleaner. One of the main reasons for using clay is the removal of brake dust. Brake dust is a metallic surface contaminant that can be removed safely and effectively by using clay. Clay will also remove tree sap, paint overspray, and tar. On thick tar I will use a gentle solvent like bug and tar remover or Goo Gone. Don't drop the clay on the ground. You don't want to pick up any dirt or gravel. If the clay is sticking or not sliding easy, then you need to spray more lubricant. Be liberal with the lubricant. It doesn't hurt if it runs down the paint. The lubricant might leave a hazy film, which is just a light wax, but it is easily removed. I don't even worry about it. I go from claying straight to polishing or waxing. You can also use soapy water if you run out of spray lubricant. ![]()
#5 |
CARDS RULE
Trader Rating: (0)
Awesome dude!! Just what I was looking for!!!
#6 |
Trader Rating: (15)
Now the fun stuff.
Waxing A brief history. ![]() It was European coach builders that first applied coatings of animal fats and wax to protect the custom paint on their horse-drawn carriages. This tradition has endured over 100 years and is still a great way to protect the paint on modern-day coaches. Today, the multilayered finish on your Taco, from the primer through the top clearcoat, is only .004 to .006 of an inch thick. Radiant and ultraviolet energy, acid rain, salt, atmospheric pollution, insects and bird droppings wage a constant war on your vehicles finish. Waxing provides an easily renewable, transparent barrier between the finish and a hostile environment. Quality waxes now combine enriching oils that "wet" the surface with protective formulas of Brazilian carnauba or modern polymers for a high-gloss shine. Waxes can be made from a natural wax, usually Brazilian carnauba, or synthetically made of polymers and acrylic resins. Carnauba Many enthusiasts and show car owners prefer the shine of carnauba waxes, especially on black, blue and other dark colors. Carnauba waxes bead water nicely, absorb the acid content in rain, and hide minor swirls in the paint. Our Vendor, Adam's Polishes, makes a nice rich , buttery Carnauba Wax, and it also has some synthetic wax in it, to make it more durable. Generally, Carnauba waxes are not as durable as synthetic waxes or sealants. Depending on your climate, a carnauba wax might last between 30 and 60 days. Additionally, some carnauba waxes can be temperamental, occasionally streaking under certain temperature or humidity conditions. With the limitations of carnauba wax, you might be asking why it continues to have a loyal following. On dark colored paint carnauba just has a nice deep shine that's hard to beat, especially if you have a show car, or don't mind waxing a little more often. Synthetic To make a true wax coating more durable, some chemists have turned to synthetic waxes that mimic the valued properties of natural carnauba, but greatly improve on the limitations. Most people judge how much wax is on their paint by how well the water beads up, but be aware that some synthetics don't create a beading action when they get wet. Some waxes have a sheeting action. A heavier duty version of synthetic wax is a resin sealant. The king of acrylic resin sealants is Klasse. The Klasse products include a cleaner and sealant in one, called Klasse All-In-One and a pure sealant called Klasse Sealant Glaze. Klasse All-In-One is a one-step product that gently cleans and polishes your paint as it protects with the patented Klasse acrylic formula. A single coat of Klasse All-In-One provides 4-6 months of protection. For even more protection and paint finish beauty, you can add one or more coats of Klasse Sealant Glaze, which does not contain cleaners or polish. Klasse Sealant Glaze is pure acrylic resin. Application Work in a shaded area out of direct sunlight. I use a soft foam pad on my buffer to apply wax. But wax is just as easy to apply by hand. I just use a buffer for a more uniform application. Then I use a small hand held foam applicator to get the wax into all the nooks and crannies, like around the door handles, antenna, fog light holes, etc. When the applicator becomes caked with wax, switch to a fresh applicator. Most people apply wax too thick. Doing this won't add any extra protection. Also, Applying it thin make it easier to remove. If the wax is hard to remove moisten it up with a spritz of quick detail spray. Follow the wax manufacturer's instructions on whether or not to allow the wax to dry (haze) before buffing. Apply your wax in a back-and-forth motion, not in circles. I follow the lines of the body front to back. This way you won't leave any swirls. If you leave any fine lines or micro-scratches they will be straight lines and less noticeable than if you made circular swirls or micro-scratches. Use this same method for removing the wax. I use a good microfiber buffing towel. I like these. I then use a soft brush like this to get any wax out of cracks and emblems. What do you do if, after all this work, you still have streaks and areas that don't want to buff out perfectly? This can often happen on older paint. There are several tricks, but the easiest is to park your Taco in the sun for 10 to 15 minutes. Let it get warm, but not hot, and then take it back inside the garage. Next, using a good spray bottle and distilled water, spritz a small area and buff with a clean terry cloth towel. If you don't have distilled water, use a detailing spray. If you're using a sealant system (like Zaino), use the quick detailer made for the system. Adding multiple layers of wax is a subjective matter, although many concours winners use multiple layers to produce the desired depth. For some added gloss after a wax job, I will spritz the panels of my Taco with a quick detailer or Spray Glaze and spread the moisture around and buff it with my softest towel until it's perfect. This added moisture can add even more depth, and it only takes an extra 15 minutes. I will also do this once a week (weather permitting) to rejuvinate the wax and de-dust the paint. I would recommend waxing your vehicle at least twice a year. Personally, I do mine at least once a season. Sometimes I do it a few times during summer, as the hot sun will increase the speed at which the wax "evaporates". I would at least give your Taco a real work-over after Winter is over. There are many different brands of wax that people say they use, and that's fine. Use whatever you want if it works good for ya. I have used lots of different products, including wax that is over $100 for 6 ounces. I'm just telling you what works for me. ![]()
#7 |
Trader Rating: (15)
Quick Detail
If you want to keep your vehicle clean, but don't have time to wash it every time it gets dusty, then all you need is about 10 minutes to quick detail your vehicle. Rinse a microfiber towel thoroughly and wring out as much water as possible. Fold the towel in half, then in half again. Starting at the top, wipe down your vehicle, wiping in a single direction only. As the surface of the towel gets soiled, flip it to a clean side. When all sides of the towel are dirty, rinse it out in the bucket, wring and keep wiping. Don’t forget the windows. When the loose dirt is gone, rinse the towel again, wring out all excess water, refold, and spray the towel with a few shots of detailing spray. Wipe the Taco down with the detailing spray, giving a couple of shots into the towel for each panel. Use a quick detailer. Don't mess with spray on wax. I like Adam's Detail Spray. It's easy to wipe on and wipe off. Some other detail sprays can leave streaks and require more buffing to remove. Buff the quick detailer immediately with a clean, dry towel. I recommend a second microfiber detailing towel. Spraying the towel instead of the vehicle will ensure better distribution and will use less product. As the final step, do your wheels. If your wheels are fairly clean, simply wipe them down with the damp microfiber towel. Rinse the towel for each wheel. If your wheels have heavy brake dust, give them a couple of shots of detailing spray and let it sit for a minute. Then wipe off as usual. I use Eagle One All Wheel & Tire cleaner or Adam's All Purpose cleaner. If you wash your vehicle at least every couple weeks you shouldn't have to use any strong chemical cleaners or acids.
#8 |
Trader Rating: (15)
Swirls & Water Spots
I get a lot of questions from TN'ers regarding water spots and swirl marks. Water spots and swirl marks are different problems, but most often the solution is the same: polish the paint. Water Spots The same water you use to clean your vehicle can also damage your vehicle paint. The spots and damage are caused by the minerals in the water. When water evaporates off of your vehicle paint, it leaves behind the trace elements it contains. Calcium and metals are the most damaging elements found in your tap water, whereas rainwater may contain damaging acids from air pollutants. Avoiding water spots is easy if you chase after them. The best solution is to use a quick detailing spray after you wash, or as soon as you discover the spots. You can first try Claying, but sometimes even clay won't do the job. If the spots are allowed to dry and bake on, they will attach to and harden on your paint. When this happens, you need to use a mild acid to get them loose. Believe it or not, the best acid is also the least expensive and most available: a gallon jug of distilled white vinegar. Expert car detailers have known this secret for years. If you take your car to a pro, they will tell you about the "magic acid bath" and charge you $60 or more for the pleasure of smelling like a pickle. Save the $60, put on some gloves, and do it yourself. Just get the cheap vinegar. No need to get the scented kind.To give your vehicle the magic acid bath, first wash your Taco with your normal car shampoo, rinse, then use the distilled vinegar. Just wipe it on with a sponge, and rub it in. Do one section at a time, let it sit 30 to 60 seconds, then rinse. When you're done, wash the car again with shampoo and rinse. By the way, vinegar will remove your wax. So, be prepared to re-wax your car after the vinegar treatment. If water spots are allowed to stay for more than a week or so, the minerals can etch the paint. In this case, using vinegar will remove the mineral spots, but the paint will have etched spots (dimples). In this case, it is necessary to use a medium cut polish. Then you can use a fine cut polish to restore the paint surface to a real high gloss. Swirls Incorrect use of a buffer or polisher can be a leading cause, but it's not the only cause of swirl marks. Every time you wash or wipe down your vehicles paint you create micro-marring. The severity of the micro-marring depends on your tools and the contaminants present. IMO, here are the ten most frequent causes of micro-marring (swirl marks):
![]() Swirl marks can be removed by polishing. Polishing out swirl marks without a buffer is a lot of work. I recommend polishing your Taco one small section at a time so you can see the progress. To remove swirl marks, use a good medium cut polish. If you have some real neglected paint or scratches then you might need to step up to a more agressive polish. Basically: To keep water spots to a minimum, try using a detailing spray after you wash. I also will spray some quick detailer in the bucket to add some extra lubrication to the soap. Lubrication is the key to reducing microscratches and marring. Keep your vehicle in the shade, and dry it off ASAP. To keep swirl marks to a minimum, make sure you have good wash and dry tools. Never wipe, rub or polish in circles (straight line motions only), and be very careful when you use buffers and polishers. If you have repair work done on your vehicle, tell the painter you want a warranty against swirl marks. This lets them know you're clued in to a quality job. Regular polishing is the best way to remove water spots and swirl marks. Choose a good polish, good tools, and be patient. ![]()
#9 |
Trader Rating: (15)
Using a buffer
I will focus mainly on the use of the Porter Cable 7424 because it is what I use most of the time, and it's a very popular buffer. A rotary buffer can produce results faster, but you have to be much more careful with a rotary buffer. Only an experienced detailer should try using a big rotary. The Porter Cable (PC) 7424 started life over a decade ago as a sander for woodworkers. With the introduction of foam buffing pads into the woodworker industry in the early 1990’s, you see how the PC 7424 came into use on car finishes. Porter Cable did not design and does not market their 7424 for use on automobile finishes. So, why is the PC 7424 so popular as a car buffer? I'll explain. ![]() The term random orbit refers to the action of the tool’s head. Unlike a rotary buffer, that spins at variable speed on a stationary spindle, a random orbit machine operates by spinning the head (free-spinning) on a center spindle and running this spindle around an eccentric offset. This offset is what makes it go side to side. The side to side movement is a generous 15/16". Here's a good example of what the PC can do when used with a good polish and pad. ![]() Imagine being able to make 2,500 to 6,000 tight hand circles in a single minute and you’ll have a pretty good idea of how the PC 7424 does its job. It works just like your hand, only at Superman speed! ![]() This is the PC 7424 with a backing plate and some various pads. ![]() I use 6" pads for light polishing and waxing. For repairing swirls or scratches I'll switch to a 4" backing plate and pad. The smaller pad gives you more control and concentration on the area. Pads must be matched to an appropriate polish to achieve the desired results. Don’t try to use a fine hand polish with a cutting pad to remove heavy oxidation or swirl marks. It simply won’t work. Depending on which brand of pads you use, the color of the pad will represent the stiffness of the pad. Use a stiffer pad for polishing, and soft pad for waxing. Using the PC Your vehicle must be freshly washed and dry. Do not buff on a dirty finish. ![]() Work in an area with good lighting. Overhead fluorescent or halogen lighting is best. They will make imperfections show up better. Remove all jewelry, belts and other items that will scratch your paint. And watch for buttons too. The PC has a variable speed, which has a control on the back that is numbered 1 through 6. Speeds 3 or 4 is a good starting point. With the PC Off, apply a small amount of polish, cleaner or wax directly to the polishing pad. There are two good methods that seem to work for me. Squeeze out a complete ring of product about 1 inch in from the outside of the pad, or squeeze out an “X” of product across the pad. Dab the pad in 3-4 spots around the area to be polished, cleaned or waxed to distribute the product. This way it won't sling the polish when you start. Put the PC flat on the work surface (I usually start with the hood and then go to the roof and then the doors and then the bed) Get a firm grip and switch it On with your thumb. Move the PC back and forth in a slow, sweeping motion, overlapping each pass (by 50% of the pad width) with the previous, and then switch your pattern to up and down. I don't always follow this rule, but you might want to while you are getting used to the PC. It's not necessary to apply more than a pound of pad pressure. Allow the polisher to work under its own weight. Sometimes I will add a little more pressure to help get out a scratch, but it depends what polish I'm using. Then I usually remove the polish or wax by hand. But you can also remove it with the buffer by putting a soft bonnet over a dry clean pad. Still using speeds 3 or 4. Be sure to always have the buffer head on the paint surface when you turn it On, otherwise the head wobbles all over the place and scares the poo out of ya. A few tips If you wax over bad paint, it’s still bad paint. When you polish bad paint (paint with scratches, heavy oxidation, swirl marks, stains, water spots, etc.), you remove the bad paint to reveal a fresh finish. Obviously you can only do so much polishing before you wear out (thin or completely remove) the paint, so only polish as much as necessary to maintain healthy paint. But don't get scared; it would take a lot of polishing to actually get through the clear coat of most vehicles. You would have to sit the PC in one area for like 30 minutes to wear it down. Buffing pad and polish makers create products with different levels of aggressiveness to make the job faster and easier. You can use an aggressive pad and polish combination to quickly remove paint defects or severe oxidation, but it won’t reveal the full gloss potential of your paint finish. You must use several grades of polish to bring out the final radiance. On newer vehicles it is not necessary to use heavy abrasives, unless you are trying to remove a scratch or a bad bird poo etching. Otherwise, I would only polish my vehicle once a year if there aren't many swirls, and I have maintened good washing techniques. You can use very mild pre-wax cleaners and glazes to maintain finish or create a finish that glows. To do so, use a fine polish and a foam polishing pad, and work the polish in with a light touch until most of the polish residue is gone. Remove the remaining polish residue with a good buffing towel. Fine polishes won’t take a lot of heat before they cake up and clog your pad, so don’t apply pressure to the machine. Allow the pad and polish to do the work. ![]() Apply polish to pad ![]() Spread it out ![]() Start at low speed ![]() Increase speed and work it in ![]() Polish until film is nearly gone or gets dusty ![]() Switch to a finishing pad or bonnet if you want ![]() ![]() Buff clean with a detailing spray and towel ![]() How to apply paste wax to a soft buffing pad ![]() ![]() When applying wax use a slower speed like 2 or 3. You don't really need to "work" wax. You just apply it. ![]() Here's some examples of what can be fixed with a buffer and polish. ![]() ![]() ![]() ![]() ![]() A few more tips Some people believe that polish should be used sparingly. Doing so puts more of the workload on the pad and causes the polish to dry out before you achieve any work. Use polish liberally. Apply enough polish to work an area for one to two minutes before the polish hazes and begins to buff out. To keep a big glob of polish from going down into a door jamb, start out in the middle of the body panel and then as the polish thins out work your way over to the edges of the body panel.Polish safely by keeping the pad flat on the surface you’re buffing and the cord off of the paint. I like wrapping the cord around my wrist once and draping the rest over my shoulder. You’ll have to find a method that works for you. The handle on the side of the PC is removeable. Sometimes I use it and sometimes I don't. The handle seems to help when working on the lower parts of my Taco. Polish with the pad flat on the surface. If you tilt the polisher, you risk excessive heat build-up, pad destruction, and potential damage to trim. And also swirls. Unlike a rotary buffer, which is capable of applying energy to the edge of the buffing pad by tilting the buffer a few degrees, a dual-action polisher is not able to really focus polishing action. Tilting your PC 7424 will quickly destroy foam pads (it causes the backing plate to cut into the pad) and may build-up enough heat with a rubbing compound and cutting pad to burn paint. Just keep it flat then there's nothing to worry about. ![]() I like to 'prime' a fresh, clean pad with a shot or two of detailing spray. This makes the initial buffing a little smoother. Just use a light mist. When you are done with the PC you can just store your pads in a big ZipLoc if they aren't that dirty. If they are dirty then you can wash them by hand. It's usually not recommended by the manufacturer, but I usually put them in the washing machine on the gentle cycle on Hot and use Woolite. Then afterward let them air dry. My pads still look like new, except for a little staining, which doesn't hurt anything. While the PC 7424 is a very easy polisher to master, practicing on an older car with an imperfect finish is the best way to learn. You should experiment with a variety of polish and pad combinations until you learn how to get the best results. Don’t get frustrated if your first experience is not perfect. The smallest change (a different pad, polish or speed) can make a huge difference. Wheeeewww. I think that's it. ![]()
#10 |
CARDS RULE
Trader Rating: (0)
Many thanks Pb, this is going to be a big help to alot of people!!!!
#11 |
My name is Blake
Trader Rating: (1)
OMG. I am in love.
PB I U.
#12 |
God Bless!
Trader Rating: (1)
Wow! I thought I was doing pretty good with my weekly trips to the local car wash (not the swirl-o-matics..the ones with the pressure washer. I have to rethink my routine of rinse, rinse with soap, rinse, spot free rinse, drive around to dry, park and dry with 100% cloth. I wax every 2 or 3 weeks with Meguiars Gold Coast wax. Pb, do you think my approach is flawed? I never use the brush at those places.
#13 | |
My name is Blake
Trader Rating: (1)
I also tried using it on the rest of the truck and it did nothing. They use dirty water I think!!! I DID find success in the brush. I used that to clean my tires and wheels and it worked nicely. Those places suck. Nothing better than a 100% hand wash at home.
#14 | |
CARDS RULE
Trader Rating: (0)
#15 |
Don't mess with the Blue
Trader Rating: (1)
WOW, this sure will be useful for everyone. Thanks so much PB. When is it going into the Sticky? Great job on the write up.
![]() 2006 SpeedwayBlue Tacoma TRD Sport
| Sponsored Links | |
Advertisement |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| let my GF drive my taco... | NESW20 | 2005+ Tacoma General | 83 | 01-16-2008 08:07 AM |
| Detailing your vehicle (Interior) | Pb | Detailing & Car Care | 51 | 02-03-2007 07:28 PM |
| Newbie Dilemma (Get Taco or Keep 4RNR) | Ogie | 2005+ Tacoma General | 24 | 12-05-2005 03:57 PM |
| Newbie. & Lucker. 05 Toy Taco questions. | Oiler | 2005+ Tacoma General | 6 | 03-25-2005 09:47 AM |
| Detailing Shop | BenG | Feedback: Buyers, Sellers, and Vendors | 4 | 04-30-2003 11:42 PM |
