sometimes i hear a high pitch squeal from behind the the dashboard, it happened 3 times in one year and happens usually when i go 0-70mph and it's VERY windy outside
to me seems more like an alarm/chime coming from the dashborad whereas my wife says it's just air being funneled around the windsheild and making noise. I don't think she is right the noise is from inside! Plus, when the squeal appears i also have a strong pull-to-the left sensation on the stearing wheel which could be dangerous i think....what the hell is it? is there some sort of sensor that is telling me i am going too fast on a very windy day????
i appreciate any feedback
I have the same issue....
2005 S
I know when they put in the alarm system, they opened one of the rubber boots.
And that seems like the place I hear the whistle...
sounds like you are describing wind noise. It could be from either the windshield not being sealed well or like someone else stated it could be from a rubber plug missing in the firewall. The firewall is the back wall of the engine bay. look around there for any holes that may not be lugged up. Has the window ever been replaced for any reason.
as for the pulling that ishard to say. It is most likely jsut the wind pushing the car across the road on windy days. If you think yours is bad you should drive a Sienna in the ind. We had 20 mph steady winds yesterday with gusts up to the 30's and it was loads of fun in my van.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
but the high pitch noise and the pulling to the left occur at the same time and as a sudden 3 sec long event, it's not a gradual thing growing with speed.
As i said, is as if someone had pressed an alarm button for a few sec and moved my stearing wheel to the left
then if i slow down things go back to normality.
I will look at the firewall anyway.
I do know that the underneath engine plastic cover is loose and some plastic snap-on lockers are missing, could that be it?
sorta grabbing at straws trying to diagnose over the internet. But maybe you ahve a problem with brakes dragging. or a wheel bearing going out and there is a certain spot that it grabs. I would be more inclined to think brakes than wheel bearing because normally with a wheel bearing you get more of a grinding/groaning sound, plus it should be a constant noise instead of intermittent like you are explaining. The cover wouldnt have anything to do with, or it shouldnt because it is not anything structural or driveability related. It is more to keep debris from entering the engine compartment.
My 94 Corolla does the same thing. It's just high wind gusts blowing a light car....although mine does get blown more than a newer one would because it's lighter. I have also heard the whistling noise coincide with a strong pull when the wind hits just right.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
If you have had your windshield changed at all, or if its ever been changed, its possible wind noise could result from that. I work for a auto glass shop, and atleast my store if you come in with a problem like that we will take a look at it and see if we can find any gaps in the glue... Alot of times if there is an air bubble or anything in the urethane, even a pin prick, it can cause air leaks
My girlfriend's 2005s does the same thing. I always thought it was just a small defect in the rolla due to cost cutting measures since its not a luxury vehicle or anything and the noise wasn't hurting the car.
I will now check for any gaps in the firewall and see if plugging it up solves the problem. But the thing is, it happens every now and then because in order for the problem to show up, I have to be traveling at a pretty high rate of speed as well as it being very windy outside.
Her windshield has never been changed so I guess I can rule that out but who knows there could be a crack in the seal. Can't hurt to look.
07 I4 LE (fully unloaded except for free mats and cargo net!)
Personal add ons: alarm w/remote start, XLE Grill, Lip Spoiler, OEM Sport Pedals
93 SlowRolla (Speed Isn't Everything...ah who am I kidding?)
my 05 rolla Xrs does the same thing. I fisrt thought it was from my windshield not being sealed as it has taken quite a few rock chips; but now I am thinking it might be when I brought the power cable for my amp through the firewall... hmmm... I ran it beside the ac line as I didn't want to drill a new hole through my firewall.
I have a 2005 corolla CE and have experienced the same problem. Drving into a strong wind, or getting passed by a transport causes this piercing loud squeal coming from the dashboard. we're looking into your suggestions, and will let you know what works.We tried recirculating the air & it didn't work.This is an intermittent problem,it will be hard to find.S
I had the same problem..everytime I drove close to 75 MPH, heard a loud buzzing noise. After arguing with the servicing ppl, finally had them come on a test drive with me.
Apparently, this is a common problem and is due to the windshiled not being sealed right. My corolla is at the dealership as I write this post..they are sealing the windshiled..hopefully, that fixes the problem!
Def a hole in the firewall probably between the brake pedal and the bundle of wires to the lft of it, I just used some strip caulk (didnt use silicone, cant stand the smell) and it all worked out just fine, it was a 05 corolla s for me....
d
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail! http://www.financialfreedomfordummies.com
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
