» Sponsors
» Sponsors
Go Back   Toyota Forums :: Toyota Nation > Toyota Truck, SUV and Van Forums > Toyota Tacoma Forum > 2005+ Tacoma General
Register Home Forum Active Topics eBay Marketplace Photo Gallery TN Arcade Blogs Mark Forums Read
2005+ Tacoma General Discussion area for all the new Toyota Tacoma owners out there!
Please Visit our Site Sponsors
Thread Tools Display Modes
Old 06-17-2006, 04:02 PM   #1
jacksnodgrass
Linux Geek
jacksnodgrass's Avatar
Trader Rating: (0)
View jacksnodgrass's Photo Gallery
Tailgate Alarm
First of all you need an alarm with a wire you can identify that sets off the
alarm when grounded. My 2006 Tacoma came with a 'Gulf States' Security update.
Besides a glass break sensor, I believe the the upgrade added a hood protection
switch too. This is the switch that I tapped into:
This mod just adds a second pin switch / alarm switch onto the same circuit that
the hood switch is on. If EITHER swich becomes grounded ( opens ) the alarm circuit
will trigger.
I bought a "Self Grounding Door Jamb Switch" ( Conduct Tite part# 85932 ) from
Pepboys. I also bought a standard, single throw, 2 pole switch from my local
electronics store. This switch can be used to disable the tailgate alarm. If the
switch is in the 'off' position, the circuit is broken and the pin switch will
never be grounded and set off the alarm. You'd want to do this if you are driving
with your tailgate down or off...
Here are the parts you need: Pin Switch, by-pass switch, nut, bullet connector
and a wire splice adapter. You'll also need 15-20 feet or so of wire.
Start by removing the drivers side tail light assembly. You'll need a 10mm
socket to remove the two bolts ( top and bottom ) that hold in the tail light.
Once the bolts are removed, pull backwards on the tail light and it will come
out. It's held in place by friction. Disconnect the tail light and put it in a
safe place.
Depending on the size of the pin switch you used, drill a hole about an inch
above the bump stop on the tail gate and install the pin switch.
I mounted my by-pass switch in my driver side storage box. I ran a wire from
the pin switch to the by-pass switch and from the by-pass switch to the engine
compartment along the bottom of the frame. Here is a picture of the switch
wired before I installed it in the storage box.
I used my splice adapter to tap into the hood pin alarm inside the engine
compartment.
I zip tied the alarm wire to the frame in several places, re-attached the
tail light and it's good to go.
I verified the operation of the pin switch and the by-pass switch before
I put everything back together.
jack
jacksnodgrass is offline   Reply With Quote
Old 06-17-2006, 09:11 PM   #2
Taco5
"Great White 2"
Taco5's Avatar
Trader Rating: (1)
View Taco5's Photo Gallery
Nice mod! Eventually I'm going to get the power lock for the tailgate.
^Another Sockmonkey Creation^
Proud new owner, 2008 Trail Teams Edition FJ Cruiser
Taco5 is offline   Reply With Quote
Old 06-24-2006, 10:11 PM   #3
cam2Xrunner
cam2Xrunner's Avatar
Trader Rating: (3)
View cam2Xrunner's Photo Gallery
Sweet. Added to the DIY Article sticky.
The ratio of people to cake is too big. - Milton
cam2Xrunner is offline   Reply With Quote
Old 10-20-2006, 01:47 AM   #4
rudy0027
Trader Rating: (0)
View rudy0027's Photo Gallery
did this, but just took out the little black stopper so I didn't need to drill a hole. pin was the same exact size when compressed.
rudy0027 is offline   Reply With Quote
vB code is On
Forum Jump
Similar Threads
1993 MR2 Factory Alarm rcustomrods MR2 Forum 10 04-07-2009 02:14 PM
Taco tailgate...POS arctic_front 2005+ Tacoma General 95 07-23-2006 09:53 AM
tailgate alarm? jacksnodgrass 2005+ Tacoma General 3 06-08-2006 05:56 PM
Non factory alarm draining battery? 03 CE Corolla... Please help latstar Archived Corolla threads 3 01-28-2005 08:11 PM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Page generated in 0.09565 seconds with 14 queries
