» Car Quotes
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Go Back   Toyota Forums :: Toyota Nation > Toyota Truck and SUV Forums > Toyota Tacoma Forum > 2005+ Tacoma General
Register Home Forum Gallery Active Topics TN Arcade Blogs Mark Forums Read
2005+ Tacoma General Discussion area for all the new Toyota Tacoma owners out there!
Thread Tools Display Modes
Old 12-16-2006, 02:31 PM   #1
ncpaladin
Trader Rating: (0)
View ncpaladin's Photo Gallery
05-06 TPMS bypass DIY
Well folks, here's the TPMS bypass some of you have asked about. Hopefully this will help. Sorry if the images are not the best, I took them at full resolution, reduced and moved them from Canon Zoombrowser to My Documents ( where they are about 70K each), then uploaded them to Car Domain so they can be picked up here. I'm no computer expert, but here we go...
Undo bottom of glove box shock from glove box by pinching the post, pull in sides of glove box to get stops past the surrounding dash plastic, then lower glove box more and POP the glove box off its hinge points.
Remove the shock temporarily to get it out of your way.
This picture is of the harness change with the TPMS light in the always off possition.
Here I'm holding the wire that is the output of the TPMS computer, I have put a male crimp here. This wire puts out a ground of just a few ohms when it wants the light out.
Here is the ground lead I've put in, a simple fuse link with a loop connector for the ground lug, and a male connector for the TPMS light connection.
Here you see the female connector attatched to the light lead (About an inch out of the harness), plugged into the TPMS computer lead. This is the factory configuration for the light to function according to the TPMS output.
This is just a pull away shot to give you a better overall view of the area. The wiring is here configured for the light to be off.
This is a close up shot to show you the way the harness should look and the correct wire to cut into. Again, I've cut the wire about an inch out of the harness plug.
Here is the best place to ground the fuse link wire. In case your wondering, I've used a three amp fuse, you can probably get away with much less if you use a glass fuse holder. I've fused the connection for an added safety level. The light gets its power from the instrument cluster, if there were a problem with the light, how much current would go thru it before the cluster fuse blows? I don't care to find out. Better safe than sorry.
Zip tie the harness back in place when you're done, it makes it neater.
This is a picture of a crimping tool and the types of crimps you'll need for the job.
BIG NOTE: I WANT TO STRESS THAT THE TPMS LIGHT WILL BE DISABLED!!! THE TPMS COMPUTER MAY BE COMPLAINING ALL IT WANTS, BUT YOU'LL NOT KNOW ABOUT IT, UNLESS YOU RECONFIGURE THE LEADS TO THE FACTORY SET-UP. IF YOU DON'T PAY ATTENTION TO YOU'RE TIRE PRESSURE ON A REGULAR BASIS, DON'T DO THIS MOD! THE AUTHOR TAKES NO LIABILITY OR RESPONSIBILITY FOR ANY PROBLEMS OR SITUATIONS ARRISING FROM FOLLOWING WHAT I DID TO MY TRUCK.
I can say that I've had no trouble with my truck from doing this mod. When I change the configuration back to factory, it works just fine. The TPMS computer does not seem to communicate to the ECU or anything else for that matter. This mod is now several months in my truck without any issue. BUT I CHECK MY TIRE PRESSURE WITH A QUALITY GUAGE REGULARLY!!! Remember, Uncle Sam thinks you're an incompetent imbicile and he wants you to be safe from yourself more than anything else.
Good luck in all your endevours, Richard.
P.S. Sorry for any grammatical or spelling errors.
ncpaladin is offline   Reply With Quote
Old 12-16-2006, 05:30 PM   #2
TucsonTRD
Official Newb
TucsonTRD's Avatar
Trader Rating: (1)
View TucsonTRD's Photo Gallery
very nice. i got lost at a couple parts. but i'd prolly understand if i got under the dash and looked at everything.
2006 Tacoma DC 4x4 OR, OME 884 Coils, Alcan custom leaf pack, Bilstein 5125's, Cooper Discoverer STT's 265/75R16
TucsonTRD is offline   Reply With Quote
Old 12-16-2006, 07:53 PM   #3
MrSmitty
Twinkle Twinkle
MrSmitty's Avatar
Trader Rating: (0)
View MrSmitty's Photo Gallery
sweeeeeet.. Thanks Richard!!!!!!!!!!
MrSmitty is offline   Reply With Quote
Old 12-16-2006, 10:23 PM   #4
Zman2k2
My search-fu is weak!
Zman2k2's Avatar
Trader Rating: (2)
View Zman2k2's Photo Gallery
1 vote for sticky!
This should help out everyone that has, or wants to add, aftermarket rims to their rigs.
Zman2k2 is offline   Reply With Quote
Old 12-17-2006, 12:10 AM   #5
foofighter
foofighter's Avatar
Trader Rating: (0)
View foofighter's Photo Gallery
great post! very thorough!
www.vip-culture.com
2006 Tacoma | Silver Streak Mica | 4x4 | TRD Sport
foofighter is offline   Reply With Quote
Old 12-17-2006, 06:55 AM   #6
Rodge
Red Headed Slut
Trader Rating: (0)
View Rodge's Photo Gallery
I eventually do this mod one day. I guess when I'm over there under the glove compartment I'll pop the 4x4 harness out and do the 4LO on the go mod as well.
Trail Rig: '85 Pickup - Dual Cases - 5.29s - Rear Spool - 36" Iroks - Internal Cage - 30 Spline Longs
Tow Rig: '06 D-Cab Offroad - She gets me places...
Rodge is offline   Reply With Quote
Old 12-17-2006, 09:11 AM   #7
Pb
Surfing TN via iPhone
Pb's Avatar
Trader Rating: (14)
View Pb's Photo Gallery
Good work. I like a man that uses real crimpers. I've got several Klein crimpers like that.
This is now added to the DIY sticky.
Pb is offline   Reply With Quote
Old 12-17-2006, 11:21 AM   #8
Marc M
Mine is better than yours
Trader Rating: (6)
View Marc M's Photo Gallery
Thomas & Betts crimpers I believe, they are the only thing I use, for stripping as well as crimping.
Marc M
'06 Tacoma Dbl-cab, 4X4, V6, 6-spd, SR5 / TRD Off Road
'05 Corolla XRS 6-Spd
'00 Echo 5-Spd
'90 4Runner SR5 5-Spd - '86 Shortbed 4X4 5-Spd,SAS'd ASAP - '82 Supra 5-Spd
Take your automatic and "Stick" it........
Marc M is offline   Reply With Quote
Old 12-17-2006, 12:40 PM   #9
ncpaladin
Trader Rating: (0)
You're correct, the crimpers in the photo are Thomas & Betts, but I also have a set of Klein crimpers. Way back, when I was a professional car and home A/V installer, I bought these as I can't stand cheap tools. Snap On for everything else.
Old 12-17-2006, 01:52 PM   #10
Pb
Pb's Avatar
Trader Rating: (14)
Yeah, they are great for stripping, once you get the feel for them. I rarely use conventional wire strippers. I get a good discount on Klein stuff through a friend that works at an electronics warehouse. About 50% off retail.
Old 12-18-2006, 04:43 PM   #11
screeber
Ron Jeremy's twin brother
screeber's Avatar
Trader Rating: (6)
View screeber's Photo Gallery
Wow - that's a huge addition to this forum. Nice work paladin. question though:
Is the connector in the background (by your index finger) where you grounded the TPMS wire out of the harness, and then the male connector you are holding is if you wanted to put it back to stock so that the TPMS light would function again?
'06 Tacoma
screeber is offline   Reply With Quote
Old 12-23-2006, 07:32 PM   #12
ncpaladin
Trader Rating: (0)
Yes.
Old 12-23-2006, 11:14 PM   #13
dko-tacoma
dko-tacoma's Avatar
Trader Rating: (0)
View dko-tacoma's Photo Gallery
The low tech method
Hi, just thought I'd chime in with my solution (borrowed from an earlier TN message board contributor) to a constantly lit tpms light.
When I switched my wheels to Ivan Stewart 16x8s, the dealer confirmed what I already knew going in. The sensors would not fit the IS wheels. When I got the truck back, I had a solid TPMS light.
Thanks to a TN forum search, I saw that someone suggested using a handtruck (dolly) wheel from Home Depot to contain the sensors. I went to home depot and found a small 8" wheel for $20. I placed the 4 sensors into the tire and inflated it to 35 psi. The light went out right away. It's been about 2 weeks now and no light. I keep the tire in the rear storage compartment behind the back seat in the double cab.
The hardest part was getting the tire back onto the rim.
http://www.cardomain.com/ride/2524411/1
2006 Prerunner DC, TRD OR, Ivan Stewart Wheels, Access LE Tonneau, Colorkeyed Grille, Door Handles, DF-TOY Aux Input, Dynolock Tailgate Lock, Homelink Mirror
dko-tacoma is offline   Reply With Quote
Old 12-24-2006, 12:50 PM   #14
azntony85
STi Killer :0)
Trader Rating: (0)
View azntony85's Photo Gallery
Tpms = ? :0)
06TacomaV6///Flowmaster Deltaflow 50///aFe Stage2 Si Intake///Toytec Lift
azntony85 is offline   Reply With Quote
Old 12-24-2006, 01:03 PM   #15
Pb
Pb's Avatar
Trader Rating: (14)
Tire Pressure Monitoring System
vB code is On
Forum Jump
Similar Threads
TPMS light was on this morning.... BigWillie Gen 5 & 6 7 09-23-2007 11:32 AM
06 Tpms ncpaladin 2005+ Tacoma General 3 08-11-2006 02:49 PM
Interior Lighting DIY Mega Sticky Poll SnakeyeS General Camry Discussion 22 01-26-2006 02:19 PM
DIY Posts edphighlader04 01-07 Highlander 0 10-07-2005 08:35 AM
Powered by vBadvanced CMPS v3.0 RC2
Powered by: vBulletin
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Page generated in 0.17857 seconds with 42 queries
