» Sponsors
» Sponsors
Go Back   Toyota Forums :: Toyota Nation > Toyota Truck, SUV and Van Forums > Toyota Tacoma Forum > 2005+ Tacoma General
Register Home Forum Active Topics eBay Marketplace Photo Gallery TN Arcade Blogs Mark Forums Read
2005+ Tacoma General Discussion area for all the new Toyota Tacoma owners out there!
Please Visit our Site Sponsors
Thread Tools Display Modes
Old 12-27-2006, 10:43 AM   #1
mhadden
Precision driver
mhadden's Avatar
Trader Rating: (7)
View mhadden's Photo Gallery
Post DIY: OEM Cruise Control
Alright! After waiting nearly 3 months, I finally ordered my parts and tried it out on my 4-cylinder to see if it would work, and it did! All the safety features work (clutch switch, brake switch) and the stalk works perfectly. The kicker is, if you are even somewhat electrically/mechanically inclined, this "mod" is cheaper than that crap aftermarket system that requires you to cut wires.
Here's what you'll need to order for this to work:
84632-08021 Cruise control switch (this is the stalk)
45186-0C020-B1 Steering wheel cover (order based on your steering wheel cover color)
88280-14030 Clutch switch (only needed if you have a manual transmission)
84633-04020 Cruise control wire (this is what connects the stalk to the steering wheel spinal)
90080-15079 1/2" 10/32 screws (you could save some money and get these at a hardware store)..thanks to parkinglot and Tacobama for letting me know about this oversight.
I got all these parts online through Toyota of Dallas.
Here's the tools you'll need:
T-30 Hex driver
10mm socket (long)
3" extention
Socket wrench
And the disclaimer: I cannot be responsible for any damages that may occur because of your negligence. Please be careful and have someone qaulified to do this if you are unable or unwilling.
First thing is first, you need to disconnect the battery.
Then remove the side panels of the steering wheel with a screwdriver. Be careful because they scratch really easy. Put the tip to the screwdriver in closest to you. A writeup of the next couple steps can be found here. Special thanks to Hank6500 for the how to.
Then remove the screws that hold the airbag in place. They are the T-30 Hex screws. Remove the clips behind the airbag carfully with a screwdriver and remove the ground at the bottom of the airbag.
Here's what it should look like once you remove the airbag completely:
Now you need to remove the wire that was the ground on the airbag. It has a white connector into the steering spindal. Remove that and replace it with the new one you ordered. The connector that is attached to that wire will go into the cruise control stalk. Slide the stalk in like shown below and tighten the screws. It should fit right into position.
Once you get the stalk secure, put the wire into the stalk, and put all the wires connecting the airbag bag on. Then bolt the airbag back into place and snap your covers back on. Here's what the final product will look like:
If you have an automatic transmission, you are done. But if you have a manual, you'll need to install the clutch switch. I have very generic directions on how to access the area you'll need to get to.
You'll need to find this connector underneath. It'll be taped up, but it shouldn't be too difficult to get undone. This is the clutch switch wire.
The clutch switch will go in the circle seen below. It was a complete bitch to get in this area, but even with my large hands, I was still able to access it. Take note of the distance from the top of the plate to the bottom of the blank nut. You'll need to have the same distance when you put the clutch switch in its place.
You'll probably need to remove the lower dash panel to access the clutch switch (and beleive me, it's easier!). Here's how to remove the lower dash panel to get to that switch. Thanks to remelad from TTORA. Remove the 4 bolts that attach the fuse block. Then move it out of the way and you'll be able to see where the clutch switch is supposed to be.
It's hard to get a pic, but this is the best that I came up with.
Here's the bolt that will be taken out and replaced with the clutch switch. Make sure after you screw the clutch switch into place you connect the connector to the switch. Otherwise the cruise will not work (because it'll sense that the clutch is being pressed).
Enjoy your new OEM cruise control
2010 Super White Corolla LE 4AT
2008 Whistler Silver CR-V EX AWD 5AT
2008 White Pearl Goldwing Comfort/Navi
mhadden is offline   Reply With Quote
Old 12-27-2006, 10:53 AM   #2
pointerDixie214
Trader Rating: (1)
View pointerDixie214's Photo Gallery
Sweet man! I like it... although I will never buy a vehicle without cruisecontrol... this is a good mod for those who did...
Click the pic for CarDomain Page
2006 Tacoma Prerunner TRD Offroad AC 6 Speed - OME - Flowmaster
pointerDixie214 is offline   Reply With Quote
Old 12-27-2006, 11:33 AM   #3
MGlassco
Trader Rating: (0)
View MGlassco's Photo Gallery
thats awesome!!! nice write-up too
I never really use my CC though, maybe 3 times since I have owned the truck
2006 TRD Sport | 2wd | Double Cab
3" ToyTec / OME | 285/75/17 BFG M/T
Delta Flow 50 Series Flowmaster | DF-TOY
MGlassco is offline   Reply With Quote
Old 12-27-2006, 07:51 PM   #4
mhadden
Precision driver
mhadden's Avatar
Trader Rating: (7)
I would like to add that it costs 108.99 which includes shipping.
Old 12-27-2006, 08:15 PM   #5
Pb
Surfing TN via iPhone
Pb's Avatar
Trader Rating: (15)
View Pb's Photo Gallery
Nice DIY. Added to the sticky.
Pb is offline   Reply With Quote
Old 12-27-2006, 08:25 PM   #6
Bigblue
Don't mess with the Blue
Bigblue's Avatar
Trader Rating: (1)
View Bigblue's Photo Gallery
Great Job!!
Yeah, I hardly ever use mine. I never think about it.
2006 SpeedwayBlue Tacoma TRD Sport
Bigblue is offline   Reply With Quote
Old 03-23-2007, 04:51 PM   #7
Todder
Trader Rating: (1)
View Todder's Photo Gallery
Aw come on. Is it really that easy? Nothing needed under the hood, just plug and play? If it is all that easy, I'll order up the parts a.s.a.p. It would make life so sweet for us cheap bastards that didn't opt for cruise to start with. Did I mention, I'm cheap?
Todder is offline   Reply With Quote
Old 03-23-2007, 05:17 PM   #8
mhadden
Precision driver
mhadden's Avatar
Trader Rating: (7)
That's seriously it...it's sad that $100 in parts you can do it yourself, or opt for one of the many $1700+ packages for the Tacoma to get it...just wierd that a AC 4 cyl taco can get it with the convenience package, but not the reg cab....thus I was the guinea pig for this mod...
Old 03-26-2007, 12:36 PM   #9
ynnek63
Trader Rating: (0)
View ynnek63's Photo Gallery
OK...I installed the "crap aftermarket" cruise control I have been very happy with it. It works great. But, I do like the OEM look of this setup, so do you know if the clutch switch from my aftermarket unit can be used with this one. That clutch switch is a PITA to install and I'd rather not have to do it again.
Thanks,
Ken
ynnek63 is offline   Reply With Quote
Old 03-26-2007, 12:44 PM   #10
mhadden
Precision driver
mhadden's Avatar
Trader Rating: (7)
Thanks,
Ken
I think it'll all depend. Ultimately, yes, you should be able to use it because a switch just cuts (or sends) power to indicate that the clutch is depressed. If you can look up into the wiring harness where the clutch switch is located, you'll see the pic that I posted that is the stock switch connector. If your connector is not like this, you can still use your current one, you'll just have to splice wires and reconnect them. If you need any other help, let me know.
Old 03-27-2007, 11:05 AM   #11
ynnek63
Trader Rating: (0)
OK..thanks. I went ahead and ordered all the parts, including the clutch switch. I may try and use it anyway.
Thanks again
Old 03-28-2007, 10:56 AM   #12
ynnek63
Trader Rating: (0)
I know this is off-topic, but do you think you could install the steering wheel mounted radio controls just as easily? With the stock unit?
Old 03-28-2007, 01:37 PM   #13
mhadden
Precision driver
mhadden's Avatar
Trader Rating: (7)
Doubt it...unless you have a V6...I'm sure the wiring harness is completely different. I don't think the 4 cyl reg or access cabs have the option for the upgraded radio...I could be wrong though.
I think you would have to replace the airbag with a different module anyways...
Old 03-28-2007, 06:27 PM   #14
vtunderground
Trader Rating: (0)
View vtunderground's Photo Gallery
Wow, thank you.
vtunderground is offline   Reply With Quote
Old 03-28-2007, 08:17 PM   #15
Tacobama
Trader Rating: (0)
View Tacobama's Photo Gallery
Ordered the parts today. Keeping my fingers crossed it works as advertised!
Tacobama is offline   Reply With Quote
vB code is On
Forum Jump
Similar Threads
Intresting cruise control problem metalo69 General Camry Discussion 3 05-27-2006 12:01 AM
Wandering Cruise Control johnjtacoma 2005+ Tacoma General 9 04-19-2006 02:58 PM
Stereo & Climate Control Bulb DIY *56K ouch* emiliorescigno Archived Corolla threads 7 12-13-2005 11:30 PM
Cruise control over-accelerating Bazirker 2003-2008 Matrix 13 12-02-2005 02:26 PM
Tundra Cruise Control Retrofit cookiemech '00-'06 Tundra 0 11-24-2004 07:45 PM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Page generated in 0.17235 seconds with 14 queries
