» Sponsors
» Sponsors
Go Back   Toyota Forums :: Toyota Nation > Toyota Truck, SUV and Van Forums > Toyota Tacoma Forum > 2005+ Tacoma General
Register Home Forum Active Topics eBay Marketplace Photo Gallery TN Arcade Blogs Mark Forums Read
2005+ Tacoma General Discussion area for all the new Toyota Tacoma owners out there!
Please Visit our Site Sponsors
Thread Tools Display Modes
Old 03-31-2007, 06:29 PM   #1
MrGrimm
mall crawler
MrGrimm's Avatar
Trader Rating: (0)
View MrGrimm's Photo Gallery
DIY – Extra Bed Rings
Items Needed:
  • (1) Part Number PT785-35054. Includes 2 D-rings, ranging from $19 to $30. The $19 is the internet price and the $30 is the average dealership price.
  • (1) T-55 Torx bit which will cost about $4
  • (1) Ratchet wrench that fits your Torx bit above
  • A device that will grind down the bed bolt (like a dremel or screw driver with a grinding drum attached.
  • Spray paint to paint over the area you just ground down.
First off, I am not taking credit for this DIY because many have done it but nobody has put all of the information together in a DIY. This DIY will take you less than 15 minutes to complete and will help you out a lot if you plan on hauling anything heavy in your truck bed.
Step 1: Taking your ratchet and torx bit, remove the two bed bolts towards the front of the bed.
Step 2:
The large washer that is on the bed bolt will not slip off by itself. An easy way to remove that washer is to grind down the threads just below it. You will not be needing those threads anyways. For this task I used a dremel with a grinding drum attached. It just needs to be ground down to the point where you can easily slip the washer off.
Step 3:
Clean off the area you just ground down and spray the area over with some spray paint to keep the rust off of the area.
Step 4: Head over to the parts you picked up from Toyota. You only need one portion of the items you picked up. All you need is the actual d-ring itself that is attached to the plate. The small washer, bolt, and plastic washer are not needed. Once you remove the small plastic washer, you can remove the bolt from the assembly.
Step 5:
Now that your bed bolts are done drying go ahead and slip the bolt through the hole in the d-ring. Now, use that large washer and put it on the bottom of the d-ring.
Step 6:
The final step is just to screw the bolt back into the bed. As far as tightening the bolt down I could not find an exact torque setting for it. Now you are done with a modification that should have come stock from the factory.
MrGrimm is offline   Reply With Quote
Old 03-31-2007, 08:21 PM   #2
Jotaro
+++++ J Runner +++++
Jotaro's Avatar
Trader Rating: (0)
View Jotaro's Photo Gallery
cool stuff!!
is there enough thread if i put more washer ontop the d-rings, the bolt head seems interfering with the hinge?
Jotaro is offline   Reply With Quote
Old 03-31-2007, 09:07 PM   #3
MrGrimm
mall crawler
MrGrimm's Avatar
Trader Rating: (0)
Originally Posted by Jotaro
cool stuff!!
you have plenty of room for another washer.
Old 03-31-2007, 09:19 PM   #4
sixonthefloor
"Tanoma"
sixonthefloor's Avatar
Trader Rating: (0)
View sixonthefloor's Photo Gallery
Cool I was thinking about doing this soon
2005 Tacoma TRD sport 4x4 DC: 3" Toyec lift, Wheels & Tires, 2 tone leather, DVD and NAV system, TRD exhaust and lots more.
sixonthefloor is offline   Reply With Quote
Old 03-31-2007, 10:09 PM   #5
GTCOMA
Eat Lightning Crap Thunda
GTCOMA's Avatar
Trader Rating: (1)
View GTCOMA's Photo Gallery
Looks good. I'm sure it is much sturdier than the regular install. That is a MONSTER Torx!
GTCOMA is offline   Reply With Quote
Old 03-31-2007, 11:08 PM   #6
mhillsing23
Trader Rating: (0)
View mhillsing23's Photo Gallery
Thanks for the write up. Now that riding season is upon me again I have been meaning to do this. Very simple install, good pics...
mhillsing23 is offline   Reply With Quote
Old 03-31-2007, 11:09 PM   #7
toysupra1
road hazard
toysupra1's Avatar
Trader Rating: (0)
View toysupra1's Photo Gallery
nice visuals grimm. i did this mod awhile back too. definately a must if you lug a motorcycle or oversized items that need to be strapped down.
2007 Toyota Tacoma - Black Sand Pearl, Access Cab, 4x4, TRD Sport
toysupra1 is offline   Reply With Quote
Old 04-01-2007, 12:47 AM   #8
Pb
Surfing TN via iPhone
Pb's Avatar
Trader Rating: (15)
View Pb's Photo Gallery
Good work. I'll add this to the DIY sticky.
Pb is offline   Reply With Quote
Old 04-01-2007, 01:09 AM   #9
vendeta2k
In The REAL Norcal...
Trader Rating: (0)
View vendeta2k's Photo Gallery
got any links to the internet sites for the hardware?
vendeta2k is offline   Reply With Quote
Old 04-01-2007, 01:31 AM   #10
SJlittlefoot
Go Sharks!!!
SJlittlefoot's Avatar
Trader Rating: (3)
View SJlittlefoot's Photo Gallery
trdparts4u.com has them for $18.40 thats a pretty good price. I'll probably be putting this on my todo list for next week
06 Tacoma D-cab Prerunner TRD Off-Road
http://www.cardomain.com/ride/2284057
SJlittlefoot is offline   Reply With Quote
Old 04-01-2007, 01:44 AM   #11
mjonags32
n00b
mjonags32's Avatar
Trader Rating: (2)
View mjonags32's Photo Gallery
very nice write up. its very detailed and the pictures are great! i'm ordering the d rings monday!
mjonags32 is offline   Reply With Quote
Old 04-02-2007, 12:26 AM   #12
TacoCanuck
Trader Rating: (0)
View TacoCanuck's Photo Gallery
The other option to remove the Bed Bolt washer is to put a 1-1/16 socket over the head of the bed bolt and press it out in a 4in. bench vise, takes 30 seconds each.
TacoCanuck is offline   Reply With Quote
Old 04-02-2007, 08:48 AM   #13
NJTacoma
Mall Crawler
NJTacoma's Avatar
Trader Rating: (0)
View NJTacoma's Photo Gallery
I just moved the d-rings from the back of the bed to front.
08 Double Cab 4x4
NJTacoma is offline   Reply With Quote
Old 04-04-2007, 12:20 PM   #14
misterwc930
MisterWC930
misterwc930's Avatar
Trader Rating: (0)
View misterwc930's Photo Gallery
So did you not use the backing plate?
misterwc930 is offline   Reply With Quote
Old 04-04-2007, 12:27 PM   #15
bcutshall
Trader Rating: (0)
View bcutshall's Photo Gallery
i put my extra bedrings on the sides using the backing plates.
bcutshall is offline   Reply With Quote
vB code is On
Forum Jump
Similar Threads
Bed liner...what's behind the screws namda1234 89-95 Toyota Pickup/Hilux 3 09-19-2006 08:42 PM
Bed cover? toku58 2005+ Tacoma General 1 06-17-2006 09:58 AM
Lockable Bed Extender GogglesPaizano 2005+ Tacoma General 6 05-18-2006 12:26 PM
Where To Find a New Replacement Bed Skin or Bed Jesster1 Pre-88 Toyota Pickup/Hilux 2 05-17-2006 11:19 PM
Homemade Bed extender demoncleaner 2005+ Tacoma General 27 05-16-2006 04:34 PM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Page generated in 0.15324 seconds with 14 queries
