» Sponsors
» Sponsors
Go Back   Toyota Forums :: Toyota Nation > Toyota Truck, SUV and Van Forums > Toyota Tacoma Forum > 2005+ Tacoma General
Register Home Forum Active Topics eBay Marketplace Photo Gallery TN Arcade Blogs Mark Forums Read
2005+ Tacoma General Discussion area for all the new Toyota Tacoma owners out there!
Please Visit our Site Sponsors
Thread Tools Display Modes
Old 05-23-2007, 05:02 PM   #1
slvrAZtaco
slvrAZtaco's Avatar
Trader Rating: (2)
View slvrAZtaco's Photo Gallery
So, you want to know when your fogs are on?
The following is the procedure for modifying your OEM fog light switch to light up a different color when the fog lights are on. In order for this modification to work properly the "fog light always on" mod must be done. The reason is that the relay drops the output line from the switch to ground if there is no power to it.
**Disclaimer** Do this modification at your own risk, this is for information purposes only! Damage to your electrical system could occur. **Disclaimer**
Parts Needed:
Small Flat Blade Screwdriver
Soldering Iron
Solder
3mm LED for illumination (normal light, switch off, desired color)
3mm LED for "On" (switch on, desired color)
Resistor 110 ohm 1/4W or desired output.
Drill
Drill bit (size of cathode of LED)
Shrink tubing.
Here is the switch and pin layout. If you have the switch laying with the light bulb side up, then the pins from right to left are; +12V illumination, Ground, Switch output, Switch input.
1 - Remove the light bulb. Quarter turn counter clockwise and pull up.
2 - Using a flat blade screw driver, unlock the tabs holding the Top of the switch (4 tabs) and remove the top.
Here is the bottom side of the Top.
3 - Drill a small hole, from the bottom side of the Top, inline with the output pin. This hole only needs to be large enough to have the cathode of the LED fit through. This is where your "On" LED will pass through and connect.
View of LED cathode on top side of top.
4 - Tin the electrical connections. You want to do both contacts for the light bulb, and there is a small hole that makes contact with the output pin.
5 - Take your resistor and bend it into shape. You want to have one lead from the resistor make contact with the +12V illumination contact, and then drop to the bottom of the Top piece.
6 - Solder in the resistor. I added heat shrink to eliminate any chance of shorting on the ground connection.
7 - Take your "Off" or illumination LED and bend the cathode in two 90 degree angles, so that the LED will point to the front of the switch (button) and the cathode will connect to the ground connection.
8 - Install the "On" LED, sliding the cathode through the hole you drilled. You may need to cut the cathode down some. You want the LED's to sit side by side. Bend the cathode down 90 degrees so that it penetrates the hole that you tinned on the output pin. Solder the cathode.
9 - Solder the anode of both LEDs to the resistor and cut the excess.
*NOTE* in these pictures I have the anode connections low so that I could take the picture. These should be tucked as close to the bottom of the Top as possible, otherwise the switch will not lock and unlock properly.
10 - Test your solder job and make sure that the LEDs light up. I use a 9V battery.
11- Slide the Top back down onto the switch (carefully) and turn on the LED's. You want to make sure that they are aimed properly and at the icon on the button. If not then you can pop off the button and aim them by moving them to the desired location.
*NOTE* if you are using a brighter color i.e. white for your illumination then you might not want the LED pointing directly at the icon. The illumination LED will not turn off when the switch is active, but the indicator LED will turn on in addition to the illumination LED. A brighter LED will oversaturate the indicator LED if they are aimed at the same location.
Illumination
Indicator
Both (typical condition for switch on) In this case, the white as the illumination was oversaturating the blue, so I had to aim the white away from the icon. Final product had more blue when the fog light was on.
Test your switch to ensure it locks in the On postion and then turns off. You can test this using the 9V battery connected to the +12V illumination and the switch Input pin. Press the button on and off and see if the light works.
*NOTE* The switch is designed to work on its side, as if it was installed in the vehicle (light bulb to the right).
Scroll down for more pictures and a video of the fog light switch in action.
05 Tacoma Prerunner TRD Offroad
07 4 Runner SR5 4x4
http://www.cardomain.com/ride/2531825/1
slvrAZtaco is offline   Reply With Quote
Old 05-23-2007, 05:26 PM   #2
05 r1racer
05 r1racer's Avatar
Trader Rating: (1)
View 05 r1racer's Photo Gallery
Ooo That's look good! Always something new.
07 Prerunner TRD Off Road Speedway Blue DC - 2/13/07
05 r1racer is offline   Reply With Quote
Old 05-23-2007, 05:28 PM   #3
slvrAZtaco
slvrAZtaco's Avatar
Trader Rating: (2)
I am going to do the fog light mod now.. that way I don't have to worry about the white coming on until I turn on the fogs. I will try to take some better pics.
07 4 Runner SR5 4x4
Old 05-23-2007, 07:34 PM   #4
cddallara
Trader Rating: (0)
View cddallara's Photo Gallery
When I was installing my fogs last week, I toyed with the idea of tieing the illum hot into the switch out, so the light (only) comes on when the fogs are on.
But, as it is for now, the illum/power in are both tied to the marker light.
Want to trade/buy: My black power mirrors for your white ones, my white nonscooped hood for your (any color) scooped one. PM me.
cddallara is offline   Reply With Quote
Old 05-23-2007, 07:38 PM   #5
slvrAZtaco
slvrAZtaco's Avatar
Trader Rating: (2)
I just did the fog light mod and the light in the switch works perfect. Always blue when the running or headlights are on and as soon as you turn on the fogs the white light kicks on. woo hoo
07 4 Runner SR5 4x4
Old 05-23-2007, 07:41 PM   #6
cddallara
Trader Rating: (0)
I wish I had factory fogs (from the factory), or at least the wiring. It'd be sooo much cleaner!
that is a good idea, I'd forget which color was which though!
Old 05-23-2007, 08:00 PM   #7
slvrAZtaco
slvrAZtaco's Avatar
Trader Rating: (2)
Everything is blue in my truck so white stands out.. I was going to do red or green but all I had was blue and white 3mm leds. I will do another color in my other switch, once I do some bed lights.
07 4 Runner SR5 4x4
Old 05-23-2007, 09:17 PM   #8
BuffDHC-5
Flying Taco Driver
Trader Rating: (0)
View BuffDHC-5's Photo Gallery
Hey great idea, I will be following your progress.
BuffDHC-5 is offline   Reply With Quote
Old 05-23-2007, 10:30 PM   #9
Glk21c
Stop Causing Trouble
Glk21c's Avatar
Trader Rating: (0)
View Glk21c's Photo Gallery
could you explain exactly what you did to make the switch light up different colors. thanks
2007 Silver DC 4x4 TRD Sport#1
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
Thomas Jefferson
Glk21c is offline   Reply With Quote
Old 05-24-2007, 12:04 AM   #10
tooblutacoma06
Mind over Money
tooblutacoma06's Avatar
Trader Rating: (0)
View tooblutacoma06's Photo Gallery
Great work Josh! Awesome idea and awesome execution! I'm still working on illuminating my 4by switch so when I get that done I may tackle the other switches. Keep it up man!
tooblutacoma06 is offline   Reply With Quote
Old 05-24-2007, 12:15 AM   #11
slvrAZtaco
slvrAZtaco's Avatar
Trader Rating: (2)
I will write up a full procedure. I had already changed the switch to blue by adding in a LED & Resistor, then today I added another LED just attached to the Output pin.
07 4 Runner SR5 4x4
Old 05-24-2007, 04:04 AM   #12
deff808
Trader Rating: (0)
View deff808's Photo Gallery
Yay! I'll be definelty interested in this!
Can i get a other shot, not so close to it. Wanna see how bright it is from a further distance.
deff808 is offline   Reply With Quote
Old 05-24-2007, 11:21 PM   #13
TacoMSU
A.K.A. Ty
TacoMSU's Avatar
Trader Rating: (0)
View TacoMSU's Photo Gallery
I think I've figured out how to get the light to illuminate only when the fog lights are on. I'll be working on it tomorrow, so I'll post some results when I get done. So far, the only problem I see is that I don't think the fog light switch will dim with the rheostat. That's a small price to pay, but I might be able to work it out.
TacoMSU is offline   Reply With Quote
Old 05-25-2007, 11:58 AM   #14
slvrAZtaco
slvrAZtaco's Avatar
Trader Rating: (2)
I thought about doing that as well, but I wanted to be able to see the switch when it is dark.
I think you can just use the output of the switch for your ground to do what you want to do. That way you only have power when your headlights are on, and you will only have that ground when the fog lights are on. Was that what you were thinking about doing? That way the power for the light would still be controlled by the dimmer, you would just have to have both the headlights and fog lights on to have the light on.
07 4 Runner SR5 4x4
Old 05-30-2007, 04:16 PM   #15
slvrAZtaco
slvrAZtaco's Avatar
Trader Rating: (2)
Wanted to post some better pics and a video clip.
Video
07 4 Runner SR5 4x4
vB code is On
Forum Jump
Similar Threads
Headlights / Fogs setups -- PLEASE POST PICS FRiZzO 2005+ Tacoma General 15 12-12-2006 04:47 PM
PIAA Plasma GTX 9005 fogs. FRiZzO 2005+ Tacoma General 16 12-04-2006 04:27 PM
4th gen. fogs Jordache919 General Camry Discussion 1 06-12-2006 04:55 PM
Gen 5.5 fogs finally available ... eBay 95WhiteCamry Gen 5 & 6 3 01-16-2006 09:57 PM
fogs don't turn on without heads on???? 1MZ-FExle.s General Lexus Discussion 6 04-12-2003 03:16 PM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Page generated in 0.17717 seconds with 14 queries
