» Sponsors
» Sponsors
Go Back   Toyota Forums :: Toyota Nation > Toyota Hybrid Forum > Prius Forum
Register Home Forum Active Topics eBay Marketplace Photo Gallery TN Arcade Blogs Mark Forums Read
Prius Forum The original hybrid from Toyota... the Prius! Discussion area for everything about it.
Please Visit our Site Sponsors
Thread Tools Display Modes
Old 05-28-2009, 11:15 PM   #1
NYC prius
Trader Rating: (0)
View NYC prius's Photo Gallery
Engine Flush
Why would a mechanic suggest an engine flush for a 2006 Prius with 25,000 miles and no problems.
I'm hoping that there's some reason so I don't have to start looking for a new mechanic.
Thanks!
NYC prius is offline   Reply With Quote
Old 06-19-2009, 06:39 PM   #2
hilux5084
Joe
hilux5084's Avatar
Trader Rating: (0)
View hilux5084's Photo Gallery
Australia
The real reason for needing to flush would be if the engine hasnt been serviced regularly and on time, the other reason which is more likely the mechanic is value adding to his servicing to increase his income.
Joe
hilux5084 is offline   Reply With Quote
Old 07-27-2009, 11:23 AM   #3
virg
nicely retired
Trader Rating: (0)
View virg's Photo Gallery
Engine Flushes are Never necessary
Any mechanic that recommends an engine or transmission flush for a normally maintained engine (oil and filter change per owners manual) is padding the bill. Take a look at the bottom of your oil filler cap. If the bottom is clean and has no oil sludge build up, you're fine.
virg
virg is offline   Reply With Quote
Old 09-22-2009, 08:46 PM   #4
Timm099
Trader Rating: (0)
View Timm099's Photo Gallery
This is not entirely true. An engine flush is usually recommended when a car is significantly passed the service interval. An engine flush is only used as a maintenance item to remove all of the old oil in the system. If you look at the bottom of the cap and see sludge in there, IT IS TOO LATE. A flush will not remove any sludge what so ever and can in fact loosen up sludge and cause it to clog the pickup. It is in no way designed as a repair
Timm099 is offline   Reply With Quote
vB code is On
Forum Jump
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Page generated in 0.08051 seconds with 13 queries
