| Register | Home | Forum | Active Topics | eBay Marketplace | Photo Gallery | Blogs | Mark Forums Read |
| Audio, Video, and Security - Tech For the electro-techies and the bass heads. |
Thread Tools | Display Modes |
#1 |
Whine Connoisseur
Gameroom cash: $2000
Trader Rating: (2)
Difficulty Level: 2/10 Time: 3hrs Cost:$40 minimum for basic wires and terminals Tools: Basic tools - ratchet, wrenches, wire cutter, pliers Supplies: 1 pos and 1 neg battery terminal, 10ft of wire, 4 wire terminals, heat shrink wrap Pictures: http://www.imagestation.com/album/?id=4286604527 Instructions: Remove battery 01. remove battery from car 02. remove battery tray Negative wires 03. remove ground wire from chassis 04. remove ground wire from engine 05. cut wire to length, attach ring terminals, crimp and shrink wrap 06. secure new wires to chassis mounting point 07. repeat step 5 and secure to engine mounting point 07. trim plastic off wire and attach to new terminals Positive wires 08. unsnap and remove fuse box cover 09. pry main fuse box located in the engine bay with a screwdriver 10. open cover at bottom of fuse box to gain access to main fuse 11. cut new wire to length, attach ring terminals 12. run new wire up from bottom of fuse box and secure to main fuse link 13. close and put back fuse box 14. remove positive connection from starter. The nut is hidden behind and underneath the starter. Sorry no pics. 15. cut wire to length, attach ring terminals, crimp and shrink wrap 16. secure to starter 17. trim plastic off wire and attach to new terminals Reconnect 18. double check to make sure all connections were done properly 19. reconnect terminals back onto battery 20. turn on car I elected to use 1 gauge wire for negative and 4 gauge for positive and extra bling terminals. Make sure your terminals accept 1 guage before you start - most only go as large as 4 gauge. As for the amount of wire, you'll need about 2.5feet for each connection (2x2.5 for neg and 2x2.5 for pos) I had some difficulty trying to remove the nut from the starter because of it's location. It kept slipping because I couldn't get the wrench to seat properly to get a grip. I tried using a universal joint to get at it but had no luck. At the end, I was successful by using the handle of the ratchet to simply hold the wrench in place by pressing it up against it so that the wrench wouldn't slip off. Feel free to ask any questions you have. The lights no longer dim when the bass hits and the car seems to idle much better. Thanks to Luc for guiding mw along the way. Big up to skperformance for hooking me up with a Yellow Top. Redrum deserves props for lending me some tools I didn't have. Thanks guys! Last edited by Phi : 06-09-2004 at 03:37 PM. |
| Sponsored Links | |
Advertisement |
#2 |
Mad Scientist
![]() Join Date: Feb 2004
Gameroom cash: $7700
Trader Rating: (7)
in total for everything was 40 ? |
#3 |
Whine Connoisseur
Trader Rating: (2)
I wish! My negative terminal alone was $40
The $40 I stated above is assuming you use 4 gauge wires instead of 1 gauge and your terminals aren't as flashy. |
#4 |
Got SQ?
Gameroom cash: $1500
Trader Rating: (0)
Excellent turtorial, did you run new wire to your alt (crucial), what about engine to chassis? Thanks for the tips, mine is totally rigged right now.
Iraggi Alt ->SVR ->Eclipse ->Tru Technology ->DLS / Image Dynamics / Marv Enclosure / Rammat Gen 4 V6 For Sale: Adire Audio Sadhara Sub System, Bryston SP1 Video Switcher, Totem acoustics speakers |
#5 |
Whine Connoisseur
Trader Rating: (2)
I never considered re-wiring the alt. I talked to a few guys and they said it'd be a bitch to do. I'll look into that further. As for upgrading the other grounds, I haven't gotten around to doing that yet. I plan to though. Thanks for the tips.
btw- I noticed you only post in the audio section and judging by your sig, you're a serious audiophile. What else can you share about yourself? what car do you drive? Maybe you could formally introduce yourself in the me/mines/mods section ![]() |
#6 | |
I get angry when Im sober
Trader Rating: (0)
Very nice post Phi. I will likely do something similar when I finish doing my system and get my Optima Yellow Top. Just not sure when that's going to happen.
1995 Silverleaf Metallic Camry LE Automatic beater 1987 Buick Grand National |
#7 | |
Whine Connoisseur
Trader Rating: (2)
I'm surprised you don't have a yellow top yet, Stealth. |
#8 | |
Trader Rating: (0)
). Gonna be doing a lot of sound quality stuff this time, which is why I'm taking my time. Also, I'm really poor right now. In fact, my bank balance is -$6. I'm just waiting for my paycheck. First thing I have to do is replace my Infinity Perfects since I put em up on ebay. Then after that, I have to replace my midbass drivers and dynamat (peel and seal ;-)) my doors. Then I need to save up some cash and get myself a mono amp and a pair of 12s, build a box, buy a boatload of new wiring, more dynamat for trunk, and then once that's all said and done I'll probably get the yellow top.
#9 |
Wild on the Flip Side
Trader Rating: (0)
hey! interesting topic!
here's what i did to my car when it still had its stock engine... http://www.cardomain.com/memberpage/458428/4 ![]() |
#10 |
Got SQ?
Trader Rating: (0)
Been doing systems for about 20 years, so I guess you can say I like car audio. Here's a link to my sounddomain web page, I really dont much about anything else, like modifications and such, so I stick to what I know, home and car audio.
http://www.sounddomain.com/memberpage/565649
#11 |
Banning is an art.
![]() Join Date: Jul 2001
Gameroom cash: $2500
Trader Rating: (0)
Cool DIY! Added to the ultimate sticky.
#12 |
Trader Rating: (0)
Great job Phi!!! I wish I had better documentation when I installed mine, but after 4 hours of cursing by myself, I had to get away from it for a bit.
1998 S/C'd 1MZ-FE A/T |
#13 |
Whine Connoisseur
Trader Rating: (2)
Update: As Luc warned in earlier posts, the Optima wasn't high enuff to secure using the stock batt strap. I finally got Optima/Interstate to send my a tray free of charge (retails: $12). It can be used as both a cover and tray.
When I called Optima, they told me they had discontinued the tray. I emailed them aswell and was successfull with this method. ![]() |
#14 |
No Fat Bitches
Trader Rating: (9)
How much were the battery terminals and where'd you buy them from?
#15 |
Whine Connoisseur
Trader Rating: (2)
I had them ordered by a local audio shop. I'm not gonna say how much I paid, but be prepared to pay around $100 for them.
| Sponsored Links | |
Advertisement |
| Thread Tools | |
| Display Modes | |
