» Sponsors
» Sponsors
Go Back   Toyota Forums :: Toyota Nation > Toyota Passenger and Sports Car Forums > Celica Forum
Register Home Forum Active Topics eBay Marketplace Photo Gallery TN Arcade Blogs Mark Forums Read
Celica Forum Forum for all Toyota Celica discussion! Including the ST16x/18x/20x, and ZZT230/231.
Please Visit our Site Sponsors
Thread Tools Display Modes
Old 10-12-2004, 07:21 PM   #1
Zrain
Trader Rating: (0)
View Zrain's Photo Gallery
Post the 5sFE Turbo Upgrade Info
(Add/Edit where you see fit, and Please for the love of god Sticky this)
Read this as a genral information guide, its a good starting place, but also do a few serch's with the TN serch tool, try these key workds
5sFTE
5sGTE
that will give you alot of good stuff as well.
Safe Limits on Boost
Im puting this first due to the fact that its a common question.
(No intercooler, and a CT26 Turbo Charger)
4-8PSI is a goo range acording to most people.
(WITH AN Intercooler[stock 3s top mount], CT26)
18PSI max, altho the CT26 will start to run out of breath around 14PSI as it aprotch's this number.
Originally posted by MRQturbo
general consensus amongst mr2 owners is that 16psi is the max effeciency range for the stock ct-26.....forged internals are a must if u guys plan to run higher boost....i can't see how the 5SFE can withstand any more than 8psi on the stock motor....
great write up......
Good To know Q. (information comes out.. thats what i wanted to do with this Post.)
5sFE, 3sGTE info
Allright First you need to understand the S mottor Series
As we Know the 3sG(T)E, and the 5sFE are of the same series of mottors, (the s series) the 5s is a 2.2L, while the 3s is a 2.0L.
this series of mottors came with 2 difrent head desines. the FE and GE. the GE is the "sport preformace" head, while the FE is the econimy head. these 2 heads share the same Exhaust port pattern, but donot share the same intake patter, the GE has 2 belt wheels that drive, 2 independent cams, while the FE has one belt wheel that drives both cams VA transfer gear inside the head. both mount the distributor, on the right side(facing the mottor) and both bolt up to the 's' sries mottors.
a GE head can be interchanged with a FE head, (and Vise Versa) the only problum is the ECU's need to be swaped, or a stand alone be used.
(NOTES: the S serices mottors have some of there own genirations with in there run and as such, an older 5s, might not take the head off of a newer 3s, i dont have the information as to witch ones dont match up, but be aware.
UPDATE: Acording to some new info i got, the parts should be pulled off of a Second Geniration 3sGTE and that older 3sGTE's had difrent bolt count on the exhause mainfold.
the 3s is the common turbo mottor, being caled the 3sGTE, this is due to the fact that it use's a GE head with a turbo charger, thus the G T E tag at the end of the 3s.
the turbo system on this mottor is compirsed of the following.
CT26 Twin Entry Toyota Turbo Charger
4 port, tiwn output Turbo Exhause mainfold
Air to Air top mount intercooler
2 Bar MAP senceor.
to Turbo charge any mottor from the S series you need the following, a Exhause mainfold off of a 3sGTE, and a 2BAR Map off of a MR2 Turbo, or Celica Alltrack. (and various other Parts)
the Mainfold will alow you to bolt up a Turbo to the car, and the 2Bar map will let the ECU proporly get information about air Dencity, and preshure alowin the ECU to make the right fuel to air mix.
the Mainfold and 2bar map are the hard parts to get, the rest is up to you.
Now this is where we enter the gray Area.
a 5s can ither be a 5sGTE, or a 5sFTE. as you now know, this is mearly the difrince in heads they use. both will make use of the 2bar map, and the mainfold. the FTE is the common upgrade given the fact that you dont need to swap the head to do it. but the GTE is posible, and also makes more power.
The Turbo
the Turbo you use is all up to you, but the simplest is the CT26 that comes stock on the 3sGTE, they are cheep as far as turbo's go and they work well for low boost aplications.
another turbo you can use is the CT20b, its the JDM turbo that came on 3sGTE's and it blows the door's off the CT26, its a comon MR2 Turbo Upgrade, mostly due to the fact that it bolts right in with no adaptors.
you can use a t3/t4 Hybrid turbo, but for this you will need a flange to adapt the 3s turbo mainfold to take the difrent bolt pattern. these t3/t4 hybrids are good turbos, and make good power, but are not intended to be amazing high preformance drag/race turbos. dont get me wrong, they will make good bost and shure blow you away when you get them under the hood, just dont expect to make 500 HP with them.
Fuel System
Given the fact that this upgrade know's no bounds on how much you want or can spend on it, the fuel system is somthing to take into acount. if your runing low boost (4-8PSI) then you dont realy need to upgrade the injectors on the fuel system, but if you plan on making 300+HP then you will need to look into larger injectors, and a biger fuel pump, other then that if u want more then 400+HP you will have to do your own dam reserch .
Exhaust and Piping
the Down pip for the turbo needs to be costom fabricated by an exhaust shop, you also need to install a new catilitic converter so that you stay street legal.
the intake piping is also a spot inwitch some costom work needs to be done. silicone and alunimum tubing with pipe clamps are inorder, but you need to decide on an intercooler (or no intercooler) this will afect your piping plans, but all in all you need to look into geting some costom tubing.
Oil Lines
Given the fact that the 3sGTE and the 5s are of the same sieres you can interchange oil pans from them, and to hook up the oil return line for the CT26, you need to ither put a second gen 3sGTE oil pan on the car, or tap a costom oil line onto the stock 5s Pan.
Drive Train Upgrade information
Acording to a handfull of people the Automatic 5s's cant realy take the added power seen in a 5sFTE upgrade. but more over some people might have so much work needed to be done to the over all drive train, that a 3sGTE swap is actualy a better option, this is nothing more then swaping in a 3sGTE mottor for your stock 5sFE, and swaping out all your electronics, and ECU to run the mottor.
Price Guide
Price's are all over the place on doing this upgrade, there is a kit that cost's $2500 that can be found at... http://www.poweredbytoyota.com/ssfeturbo.html
now this kit is rather "Hassel Free" and alot of what you pay for is the "hassel free" nature of the kit. understand tho its a bair bones kit that dosenot have an intercooler or any bost controlers/turbo timers, or anything to that efect.
the more low cost way to do this is to dig up parts. as such this is an idea on price's for those parts.....
:Used:
Exhaust Mainfold - $40-$50 is a good price for one of these. always get it machined and reserficed before you mount it (then tend to be warp when removed)
:Used:
CT26 - $100 - $300 for $100 you should be geting one in working but "in need of rebiuld" condition, while a $300 one should be in good working condition. (do reserch on used turbos to know how to identify the condition of a turbo)
:Used:
CT20b Turbo $400-$600, these are expensive but well worth it
(serfice the turbo flange on ither turbo when u get them used)
:NEW:
2Bar MAP - $260 pain in the but to find new, but the dealership sells them for 260 somthing. dont waist your time with a used one IMO, just bite the bullet and get the new one.
1991 Toyota Celica Red, Gray Interior, 5spd, 2.2L
My New Toy 3-1-04
Zrain is offline   Reply With Quote
Old 10-12-2004, 11:13 PM   #2
FLEX92GTS
Trader Rating: (0)
View FLEX92GTS's Photo Gallery
Hey Thanks for that posting! Very Nice! Could you please indicate a price range for these upgrades? I might own a 92 celica gt-s. If I decide to go turbo shoudl I do a turbo upgrade or an engine swap since it is automatic?
Thanks
FLEX92GTS is offline   Reply With Quote
Old 10-13-2004, 10:02 AM   #3
trebor_9513
trebor_9513's Avatar
Trader Rating: (0)
View trebor_9513's Photo Gallery
this needs to be a sticky in this forum!!! What about it? This is the stuff people drool for.
trebor_9513 is offline   Reply With Quote
Old 10-14-2004, 02:45 PM   #4
silverstreakin
camrys blow off too!
Trader Rating: (0)
View silverstreakin's Photo Gallery
fyi 3s engines dont use a map with the exception of the rav 4. 3s engines that are found in celicas use a gate type maf
93 toyota mark II tourer V
1jz-gte twin turbo goodness!
93 toyota scepter turbo stored back in the states!
*in loving memory rapeacivic*
silverstreakin is offline   Reply With Quote
Old 10-14-2004, 03:02 PM   #5
Aaagogo
F'ing 3sgte swap ARGH!!!!
Aaagogo's Avatar
Trader Rating: (0)
View Aaagogo's Photo Gallery
awesome write up
definitely shd be a sticky....
could u include some info on the injectors and fuel pump info. thanx.
My New Toys; Canon 30D, 28-135 W Hood, 50 1.4 W Hood, 580EX.
Future purchase, EFS 10-22, EFS 17-55, 70-200 IS 2.8L
In golf as in life it is the follow through that makes the difference.
Aaagogo is offline   Reply With Quote
Old 10-14-2004, 03:56 PM   #6
pog0
Trader Rating: (0)
View pog0's Photo Gallery
The CT26 runs out of breath at 14 psi.
The 3SGTE manifold doesnt warp when removed, it was a problem with the 7 stud manifold that came on the early 3SGTEs. This problem was fixed with the 9 stud manifold from later US 3SGTEs.
As for parts needed to make a turbo 5S would be more than what you listed. You would want both your manifold and turbo to come from a second gen 3SGTE, as with the oil and water lines. Not too sure about the map sensor since I dont have a 5S. You would also need a 3SGTE oil pan for your return line. There are many more things that come into play. As for exhaust, I believe you can use the stock 3sgte downpipe and cat or go aussie. I do remember seeing someone put an entire Greddy 20G for a 3SGTE on a camry.
Kevin
92 ST185 RC Converted
pog0 is offline   Reply With Quote
Old 10-14-2004, 11:42 PM   #7
CamNub
The Greatest
Trader Rating: (4)
View CamNub's Photo Gallery
18 PSI w/o intercooler is just plain unsafe. If you really want to risk blowing your engine, Go for it.
I dun think you should tell ppl to run that high. Even 8 psi is pushing it, at least for camrys it is...
CamNub is offline   Reply With Quote
Old 10-14-2004, 11:46 PM   #8
Zrain
Trader Rating: (0)
CamNub can u actualy read the post, 18 is with an intercooler...
pog0 thanks for the info forgot all about the oil pain.. (it was alot to get down when i put all the info together... i will update
My New Toy 3-1-04
Old 10-19-2004, 07:51 AM   #9
Aaagogo
Aaagogo's Avatar
Trader Rating: (0)
may i ask, what are the general gagues that one wold need to get?
i dun wan to have my dash board clustered up with too many guages, cause i wanna sleeper
Old 10-19-2004, 08:01 AM   #10
MRQtwinturbo
TN Post Wh*re
MRQtwinturbo's Avatar
Trader Rating: (2)
View MRQtwinturbo's Photo Gallery
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 10-20-2004, 10:54 PM   #11
fiveSFE
Banned
Trader Rating: (0)
View fiveSFE's Photo Gallery
u should get an digital air fuel meter gauge, boost gauge, and a egt(exhuast gas temp) gauge.
i think it is a good write up, but it is also missin soooo much stuff, like blow off valve, piping, ic, i would get injectors, and a fuel pump also.
im parting my own turbo together right now, ima be using a supra tt fuel pump, wit the older 7mge light green top injectors which are a direct fit.
and u dont have to custom fab ur own downpipe, just use one off a 3sgte, u do have to do a custom exhuast though.
it is also highly recommended to run somekind of engine managment system wit the turbo. and a msd btm to ctonroll timing.
here is what i have so far wit my setup:
jdm ct26
9 stud twin entry manifold
dsm blow off valve (free)
msd btm
supra tt fuel pump
about to buy a 2 bar map sensor and downpipe for 140 shipped tonight
also buying oil lines tommarow for 25 shipped.
my coolant lines came wit the turbo
fiveSFE is offline   Reply With Quote
Old 10-24-2004, 01:59 PM   #12
1995CAMRY
Trader Rating: (0)
View 1995CAMRY's Photo Gallery
can u put a 3sgte head on a 5sfe block? thanks
1995CAMRY is offline   Reply With Quote
Old 10-25-2004, 03:03 AM   #13
EggBeater59
Trader Rating: (0)
View EggBeater59's Photo Gallery
some accessories that are almost necessary (or at least very nice to have with the car) are blow off valves, turbo timers, boost controllers, and definately a boost guage. alot of people have been running into the ecu wiring problem. you definately want to find someone who has done this swap before you get started and take your camry out of commission. and you definately want a fmic. no matter what, unless you get an all trac hood. even then, though, fmics are considered better in the long run. oh, and make sure you run premium... don't want to start detonating. watch that temp guage!
my 2 psi.
EggBeater59 is offline   Reply With Quote
Old 10-25-2004, 03:48 AM   #14
CamNub
The Greatest
Trader Rating: (4)
Sorry. My mistake.
But what about the 4-8 thing. I have heard that 6psi is basically the most your stock internals can handle. At least that is for camrys. I assume it should apply?
Old 10-29-2004, 01:17 PM   #15
trebor_9513
Trader Rating: (0)
just to clarify is it a Map sensor or a Maf sensor? Just want to make sure I am looking for the right part. Still learning.
vB code is On
Forum Jump
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Page generated in 0.18832 seconds with 13 queries
