Warning: parse_url(http://) [function.parse-url]: Unable to parse URL in /includes/class_bbcode.php(181) : eval()'d code on line 68
CAMRY FAQ ***READ FIRST*** - Toyota Forums :: Toyota Nation
» Sponsors
» Sponsors
Go Back   Toyota Forums :: Toyota Nation > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > General Camry Discussion
Register Home Forum Active Topics eBay Marketplace Photo Gallery TN Arcade Blogs Mark Forums Read
General Camry Discussion Discussion area for every generation of Toyota's family car, the Toyota Camry. Lexus ES250/300 owners welcome! Topics of discussion range from fuel economy, safety, modifications, performance and more.
Please Visit our Site Sponsors
Closed Thread
Thread Tools Display Modes
Old 07-21-2002, 11:58 AM   #1
EKam
There is no substitute.
EKam's Avatar
Trader Rating: (5)
View EKam's Photo Gallery
Camry Faq ***read First***
Please visit the ULTIMATE CAMRY FAQ
S2000 Antenna Conversion
- Spectra Blue Cam
THE CELICA/S2000 CONVERSION WAS AN UNQUALIFIED SUCCESS!!
I had toggle switch to get my antenna up and down because unlike the factory decks, aftermarket ones don't care whether you're listening to the radio or not, it goes up all the time. With that switch I can put up the antenna only when necessary. But my recently-added RMM wing hits the antenna when the trunk lid is up. Also, it doesn't go up all the way anymore. So I've been investigating into doing the conversion.
I knew it was a good sign when only one day after I was told the S2000 antenna was backordered for weeks, it arrived.
The whole process took about 45 minutes. 25 of those minutes were spent twisting and bending the antenna bracket to bolt onto the support.
Here's the deal:
1. S2000 antenna - PN 39151-S2H-E01, $34.26
2. Celica sub-antenna (includes bracket) - PN 86309-20300, 35.60
3. Celica antenna nut - PN 86396-20030, $15
The prices are from Sisley Hondau (Yonge and Steeles) and DVNLT. Prices are in CDN, before taxes.
It's basically a bolt-on exercise. The only modification required was to trim a bit off the bottom part of the "antenna ornament" (official parts dept. name for the rubber boot on the rear quarter panel around the antenna). As mentioned, the most challenging part was twisting the bracket which came with the antenna to meet the existing bolt hole.
Reception is excellent.
- extra info + (DIY w/ PICS) - http://www.toyotanation.com/forum/t65507.html
Gen3 Indiglo Install
- rayray
http://www.imagestation.com/album/?id=4292103119
Gen 4 Indiglo Install
- Racer_Rodney
http://www.toyotanation.com/forum/t59805.html
GEN 3 SPRING OPTIONS AND OPINIONS
-w/a body kit - Intrax 1.75" are better riding than Sprints 1.8" or VIS
Coilovers
-w/out a body kit - I have come to the conclusion that H&R's offer the best
of looks (w/ the right size tires and rims), comfort and sharp handling w/a
1.25" drop.
Your other options are Eibachs 1.0" and B+G 1.6"
The Eibach drop is not really noticeable. I personally want the drop of the
B+G's (w/ 215/50/17's I should get about a 1.5 finger gap in front and 1
B+in back) but I've heard very mixed reviews on them. Everything from "identical to Eibach", "Love em to death" and "they're mushy"
I don't know if mushy is a bad thing tho. I think of stock as mushy. If
mushy in this case means softer ride and less (but still better than stock)
cornering stability... tha'd be ok by me.
I'd say the ideal size and proportion rim/tire for a gen3 is... 215/50/17 - 215/45/18 - (w/a low drop) xxx/40/18
Gap in finger width w/ 215/50/17... ( -F / R- )
Eibach 3-3.5 / 2.5-3
H&R 2.5 / 2
B+G 2-1.5 / 1.5-0.5
Intrax 1.5-1 / 0.5-tuck
Vogtland 2.5 / 2
Sprint 1 / tuck
VIS c/o adj. / adj.
JIC Majic c/o adj. / adj.
FYI - Struts and tire profile make a diff in stifness.
KYB's will be softer than Tokico's and the lower profile you go the harsher
the ride.
CORNER LAMP FLASHERS
- 88 LE
Cut the ground wire for the parking light. Tape off the end that goes to the
car (you won't be using it anymore).
Splice the ground wire from the parking light (the bulb socket) to the alternating +12V
wire of the blinker. You'll need a piece of wire and some crimps to do this.
Parking lights off = parking light and blinker both blink at the same time.
Parking lights on = parking light and blinker blink alternately.
Remember to cut the ground wire on the parking light and only use the end that
goes to the bulb socket. Otherwise you'll end up with blown fuses. Also verify the wires with a DMM before you cut and splice.
Wires on a gen 2 (87 - 91) Camry
Ground wire on corner light = white wire with black stripe.
Alternating +12V wire on blinker = green wire with yellow stripe.
Pictures:
http://www.toyotanation.com/forum/sh...4&page=2&pp=15
MORE LIGHT
- bluemeanie
Ellipsoid headlights produce a yellowish pattern of light on the ground. We
all agree that more light is needed. Even $400usd for the HID upgrade is a
lot of money. But some people found out that the 9005 bulbs can be modified to fit the 9006 sockets of the Toyota Camry.
This works only on ellipsoid.
I have experimented with the Sylvania Cool Blue 65W 9005 ($12usd ea.), Pilot Greenish blue somethings 65W 9005 ($20usd ea.), GE Blue Vision 65W 9005 ($12usd ea.) and the latest, Sylvania Silverstar 65W 9005 ($29usd ea.) and was really happy with the brighter light across the board.
Hands down, Sylvania Silverstar 65W 9005's are the best, the brightest, the
longest lasting (I've had mine in for two years now) and the whitest.
Why I'm using a 9005 bulb: 9005 bulbs are 65W and are not capped at the end, 9006 bulbs are 55W and have a cap at the end. The light increase is from the increase in lumens from the 9005 bulb. A 9005 bulb has 70% more lumens than the 9006 (1700 lumens vs 1000 lumens). HID has
3200 lumens. You have to slightly modify the 9005 bulb to fit the 9006 socket.
Supplies
*File or chisel tools, Sharp knife, blade, soldering iron or Dremel like tool.
*2 x 9005 bulbs.
*Protective glasses and gloves (you don't want to lose a finger or an eye). :P
Procedure
1. Remove 3mm of plastic from the left of the center of top tab when the
socket is pointing down until you have 5-6mm of plastic left.
2. Remove the two guides inside the socket. Install 1 new O'ring from the
old 9006 bulb on the new modified 9005 bulb to ensure a tight fit.
3. Install the bulbs in your car and have your light adjusted if not
already.
pics from - www.BMWE34.net
FYI -
It is also possable to modify the harness on the car... but I don't recomend
it. I've seen way too many afm harnesses melt or worse melt the fuse box. On the Gen3 (1992-1996) Toyota Camry both the high beam and low beam harnesses are designed to carry a max load of 65wats safely
HIR bulbs - Update: New type of lighting - HIR bulbs.
Gen3 and 4 Loose Seat Back DIY Fix
- Morley
It cost me nothing but 2 washers, and about 4 hours of my time.
I can do it in about 2 hours now that I know exactly what needs to be done to fix the problem.
Unfortunately I would have taken some pics, but my friends girlfriend dropped my digicam a few weeks ago and needless to say it's finished.
So I will try to explain this as best I can.
1.) Remove defective seat
2.) Put seat on bench, and flip upside down
3.) Remove all 4 bolts that hold the guide rails to the underseat.
4.) The seat is still attached via the tilt hinges, but the rail assembly can now move a little.
5.) Remove the side bottom peaice of plastic on the seat. (Not the peice with the power buttons on it, but the one below it)
6.) You will see 2 different bars (shafts) that go across the bottom of the seat, one will be rusty and the other one is black. They are both held on by C Rings. If you play with the bars you will notice alot of play from side to side, and up and down. This is where the problem is.
7.) Remove only 1 C ring from one bar, and then remove only 1 C Ring from the other bar.
Whichever side you decide to remove on the black bar, remove the opposite side on the rusted bar. This is to distribute the shim load you are about to fabricate.
8.) You need 2 washers that the center hole have a diameter large enough so you can slide it onto the shaft. Exact size, Im not sure, I just had some old washers in my junk drawer.
9.) Once you have 2 washers that will fit onto the shafts, you need to grind the washers down so that they are very thin. Otherwise you will not be able to snap the C Ring back on after.
This takes alot of grinding, and test fitting, and then more grinding etc.. you get the picture.
10.) Once you have the washers at the right thickness, install on shaft ends, and reinstall C rings, and put the seat back together.
11.) Test drive and you will see that the problem is gone.
I have asked the dealer about fixing the problem and they wanted to replace the entire seat. Also looked online for quite some time now, and nobody has posted a fix for this common problem. So I hope this will help others
I know this problem really bothered me, and was the only thing on the Camry that I could not stand. So I did one of my custom jobs once again..
Gen5: change gauge color
http://www.sounddomain.com/member_pa...257&page=6
GEN 3- CLEARING HEADLAMPS - DIY
- thisdj78
http://www.toyotanation.com/showthre...threadid=22858
How to change the power steering fluid
- Ken4
http://www.toyotanation.com/forum/t19334.html
Adjusting Trunk Springs DIY
-Hajoca
http://www.toyotanation.com/forum/t78342.html
Acoustic Control Induction System DIY Mod (ACIS)(v6 models only)
-2wickedtoyz
http://www.toyotanation.com/forum/t45066.html
How to install a intake on a gen 4 w/5S-FE
#1 http://www.toyotanation.com/forum/t81698.html (http://209.160.1.32/Intake) -mike6789
#2 http://www.toyotanation.com/forum/t86710.html -brink
How-To Guide: Struts and Spring Install
http://www.toyotanation.com/forum/t86545.html
Automatic to Manual Transmission Swap
http://www.tt-cc.com/ratko/swap/index.html
Gen4 Guage bulb replacement / Color change
(Needle Color Change w/ indiglos)
http://www.toyotanation.com/forum/t88355.html
How-to change brake pads
-nort0188
http://www.toyotanation.com/forum/t92082.html
DIY CAI (gen 3)
http://www.toyotanation.com/forum/t92453.html -Brujo
http://www.toyotanation.com/forum/t36348.html -brungold
DIY cold cathode trunk light
-brungold
http://www.toyotanation.com/forum/t88727.html
Shift knob with o/d button install
-brungold
http://www.toyotanation.com/forum/sh...441#post302441
How to program keyless entry remote (gen 4)
-keithy
http://www.toyotanation.com/forum/t96974.html
Rack & pinion and 2 Axels Replaced (gen3)
http://www.toyotanation.com/forum/t108185.html
DIY: Gauge Needle Color Change
DIY: Gauge Needle Color Change #2
Clock Color Conversion
DIY: Shifter Lights Color Change
DIY: Cold Cathode Trunk Installation
DIY: Stereo LED Color Change
How-to remove headlights (gen 3)
-YESCA
http://toyotanation.com/forum/t128837.html
Whiteline RSB install (gen 4)
-Hajoca
http://toyotanation.com/forum/t143574.html
Door panel removal (gen 4)
-Delay_FTB
http://toyotanation.com/forum/t145402.html
How-to change timing belt (5s-fe)
http://toyotanation.com/forum/t109966.html -Ken4
http://toyotanation.com/forum/t149232.html -JerryGiese
EKam is offline
Old 03-05-2004, 05:19 PM   #2
BLUEMEANIE
hogdoggin'
BLUEMEANIE's Avatar
Trader Rating: (7)
View BLUEMEANIE's Photo Gallery
Research and construction of orig. thread courtesy of Razo-E
BODY KITS/WINGS...
these are just the ones i found, if you have a kit/wing that is NOT here, please post link/info...
94 Accord side skirts can be used on Gen.3 Camrys...
more info:
http://forum.toyotanation.com/showth...500&forumid=15
Kits are sorted by website, NOT specific model, so please read descrptions carefully...
-www.Erebuni.net
-www.Erebunicorp.com
http://www.erebuni.net/clearance/tocamry.htm <--Gen. 3 camry-Clearance
http://www.erebuni.net/ge/toycamry.htm <--Gen.2 camry-Full Body Kit
http://www.erebuni.net/ge/toycamry92.htm <--Gen.3 camry- FUll body kit
http://www.erebuni.net/wings/toycamry92.htm <--Gen3/3.5 camry wings
http://www.erebuni.net/ge/toycamry97.htm <--Gen4.camry-Full Body kit
http://www.erebuni.net/ge/toycamry00.htm <--Gen 4.5 camry- Full body kit
http://www.erebuni.net/wings/toycamry97.htm <--Gen.4/4.5 camry-wings
http://www.erebuni.net/wings/lexes300.htm <--Gen. 2 ES300-Wing
http://www.erebuni.net/wings/toyavalon00.htm <--Gen.2 Avalon OEM wing
-www.Wholesalehyperformance.com
http://www.wholesalehyperformance.com/kits1-main.html <--Gen1 Solara-full Body kit/ Gen 3/3.5-Camry full body kit/Ge.n 4/ Camry-Full body kit
-www.Carmate.com/au (Not a guaranteed fit: australian Gen. 3 camrys have different bumper lights, and will not fit USDM bumper lights)
http://www.carmate.com.au/Camry92.htm<--Gen 3 camry-Full body kit
http://www.carmate.com.au/92CAM-C-FBS-SS.htm <--Gen 3camry-Full body kit
http://www.carmate.com.au/92CAM-CB-FBS.htm<--Gen 3 camry-Full body kit
http://www.carmate.com.au/97CAM--TCR...CAM--X--SS.htm <--Gen 4 camry-full body kit (might not fit USDM headlights)
-www.ToyotaParts4U.com (random car images, please contact specific owner [if available] for information on their car)
http://www.toyotaparts4u.com/show_us...mry_solara.htm
-www.bodykits.com
http://www.bodykits.com/fullview.php...option_price=0 <--Gen. 5 Camry-full body kit
http://www.bodykits.com/fullview.php...option_price=0<--Gen. 5 Camry-full body kit
http://www.bodykits.com/fullview.php...option_price=0 <--Gen.1 Solara-full body kit
-www.tsunami1.net
www.tsunami1.com/products_aero/lexus/es300.htm
www.tsunami1.com/products_aero/lexus/es300_2.htm<--Gen 2. Lexus ES300-full kit
-www.rodmillenstore.com
http://www.rodmillenstore.com/camry/92_lip.htm <--Gen3 Camry-Front lip ONLY
http://www.rodmillenstore.com/camry/95_front_34.htm <--Gen 3.5 Camry-Front lip ONLY
http://www.rodmillenstore.com/camry/touring_1.htm <--Gen3/3.5 Camry-Wing
-http://www.cardomain.com/memberpage/308612 <--Custom Avalon Kit there ARE no ready made kits for the Avalon, in USA/Canada
-www.pacifictoyota.com/au
http://www.pacifictoyota.com.au/p_acc_avalon.htm <--Australian Avalon Sportivo, scroll to middle to see price...
-www.streetbeatcustoms.com
http://www.streetbeatcustoms.com/avalon.html <--3 Avalon Wings
http://www.streetbeatcustoms.com/camry.htm <--various wings for Camry/Solara
-www.jtautostyle.com
http://www.jtautostyle.com/whole.htm <--Various Gen.3/Gen 4/4.5/Solara Body kits
-www.visracing.com
http://www.visracing.com/catalog/adv...keywords=camry <--Gen.3/ Gen4 body kits
http://www.visracing.com/catalog/adv...eywords=solara <--Gen.1 Solara body kits
-www.importfan.com
http://www.importfan.com/product.asp?0=0&1=0&3=6132
http://www.importfan.com/product.asp?0=0&1=0&3=6133
http://www.importfan.com/product.asp?0=0&1=0&3=6134 <--Gen.3 ES300 front/rear/sides
http://www.importfan.com/search.asp?7=camry <--Various Camry body parts
http://www.importfan.com/search.asp?7=solara <--Various Solara body parts
-www.nopi.com
http://129.33.208.33/ecat2004/dsp_pa...&vtitle=TOYOTA Avalon 2000 <--Gen.2 Avalon wings
http://129.33.208.33/ecat2004/dsp_pa...&vtitle=TOYOTA Avalon 1997 <--Gen.1 Avalon wings
http://129.33.208.33/ecat2004/dsp_pa...&vtitle=TOYOTA Camry 1989 <--Gen.2 Camry Body kit
http://129.33.208.33/ecat2004/dsp_pa...&vtitle=TOYOTA Camry 1998 <--Gen 4 Camry Body kits
http://129.33.208.33/ecat2004/dsp_pa...&vtitle=TOYOTA Camry 2000 <--Gen. 4.5 Camry Body kit
http://129.33.208.33/ecat2004/dsp_pa...&&vtitle=LEXUS ES300 1992 <--Gen.2 ES300 (tsunami kit)
link courtesy of Phi...
-www.vizages.com
http://vizages.com/toyota-camry-info.htm <--Gen. 5 Camry
links courtesy of Phi...
-www.carismaautotec.com
http://www.carismaautotec.com/Aero02...OYOTA&offset=0 <--Gen.1 Solara and Gen.5 Camry (+more)
links courtesy of BLUEMEANIE...
-http://www.carlsson.de/en/race/engin...gineering.html
http://tt-cc.com/Photo/carlsson3.jpg
http://tt-cc.com/Photo/carlsson2.jpg
http://tt-cc.com/Photo/carlsson.jpg <--Gen.3 Camry (grill and bumper only)
-www.aeroduo.com
http://tt-cc.com/Photo/blackwidow2.jpg
http://tt-cc.com/Photo/blackwidow.jpg <--Gen.3 Camry full kit (no longer in production)
BLUEMEANIE is offline
Old 04-29-2004, 12:06 PM   #3
BLUEMEANIE
hogdoggin'
BLUEMEANIE's Avatar
Trader Rating: (7)
-MISC. ACCESSORIES...
NOTE: If there is a link here, then there IS/ARE (a) Camry/Solara/Avalon/ES(300/330) part(s), and may require a little bit of searching...
NOTHING here is a guaranteed fit, PLEASE read information given CAREFULLY, and as always BUYER BEWARE...
Some V6 engine parts are interchangable between these models...
Gen.2 Camry/Gen.1 ES(250) V6 =2VZ-FE...
Gen.3 Camry (except 94)/Gen.2 ES(300) V6=3VZ-FE...
Gen. 3(94+)-Gen.5 Camry (except 2004+ SE), Avalon, Solara/ ES(300) V6=1MZ-FE...
Gen.5 Camry (2004+ SE), Gen.2 Solara, ES(330) V6=3MZ-FE...
Some I-4 engine parts are interchangable between these models...
Gen.2 Camry/ Gen.4 Celica GT(non-all trac) I-4=3SFE..
Gen.3-Gen. 4.5 Camry/ Gen. 5 Celica (non all-trac)/MKII (Gen.2)MR2(NON-turbo) I-4=5SFE...
Gen.5 Camry/Scion tC I-4=2AZ-FE...
(also Highlander/RX(300/330)/Sienna/Celica/MR2/tC parts MAY also be interchangable if equipped with same engine, but not guaranteed due to revision(s) over the years...)
for a little more info on Camry Engines, visit:
www.tt-cc.com
http://www.tt-cc.com/spec.htm
(Universal DOESNT guarantee a perfect fit, may require modifications..)
-www.autoclearguard.com
--Clear Protective Car bras...
http://>http://www.autoclearguard.com/painttoyota.htm <--Toyota...
http://www.autoclearguard.com/paintlexus.htm <--Lexus...
-www.customautotrim.com/index.html
--Dash Kits...
http://www.customautotrim.com/wood-d...og_camry92.htm <--Gen. 3 Camry...
http://www.customautotrim.com/wood-d...og_camry94.htm <--Gen. 3.5 Camry...
http://www.customautotrim.com/wood-d...og_camry97.htm <--Gen. 4 Camry...
http://www.customautotrim.com/wood-d...og_camry98.htm <--Gen. 4.5 Camry...
http://www.customautotrim.com/wood-d...og_camry01.htm <--Gen. 5 Camry...
http://www.customautotrim.com/wood-d...g_avalon95.htm <--95-99 Avalon...
http://www.customautotrim.com/wood-d...g_avalon00.htm <--01 Avalon...
http://www.customautotrim.com/wood-d...g_solara99.htm <--Gen. 1/1.5 Solara...
http://www.customautotrim.com/wood-d...g_es300_95.htm <--Gen. 2 ES300...
http://www.customautotrim.com/wood-d...g_es300_97.htm <--Gen. 3 ES300...
http://www.customautotrim.com/wood-d...g_es300_02.htm <--Gen. 4 ES300/330...
--(search) misc. accessories...
http://www.customautotrim.com/cgi-bin/search/search.cgi <--ES300/Solara/Camry/Avalon...
--Wings...
http://www.customautotrim.com/spoile...poilers772.htm <--Gen.3 ES300...
http://www.customautotrim.com/spoile...poilers854.htm <--Gen.4 ES300/330...
http://www.customautotrim.com/spoilers/toyota_wings.htm <--Camry/Solara/Avalon...
--Universal wings....(Universal WONT guarantee a perfect fit may require modifications...)
http://www.customautotrim.com/bodyki...univ_wings.htm
--Clear Lights...
http://www.customautotrim.com/tail-l...ghts-92-94.htm <--Gen.3 Camry...
http://www.customautotrim.com/tail-l...ghts-95-96.htm <--Gen. 3.5 Camry...
http://www.customautotrim.com/tail-l...ghts-97-99.htm <--Gen. 4 Camry..
http://www.customautotrim.com/tail-l...ghts-00-01.htm <--Gen. 4.5 Camry...
http://www.customautotrim.com/tail-l...ghts-98-02.htm <--Solara (cant confirm if it's for Gen.1's or 1.5s which most likely WONT interchange, contact site for more info)...
--Lamborghini doors...(Universal DOESNT guarantee a perfect fit, may require modifications..)
http://www.customautotrim.com/bodyki...oors/index.htm
--hood scoops...(Universal DOESNT guarantee a perfect fit, may require modifications..)
http://www.customautotrim.com/hood_s...ota_models.htm
--Universal Air Ducts...(Universal DOESNT guarantee a perfect fit, may require modifications..)
http://www.customautotrim.com/bodyki..._air_ducts.htm
-www.goldplated.com
--Gold/Black pearl Emblems...
http://www.goldplated.com/goldpackages.htm
-www.partznet.com
--misc accessories.....
http://www.partznet.com/toyota/camry...20accessories/ <--Camry...
http://www.partznet.com/toyota/solar...20Accessories/ <--Solara...
--Floor mats...(Most likely universal, DOESNT guarantee a perfect fit, may require modifications...)
http://www.partznet.com/toyota/camry...ETHERMATS.HTML <--Gen.4-5..
-www.toyotaworld.com
--spoilers...
http://www.toyotaworld.com/accessories/spoiler_rear.htm
-www.toyotaterritory.com
--Camry TRD parts...
http://www.toyotaterritory.com/camry.asp
http://www.toyotaterritory.com/trdperformance.asp <--Misc. TRD parts (MAY OR may NOT fit your car, read description(s) CAREFULLY
-http://www.keystonerestyling.com/
--Wings (under good wings)
-https://rsp-secure.com/fastlane_toyota/
--Various AUSSIE Toyota Parts....
-http://www.eautoworks.com/
--Misc. parts...
http://www.eautoworks.com/html/home-...amry&excet=all <--Camry...
http://www.eautoworks.com/html/home-...lara&excet=all <--Solara...
http://www.eautoworks.com/html/home-...alon&excet=all <--Avalon...
http://www.eautoworks.com/html/home-...S300&excet=all <--ES300
Old 04-29-2004, 12:09 PM   #4
BLUEMEANIE
hogdoggin'
BLUEMEANIE's Avatar
Trader Rating: (7)
-MISC. ACCESSORIES AND BODY KITS...
-www.andysautosport.com
http://www.andysautosport.com/toyota/92_96camry.html <--Gen.3/3.5 Camry Kits/Accessories...
http://www.andysautosport.com/toyota/97-01camry.html <--Gen.4/4.5 Camry Kits/Accessories...
http://www.andysautosport.com/toyota/02-upcamry.html <--Gen.5 Camry kits/accessories...
-www.extremedimensions.com
http://www.extremedimensions.com/sho...amr y+92%2D96 <--Gen.3/3.4 Camry Kits/Accessories...
http://www.extremedimensions.com/sho...amr y+97%2D01 <--Gen.4/4.5 Camry Kits/Accessories...
http://www.extremedimensions.com/sho...am ry+02%2D04 <--Gen. 5 Camry kits/Accessories...
http://www.extremedimensions.com/sho...l ara+99%2D02 <--Gen.1 Solara kits/accessories...
http://www.extremedimensions.com/sho...S30 0+97%2D01 <-- Gen.3 Lexus ES(300) Kits/Accessories
-www.tte.de
http://www.tte.de/tuning/website/Acc...-camry-v2.html <--Gen.4 Camry Kit/Accessories...
http://www.tte.de/tuning/website/com...-external.html <--Gen.5 Camry accessories...
-www.importhookups.com
http://www.importhookups.com/Lightin...ils/TOYOTA.htm <--Gen.3 Camry Clear tails...
http://www.importhookups.com/Engine%...ake/toyota.htm <--gen3-gen4 Camry 5SFE Intake...
http://www.importhookups.com/Engine%...ust/toyota.htm <--Gen. 4/4.5 5sfe/Gen.1 Solara Catback...
http://www.importhookups.com/Suspens...ngs/Toyota.htm <--Gen. 3-4.5 Camry lowering springs..
http://www.importhookups.com/Suspens...cks/toyota.htm <--Gen.2-3.5 Camry performance struts...
http://www.importhookups.com/Suspens...ars/TOYOTA.htm <--Gen.3/3.5 Camry Strut bar..
http://www.importhookups.com/Accessories/Dash_Trims.htm <--Gen 4/4.5 Camry dash trim overlays...
http://www.importhookups.com/Accesso...obs_Pedals.htm <--shift knobs...
-www.erebuni.net
-www.erebunicorp.com
http://www.erebunicorp.com/ge/LEXES300.HTM <--Gen.4 Lexus ES (300/330) Body kit...
-http://www.autobodypartsonline.com/
OEM body parts...
-www.centerforce.com
http://www.centerforce.com/centerforcesearch.tpl <--misc. tranny parts...
http://www.centerforce.com/centerfor...Ldatarq=ES-250 <--Gen.1 Lexus ES(250) Clutches...
http://www.centerforce.com/centerfor...Ldatarq=ES-300 <--Gen.2 Lexus ES(300) Clutches...
http://www.centerforce.com/centerfor...datarq=CAMR Y <--Gen.1-4.5 Camry Clutches...
updated 3/26/04...
Old 04-29-2004, 12:10 PM   #5
BLUEMEANIE
hogdoggin'
BLUEMEANIE's Avatar
Trader Rating: (7)
-www.speedstash.com
http://www.speedstash.com/kits/toyota_camry_92_96.html <--Gen.3/3.5 Camry Bodykit (gen.4.5 pictured) ...
http://www.speedstash.com/kits/toyota_camry_97_01.html <--Gen.4/4.5 Camry Bodykits...
http://www.speedstash.com/kits/toyota_solara_98_01.html <--Gen.1 Solara body kit...
http://www.speedstash.com/toyota_di.html <--1mz-fe/3vz-fe/5sfe "Dragon" intakes...
http://www.speedstash.com/obxshortram.html <--1mz-fe/3vz-fe/5sfe "OBX short ram" intakes...
http://www.speedstash.com/nos.html <--NX Nitrous kit (Universal)...
http://www.speedstash.com/springs.html <--Gen.3/3.5 Camry/Gen.1/1.5 Solara lowering springs...
http://www.speedstash.com/goldline_l...g_springs.html <--Gen.4/4.5 Camry lowering springs...
http://www.speedstash.com/taillights...aillights.html <--Gen4.5 Camry Altezzas...
http://www.speedstash.com/taillights...aillights.html <--Gen.1/1.5 Solara Altezzas...
http://www.speedstash.com/clear/toyota/camry_clear.html <--Gen.3.5-4.5 Camry Clear corner lights...
-store.yahoo.com/streetbeatcustoms/index.html
http://store.yahoo.com/streetbeatcus...070330-2y.html
http://store.yahoo.com/streetbeatcus...070331-3n.html
http://store.yahoo.com/streetbeatcus...070332-2y.html <--says Gen.4.5 Camry, but appears to be for Gen.5 Camry...
http://store.yahoo.com/streetbeatcus...760-sy-d3.html <--Avalon Brake pads...
http://store.yahoo.com/streetbeatcus...440790-d2.html <--00-03 Avalon Brake Rotors...
http://store.yahoo.com/streetbeatcus...av95uptyp.html <--95-99 Avalon lowering springs...
http://store.yahoo.com/streetbeatcus...gtsgt0286.html <--Gen.1 Solara BLACK headlight covers...
http://store.yahoo.com/streetbeatcustoms/gtsgt4286.html <--Gen.1/1.5 Solara BLACK taillight covers..
http://store.yahoo.com/streetbeatcus...dglogaug9.html <--Gen.1/1.5 Solara speed glo guages...
-www.trenz.com
http://trenz.com/cust_frames.php <--Gen.3-4.5 Camry Billet Grills...
-www.zex.com
http://www.zex.com/store/merchant.mv... =Toyota-dKit <--Gen.3-4 Camry Nitrous Kit...
Updated 3/30/04...
Old 10-05-2004, 07:47 PM   #6
EKam
EKam's Avatar
Trader Rating: (5)
Getting the right tire size for your wheel
Springs & Struts Guide
IS300 Wheels & Gen3 4-cyl Camrys fitment problem
18/6/08 - Sayonara Kamuri!
EKam is offline
Old 02-12-2005, 02:19 PM   #7
BLUEMEANIE
hogdoggin'
BLUEMEANIE's Avatar
Trader Rating: (7)
- GEN3 GAUGE REMOVAL -
RADIO TRIM
1. CLIPS - two at bottom. Pry from bottom only.
2. PLUGS - 12v outlet/cig lighter
3. remove "U" shape trim around radio
CLUSTER SURROUND TRIM/BEZEL - Haynes Manual 11-13 (fig. 21.2b)
There are 4 screws and 4 clips.
4. DIMMER KNOB - remove dimmer knob by pulling. Unscrew flat nut around dial neck.
5. SCREWS - You have to remove the radio surround trim piece, exposing two screws, one on each side of the radio just under the heater/AC controls. The other two are above the gauges.
6. CLIPS - there is one to the left lower corner of the far left driverside vent. The second clip is just under the dimmer controler (you must also remove the dimmer knob and the thin lock nut under the knob). The third clipis to the right of the hazard button and the fourth is to the lower right corner of the right center air vent.
7. PLUGS - Power mirror adjustor. Clock. Hazard light button.
8. Pop those and the black trim can be removed.
CLUSTER - Haynes Manual 12-14 (fig. 19.3a)
9. SCREWS - To remove the cluster there are 4 obvious screws on metal tabs, two on the right and oen on the left and one on the bottom left.
10. PLUGS - Remove the two plugs at the top
11. and the cluster can be removed.
OPENING THE CLUSTER
12. SCREWS - To remove the glass cover I know there are two screws at the top and possibly two at the bottom.
13. CLIPS - Pry the clips along the top and the bottom.
14. seperate the glass from the cluster.
NOTE - failure to reconnect hazard switch will result in loss of turn signals.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
Old 07-08-2005, 11:05 AM   #8
BLUEMEANIE
hogdoggin'
BLUEMEANIE's Avatar
Trader Rating: (7)
Installing a gen4 Camry/gen1 Solara TRD Short Shifter into a Gen3
(also installing a gen4 TRD shifter into a gen4 assembly)
You will need an OEM gen4 Camry or Gen1 Solara shifter assembly (same part number) and TRD short shifter (the stick).
To remove the gen3 assembly remove both halves of the center console. Unbolt the assembly from the floor. Unclip the retainers where the cables go thru the front of the assembly. Unclip the cables from the shifter.
Swapping the TRD stick into the gen4 assembly is simple but a pita.
There is a collar over the stick pivot. On both sides of the collar there are hollow pins. all you have to do is punch out those pins and remove the collar and ring under the collar, remove the old stick, put in the new TRD stick and replace the ring, collar and pins. NOTE: be sure to place the oem white caps from the oem stick on the TRD stick
Installing the gen4 assembly into a gen3 is simple. All you have to do is cut the large tabs off edges of the gen4 assembly. If you set the two assemblies next to each other it will be obvious what needs to be removed. There is also a U shaped metal support at the seam between the two halves of the gen3 console you will need to cut the center of it out to fit the gen4 assembly leaving the two legs for the gen3 console to bolt back on to. Replace all the clips and cables and such and you're good to go.
For a more firm feel, remove the rubber floor bushings and bolt the assembly directly to the floor. It will need to be positioned to one side or the other so any bumps in the floor pan don't interfere with lower portion of the stick. I recomend throwing it thru the H including reverse a few times to make sure everything's clear because you will only have +1mm of clearence at the bottom of the stick at its lowest point.
Brass shifter cable bushings are also available at www.speed-source.net - their product quality is amazing. Also check out Alex's gen3 Camry w/a 3S-GTE
Closed Thread
vB code is On
Forum Jump
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Page generated in 0.53688 seconds with 13 queries
