2.5 to 2.4 swap issue - Toyota Nation Forum : Toyota Car and Truck Forums
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
post #1 of 3 Old 09-05-2017, 04:33 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hey guys.. New here. Have a little problem I'm hoping you can help with. I have a 09 rolled camry with 26k miles and a 2011 with 255k. I decided to swap all mechanical parts off the 09 to the 11. Suspension and all. Well everything is swapped with zero issues. The 2.4 and trans now lives where the 2.5 was. Everything seemed to bolt right up and plug right in. Only issue I'm having now is the engine will crank but not start. No spark. I'm guessing its a key/immobilizer issue. One other thing I did notice is the check engine light is pretty dim. I plugged the 2.5 way back in just to check the light circuit and it was bright with that ecu. Not sure why that is either.
Any ideas?
Also I'm looking for the procedure to link everything up.. Ecu, key, immobilizer
Thanks in advance
Teckarmy1 is offline
post #2 of 3 Old 09-07-2017, 09:17 PM
Senior TN Member
Quoted: 1883 Post(s)
Entire 2.4l engine + harness + ECU needs to be swapped together. Can't mix and match parts. Everything must come across.
DannoXYZ is offline
post #3 of 3 Old 09-07-2017, 09:34 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I did that. Engine. Complete harness. Ecu and transmission. I used nothing from the old engine or harness.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
User Tag List
Linear Mode Linear Mode
