2012 prius will not start. - Toyota Nation Forum : Toyota Car and Truck Forums
Prius 3rd Gen - Hybrid (2010-2015) Toyota Prius Hybrid discussion for years 2010-2015.
post #1 of 8 Old 09-13-2017, 02:33 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
message display says 'check hybrid system' car has 98000 one owner miles on it. closest toy dealer is 20 miles away and wants to tow it to shop. inverter coolant is above add mark. i even swapped in another 12v battery. shifter lever will only shift to neutral and the park button. and the light on power switch goes from green to amber. "ready" lite never appears either. and engine doesn't crank at all. i'm gonna look at all the fuses i see.
from the other posts it may be that the big battery died. maybe the desert heat did it in.
i had rotated the tires front to rear and then prius wont start. any ideas? thanks!
jascoi is offline
post #2 of 8 Old 07-21-2018, 02:38 PM
thedigitaltexan's Avatar
Quoted: 0 Post(s)
Did you ever find out the problem. Sounds like it could have been the inverter.
thedigitaltexan is offline
post #3 of 8 Old 07-21-2018, 03:25 PM
Quoted: 5 Post(s)
You'd think it would have been covered by the 8yr 100k mile Hybrid Warranty regardless. Just under the wire on miles unless it's California which may be longer.
schmidtj is offline
post #4 of 8 Old 07-21-2018, 03:51 PM
Quoted: 0 Post(s)
What did it take to fix it. The inverter has a 15 year warranty if it had the firmware update.
I'm just trying to get my 2013 v going.......
Thanks for the reply.
post #5 of 8 Old 07-23-2018, 10:34 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
After Reading the owners manual carefully and calling up Toyota dealers and speaking with the service advisors twice there was absolutely no valid information given in any of these attempts.
I had the car towed to the sanBERNARDINO Toyota dealer and after one day they discovered that the battery switch was turned off. they turn the battery switch back on... and the car works fine. Service charge for turning on the switch was $125. and I had to upgrade my AAA membership to get the car towed to the dealer. I emailed Toyota asking for reimbursement of my $200 expense based on the fact that no information was given in the owners manual or over the phone to check the battery switch. maybe I accidentally turned it off when I was getting the jack out of the car to rotate the tires.
jascoi is offline
post #6 of 8 Old 08-01-2018, 10:58 PM
Chris Boggs's Avatar
Quoted: 6 Post(s)
You don’t have a pic of the switch per chance? I’d love to know what to watch out for if this happened to me. Yeesh - a real oddball thing to happen but it could have been much worse I suppose.
‘95 Rolla ~ ‘11 Prius ~ ‘12 Camry Hybrid
(Past Toyotas: ‘82 FJ60 ~ ‘96 Avalon ~ ‘11 Camry)
www.spacemonkey.studio
Chris Boggs is offline
post #7 of 8 Old 08-08-2018, 11:58 AM
Moderator
ukrkoz's Avatar
Quoted: 867 Post(s)
Accidentally tripping that switch is rather impossible. It's well secured.
ukrkoz is online now
post #8 of 8 Old 01-26-2019, 01:29 AM
Quoted: 40 Post(s)
Doesn't sound right to me either. Plus stated happened when rotated tires.
DaneH is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Hybrid Forum > Prius Forum > Prius 3rd Gen - Hybrid (2010-2015)
Tags
hybrid failure
User Tag List
Linear Mode Linear Mode
