1989 Toyota Camry no spark - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 1st & 2nd Gen (1983-1986) & (1987-1991) Toyota Camry Discussion for years 1983-1986 & 1987-1991. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 58 Old 04-08-2019, 11:55 PM Thread Starter
Quoted: 7 Post(s)
(Thread Starter)
I have a 1989 Toyota Camry 3SFE engine with a crank but no start issue - no spark (this happened after I washed my engine bay btw - used simple green type liquid and water hose)
• No spark
• I tested the dist. and its good (99% sure)
• I tested the plug wires and they were real low in resistance - so replaced (came with new dist. cap)
• Tested a set of known operating spark plugs onto my car - didn't change anything
• Changed the igniter (for free @ junk.y,got 2)
• Battery is good like new
• Had the starter tested - good/passed
• I have fuel pressure
Now back to the distributor, these are the results of testing:
• Primary resistance of ignition coil = .6 ohms (not 100% sure if this is out of spec or ok, for 3SFE engine spec is .38 - .46 ohms)
• Secondary coil resistance = 8.93k ohms (spec for 3SFE is 7.7 - 10.4k ohms)
• Ignition coil + terminal to ground = is 0v, 40.7 ohms, 40 continuity
• Harness connector for the top terminal of the distributor is 11.92v (black/orange wire, ign. on)
• Top terminal on distributor = .01v both wires
• .07v for all wires on harness connector for the right terminal on distributor (ign on)
• Resistance of pick up coil is in spec (140-180ohms)
• Power for igniter harness connector = 11.93v (bla/ora wire, ign on) & 5.06v red/whi wire
• When installing the distributor housing I aligned the line on the housing with the cutout on the bearing cap and set the crank to TDC by lining up the notch on the pulley to 0
I've been going through alot of forums and I've seen some potential causes but not sure of, such as: EFI main relay, ECU, ignition switch, ignition fuse
Search terms: 1987 1988 1990 1991 1987-1991 87 88 89 90 91 87-91 cranks washed engine now won't start
Dan Emet is offline
post #2 of 58 Old 04-09-2019, 11:18 AM
3s-gte in a Camry?!?
white90dx's Avatar
Quoted: 693 Post(s)
iTrader Score: 6 reviews
Do you get a check-engine light with the key on, engine off? (should be yes - just verifying ECU is on/working)
This problem is normally a cracked ignition coil - it may electrically check ok and still arc internally. Visually check/replace.
-Charlie
89 Camry Alltrac LE 3S-GTE
99 4Runner SR5 4WD
08 Outback XT
Previous: 88 Camry Alltrac LE 3S-GE BEAMS, 90 Camry 3S-GTE, 90 Camry DX, 03 WRX Wagon
white90dx is offline
post #3 of 58 Old 04-09-2019, 12:14 PM Thread Starter
Quoted: 7 Post(s)
(Thread Starter)
No actually I do not get a check engine light on, all the other lights work properly, hmm... What can this be?
Dan Emet is offline
post #4 of 58 Old 04-09-2019, 12:35 PM
Toyota Collector
71Corolla's Avatar
Quoted: 2406 Post(s)
Check the EFI relay pins for corrosion and/or discoloration. Swap in a different relay if possible.
2000 Lexus ES300 Millenium Edition
1990 Camry LE V6 Anniversary Edition 5-Speed
1990 Camry LE V6 WAGON
1987 Camry LE I4 5-Speed
71Corolla is offline
post #5 of 58 Old 04-09-2019, 12:40 PM Thread Starter
Quoted: 7 Post(s)
(Thread Starter)
I tested the EFI relay it is properly functioning - in spec. Side note: the AC and fan relays weren't good but pretty sure it has nothing to do with this
Dan Emet is offline
post #6 of 58 Old 04-09-2019, 12:47 PM
Toyota Collector
71Corolla's Avatar
Did you verify power at the output pin of the relay?
post #7 of 58 Old 04-09-2019, 12:53 PM Thread Starter
Quoted: 7 Post(s)
(Thread Starter)
I performed a full test on the relay - its good, are you referring to the fuse box itself when you say "output pin"?
Dan Emet is offline
post #8 of 58 Old 04-09-2019, 12:56 PM
Toyota Collector
71Corolla's Avatar
Bench testing the relay is not the same as testing if the relay is actually outputting power, put a test light on the output pin bottom of the fuse box. Or swap the relay with one from the LH kick panel.
Always verify don't guess.
post #9 of 58 Old 04-09-2019, 01:39 PM Thread Starter
Quoted: 7 Post(s)
(Thread Starter)
Okay, so I checked the fuse box pins that the relays go into with a test light and it didn't light up for ALL of the relay spots (they had a gooey film/cake on the pins). Side note: the 7.5A fuse and the two 15A fuses for the "Heads" didn't light up at the pins either
Dan Emet is offline
post #10 of 58 Old 04-09-2019, 01:54 PM
Quoted: 56 Post(s)
Sounds like something got wet and needs to dry out?
I would pull the ignition coil out. It sounds like it'd be cracked (very common) and damp.
Also, pay attention when white90dx posts, he is extremely knowledgeable,
If you need to move the car point a hair dryer into the distributor and see if that will dry it out enough to start the engine.
66conv6 is offline
post #11 of 58 Old 04-09-2019, 02:19 PM Thread Starter
Quoted: 7 Post(s)
(Thread Starter)
Ok so is it my ECU because my check engine light doesn't turn on when ignition is on? Or is it my fuse box? <If it is can I clean it somehow and dry it out or would I need to cut the fuse box part of the wiring harness out and resaulder each wire?
Dan Emet is offline
post #12 of 58 Old 04-09-2019, 03:31 PM Thread Starter
Quoted: 7 Post(s)
(Thread Starter)
ACTUALLY the pins on the fuse box where the relays connect DO have signal I didn't test it right the first time= #4 pin location on the EFI lights up, bottom right pin location for the head light relay is the only one that DOESN'T light, top left pin location for main relay lights up only.
Again the two 15A fuses are good but the pins for their location are no good - headlights work. And the 7.5A "charge" fuse pins aren't good either.
Dan Emet is offline
post #13 of 58 Old 04-09-2019, 09:23 PM
Toyota Collector
71Corolla's Avatar
No good in what way?
post #14 of 58 Old 04-09-2019, 09:42 PM Thread Starter
Quoted: 7 Post(s)
(Thread Starter)
Using a test light onto the pins for those fuses - it doesn't light
Dan Emet is offline
post #15 of 58 Old 04-09-2019, 10:06 PM
Toyota Collector
71Corolla's Avatar
Have you checked the 7.5 amp gauge fuse? The CEL gets power from that, and a signal from the ECU. Check your PM.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 1st & 2nd Gen (1983-1986) & (1987-1991)
User Tag List
Linear Mode Linear Mode
