89 3sfe idle drop with A/C on - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 1st & 2nd Gen (1983-1986) & (1987-1991) Toyota Camry Discussion for years 1983-1986 & 1987-1991. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
 2Likes
  • 1 Post By 71Corolla
  • 1 Post By white90dx
post #1 of 8 Old 06-02-2019, 05:51 PM Thread Starter
Yaboy_chun's Avatar
Quoted: 9 Post(s)
(Thread Starter)
When I turn the AC on the idle drops to about 500 from 1000. Previous owner said he idled it up to compensate for the drop when running ac. Now the idle surges along with dropping when the AC is on. Any ideas on how to fix?
Yaboy_chun is offline
post #2 of 8 Old 06-02-2019, 05:54 PM
Toyota Collector
71Corolla's Avatar
Quoted: 2454 Post(s)
The idle up solenoid may have gone bad it's bolted to the firewall near the RH strut tower. I can post pictures later if you can't find it.
2000 Lexus ES300 Millenium Edition
1990 Camry LE V6 Anniversary Edition 5-Speed
1990 Camry LE V6 WAGON
1987 Camry LE I4 5-Speed
71Corolla is online now
post #3 of 8 Old 06-02-2019, 08:51 PM Thread Starter
Yaboy_chun's Avatar
Quoted: 9 Post(s)
(Thread Starter)
That's separate from the idle air control valve?
post #4 of 8 Old 06-02-2019, 09:33 PM
Toyota Collector
71Corolla's Avatar
Yes here's the two components involved.
66conv6 likes this.
post #5 of 8 Old 06-02-2019, 11:19 PM Thread Starter
Yaboy_chun's Avatar
Quoted: 9 Post(s)
(Thread Starter)
Aye your Camry is the same color as mine but your engine bay looks alot cleaner lol
Thanks for the input I'll try to see about finding a new one
post #6 of 8 Old 06-02-2019, 11:30 PM
Toyota Collector
71Corolla's Avatar
The valve bolted to the intake is what usually goes bad, all it does is let in more air so the ECU increases the engine speed. Don't know why the IACV can't do this maybe it can't let in enough air.
post #7 of 8 Old 06-03-2019, 11:10 AM
3s-gte in a Camry?!?
white90dx's Avatar
Quoted: 700 Post(s)
iTrader Score: 6 reviews
My experience was the opposite. The valve on the firewall with the electrical plug often goes bad. It probably has gone open circuit (easy to test with a multimeter). Hopefully you can find a replacement at the junkyard. They are probably available in parts stores too - it is a common fault.
The valve on the manifold (opposite end from throttle body) is actuated by the electrical VSV on the firewall and is adjustable. Set it so the RPMs bump up slightly (700-900) in gear when the AC turns on. Idle with AC off should be around 700 and should not have been adjusted by the previous owner (supposed to be electronically controlled).
-Charlie
66conv6 likes this.
89 Camry Alltrac LE 3S-GTE
99 4Runner SR5 4WD
08 Outback XT
Previous: 88 Camry Alltrac LE 3S-GE BEAMS, 90 Camry 3S-GTE, 90 Camry DX, 03 WRX Wagon
white90dx is offline
post #8 of 8 Old 06-03-2019, 01:01 PM
Toyota Collector
71Corolla's Avatar
I suspect it's climate related here the air valve gets gunked up and covered in salt.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 1st & 2nd Gen (1983-1986) & (1987-1991)
User Tag List
Linear Mode Linear Mode
