1985 Camry Tune Up Help - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 1st & 2nd Gen (1983-1986) & (1987-1991) Toyota Camry Discussion for years 1983-1986 & 1987-1991. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 6 Old 06-17-2019, 01:19 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Here is my new-to-me 1985 Toyota Camry 2-SE engine, automatic transmission.
The body is in great shape, and interior is clean and original.
The engine does run, but has milkshake in the oil, and smokes from the back passenger-side of the engine block when running. It doesn't seem to want to idle. I picked up a Chilton's manual for it, but the manual is 85-96 so the diagrams aren't specific to any particular engine.
I'd love to hear any tips/tricks for tuneups for this car, as well as anything to look out for.
85PNWCamry is offline
post #2 of 6 Old 06-17-2019, 04:22 PM
3s-gte in a Camry?!?
white90dx's Avatar
Quoted: 699 Post(s)
iTrader Score: 6 reviews
Uh, if it ran for any length of time with coolant in the oil, you'll need a full engine rebuild...
-Charlie
89 Camry Alltrac LE 3S-GTE
99 4Runner SR5 4WD
08 Outback XT
Previous: 88 Camry Alltrac LE 3S-GE BEAMS, 90 Camry 3S-GTE, 90 Camry DX, 03 WRX Wagon
white90dx is offline
post #3 of 6 Old 06-30-2019, 03:36 PM
Kanmuri
EightD-5's Avatar
Quoted: 84 Post(s)
I agree with the rebuild and welcome to TN. I'm in the PNW as well with a 1985 M/T. I can help you source parts and possibly help you work on it if you're fairly local.
As for tuning the vehicle up, coil, plugs, wires, cap, rotor, fluids, and check your brakes.
Dont buy iridiums or platinums, coppers are perfect. Buy an NGK or Denso Coil. NGK plugs, and just be conscious about the brands of fluids you use.
Lets see a picture!
-- If you ever want to get rid of it, i'll be your first buyer!
“Anything worth doing is worth doing poorly--until you can learn to do it well.”
EightD-5 is offline
post #4 of 6 Old 07-03-2019, 10:33 PM
glutamodo's Avatar
Quoted: 40 Post(s)
"milkshake" is not necessarily a death-rattle, but may be a factor of how it's driven. IF you make short hops around town you get this. If you're like me and drive 82-ish miles each way on a freeway commute, the engine has enough time time to boil off moisture in the oil.
glutamodo is offline
post #5 of 6 Old 07-04-2019, 01:23 AM
Senior TN Member
Quoted: 1866 Post(s)
OP, does your coolant level drop over time?
A couple CC of normal condensation in crankcase is fine and won't cause milkshake.
But when you're talking about liters of coolant in oil, that's milkshake and time for new engine.
Do compression test on engine first and post numbers here. Then we'll have more information to determine next step.
DannoXYZ is offline
post #6 of 6 Old 07-05-2019, 04:08 AM
Kanmuri
EightD-5's Avatar
Quoted: 84 Post(s)
I can attest to this as I drove my 2002 Chevrolet Blazer with a intake mani leak, which burned the coolant as well as stored some in the crankcase.
I changed oil with super cheap stuff every 3k and no issues.. finally was running through coolant fast enough to throw a new gasket in it. Then the radiator needed replacing.. ended up giving it to my ex-girlfriend to run into the ground.
EightD-5 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 1st & 2nd Gen (1983-1986) & (1987-1991)
User Tag List
Linear Mode Linear Mode
