Coolant hose under distributor leaking, part #? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 1st & 2nd Gen (1983-1986) & (1987-1991) Toyota Camry Discussion for years 1983-1986 & 1987-1991. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 6 Old 09-07-2011, 12:32 PM Thread Starter
Quoted: 3 Post(s)
(Thread Starter)
2nd Generation Coolant hose under distributor leaking, part #?
Hi Guys!
My distributor has been leaking oil for quite some time now. While this causes idle issues, it hasn't detrimental until now. The oil leaking onto the coolant hose directly under the distributor (around the area where the distributor meets the cap) and finally melted it away, causing a pretty big coolant leak though that hose.
Is there any resource I can use to look up the part number of that hose? It looks like the hose runs directly from the block into the firewall, and then the heater core (?). Besides the normal air purging when replacing the radiator fluid, is there anything else required?
Thanks!
Steve
1991 Camry Station Wagon - 340K and counting
modMonkey is offline
post #2 of 6 Old 09-07-2011, 01:20 PM
Quoted: 27 Post(s)
toyotapartseast.com has images you can view and also order from there if you want.
You'll find something like this with prices and part no. that match up.
FOR SALE
1990 Camry LE v6
1992 Pickup DLX 4x4 4cyl.
1988 4Runner SR5 4x4 (Engineless - Future 5VZ-FE)
2014 RAV4 AWD Limited
Grego 92 is offline
The Following User Says Thank You to Grego 92 For This Useful Post:
modMonkey (09-07-2011)
post #3 of 6 Old 09-07-2011, 01:35 PM Thread Starter
Quoted: 3 Post(s)
(Thread Starter)
Thanks Grego!! Exactly what I was looking for. I'll confirm when I'm home today but it looks to be this one (87246A).
post #4 of 6 Old 09-08-2011, 05:44 PM
Quoted: 2 Post(s)
That hose can be replaced by regular heater hose as I did. The only hose that's special is the 87245E, that can't be replaced with heater hose because of the angles and tight space.
typesix is offline
The Following User Says Thank You to typesix For This Useful Post:
modMonkey (09-08-2011)
post #5 of 6 Old 09-08-2011, 05:50 PM Thread Starter
Quoted: 3 Post(s)
(Thread Starter)
Oh sweet. Wasn't looking forward to paying oem prices. Is heater hose something you can get locally? Happen to remember the diameter?
So I pull the cap off last night. It appears two hoses have melted away:
1. 87246A - going from the firewall into the hardline (running from in front of the engine block)
2. A skinnier hose going from a nipple on the sensor branch (where the coolant bleed screw is) into somewhere else. I can't see to find a diagram anywhere of this. Any one happen to be able to locate a diagram showing the coolant sensor branch?
post #6 of 6 Old 09-08-2011, 08:14 PM
Quoted: 2 Post(s)
Local auto parts store will have heater hose. Size is 5/8" and the store can confirm that or buy the exact part from the parts place listed by another poster.
typesix is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 1st & 2nd Gen (1983-1986) & (1987-1991)
User Tag List
Linear Mode Linear Mode
