can't disconnect intermediate shaft from rack - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
 2Likes
post #1 of 16 Old 10-14-2017, 04:51 PM Thread Starter
Quoted: 4 Post(s)
(Thread Starter)
Hi
I'm installing a rebuilt rack in my 1997 Camry all is going well except I cant free the shaft from
the rack, I've removed the 12 mm bolt and tried to push up but there is no movement. Any
advice would be appreciated
Thanks
Bill W
tdbiwmw is offline
post #2 of 16 Old 10-15-2017, 12:00 AM
Kingdom934's Avatar
Quoted: 2050 Post(s)
I believe the inside cabin shaft should slide in and out...maybe need to loosen the bolt underneath the dash/steering wheel there as well so it can slide? Then you should be able to slide it out from the outside as it'll slide on the inside?
Some DIY but doens't mention anything on the inside. I know the inside of my Gen5 will allow the steering shaft spindle (proper name?) that does slide up and down.
https://www.toyotanation.com/forum/10...ots-pic-s.html
https://www.toyotanation.com/forum/10...se-w-pics.html
'85 Camry DLX 162K
'87 Cressida 78K
'04 Camry XLE V6 119K
'98 Camry LE AE V6 228K
'06 IS250 + sport pkg 153K
'04 Camry SE I4 5SPD 199K
Kingdom934 is offline
post #3 of 16 Old 10-16-2017, 06:03 PM
Just play along....
speedy25's Avatar
Quoted: 260 Post(s)
Wedge a chisel into the slot to open the clamp a bit. Sometimes they get rusted together.
-SP
speedy25 is offline
post #4 of 16 Old 06-09-2019, 08:15 PM
Quoted: 13 Post(s)
Originally Posted by tdbiwmw View Post
Hi
Thanks
Bill W
Did you find a solution to this? I have the same problem on my '97 Camry. I've tried removing the set screw inside, using WD-40 and Ballistol, driving the pry bar into the vertical seam, and hammering up on it with a pry bar and 3# sledge. It won't budge.
Av8r115 is offline
post #5 of 16 Old 06-09-2019, 10:01 PM
short-throw dipstick
Quoted: 1789 Post(s)
You're on the right track. Switch to a higher-grade, actual penetrating oil; WD-40 and Ballistol are next to useless. PB B'laster, Aerokroil, Free-All, etc.
As Kingdom said the shaft coming from steering wheel should slide in and out
Av8r115 likes this.
00 Camry 5S-FE 184k smoooth
01 ES300 147k NEEDS TRANS WORK
01 Insight 137k BROKEN CAMSHAFT
02 Insight 178k DC-DC BELLY-UP
08 STS-V 67k 570 RWHP!
01 Viggen 112k 400 FWHP
insightbrewery is offline
post #6 of 16 Old 06-09-2019, 10:12 PM
Kingdom934's Avatar
https://www.toyotanation.com/forum/1...t-2.html?amp=1
I had this issue before. For me I recall I had to loosen and remove the nut holding the shaft in place. I thought I could had gotten away with just loosen it.
Av8r115 likes this.
'85 Camry DLX 162K
'87 Cressida 78K
post #7 of 16 Old 06-09-2019, 10:56 PM
Quoted: 13 Post(s)
Here's what I have under the dash. I've since removed the star-head screw in the collar at the bottom. It didn't make any difference. I'm going to soak the splined shaft on the rack with PB Blaster overnight, and I think I'll disconnect the intermediate shaft from the steering column (top of the pic).
Av8r115 is offline
post #8 of 16 Old 06-10-2019, 10:52 PM
イリジウム
Quoted: 1002 Post(s)
Too rusted? See 6:10 into this video.
JohnGD is offline
post #9 of 16 Old 06-10-2019, 11:19 PM
☻Black Member
Blackness's Avatar
Quoted: 580 Post(s)
- time to hit it with a torch
- get it hot and it'll come loose
- prolly rust
1995 2.2L Camry 5sfe engine
Blackness is offline
post #10 of 16 Old 06-11-2019, 10:04 PM
Quoted: 13 Post(s)
Finally! PB Blaster did the trick. One unusual thing about PB is it doesn't come with a tube like Ballistol or WD-40 but shoots a focused stream if you only press part way down. I soaked the splines Sunday and Monday nights (couldn't work on it Monday), and a couple more shots today while I hammered upwards on it with a 24" pry bar and 3# sledge. I also put some Ballistol into the collar on the inside portion of the intermediate shaft and pulled the large rubber grommet loose. I used Ballistol because it has a spray tube and doesn't smell as bad as PB Blaster. I quit for today when I finally got the old rack out. I'll put the new one in tomorrow morning. I'll center the new one and box up the old one this evening.
Av8r115 is offline
post #11 of 16 Old 06-11-2019, 11:31 PM
Quoted: 13 Post(s)
I centered the new rack and made witness marks so I can make sure it's still centered before attaching the intermediate shaft.
Av8r115 is offline
post #12 of 16 Old 06-11-2019, 11:59 PM
☻Black Member
Blackness's Avatar
Quoted: 580 Post(s)
- what was the reason for replacing the rack?
- leaks?
- lash?
post #13 of 16 Old 06-12-2019, 05:45 AM
Quoted: 13 Post(s)
- leaks?
- lash?
A huge pothole strike. Knocked the inner tie-rods loose and the rack started leaking like a sieve. Also replaced the control arms, ball joints, and right outer tie-rod end, all of which were OE. I had already replaced the left outer a while back.
Av8r115 is offline
post #14 of 16 Old 06-12-2019, 07:39 PM
Quoted: 13 Post(s)
The passenger side bolt hole on the reman rack is off by about a 1/4". I guess I should have measured it before snaking it into place. RockAuto only gives me the option to return it, and they don't have any customer service by phone so I can let them know about the mistake. I guess it's time to make some adjustments and try again in the morning. I guess I should be glad I have the week off.
Av8r115 is offline
post #15 of 16 Old 06-12-2019, 09:37 PM
Man, I hate that. Tried calling a few months ago. The mecretary was rude as f***, even though my return issue wasn't covered by any of the drop-down menu options.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
