99 Camry 2.2L P0446 - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
 13Likes
post #1 of 19 Old 04-14-2019, 09:35 AM Thread Starter
gaijin666's Avatar
Quoted: 202 Post(s)
(Thread Starter)
99 Camry 2.2L P0446
1999 Camry 2.2L Inline4, 203,000 miles
Running a P0446 - "Missing fuel cap, incorrect cap, jarred cap, faulty vapor pressure sensor, vapor pressure sensor harness is open or shorted or poor connection"
1. Replaced purge solenoid, code returned.
2. Went to junkyard, got whole different charcoal canister "just in case" $30 ($265 new).
3. Deleted code, drive cycle not yet complete, bummer
4. Tightened up the gas cap, can't yet observe effects cuz car systems not yet totally reset
--> Hey WHERE is the vapor pressure sensor harness..? <--
Here are two photos below, one top-down, one side-view
PS - What is the specific drive cycle test for the catalyst monitor for a 99 Camry 2.2L...? Calif. does permit testing if EVAP not yet ready, but my catalyst monitor MUST be reset.
I'm pretty sure the vapor pressure sensor harness is next to the charcoal canister, but lemme tell ya, it's suuuuper cramped down there, and I don't have a lift or creeper and my jack stands are not super tall, plus my chest is pretty thick.
So where is the vapor pressure sensor, and what it the drive cycle test for the cat..?
File Type: png Screen Shot 2019-04-14 at 7.27.16 AM.png (438.1 KB, 4 views)
File Type: png Screen Shot 2019-04-14 at 7.29.36 AM.png (441.5 KB, 1 views)
gaijin666 is offline
post #2 of 19 Old 04-14-2019, 07:28 PM Thread Starter
gaijin666's Avatar
Quoted: 202 Post(s)
(Thread Starter)
Update 24 hrs later:
My drive cycle tests had not yet completed so I tightened the gas cap.
Today after 10 miles my drive test completed and the P0446 returned.
I went home and swapped the Gas Canister Purge valve, or...I think I did. What I replaced appears at photo bottom LEFT.
Checking my work, by coincidence I saw a photo of what turned out to be a TN sticky thread on the topic:
https://www.toyotanation.com/forum/1...-canister.html
That thread explained that the 99 Camry 2.2L often has my problem and appearing below RIGHT is what the guy replaced to remedy the P0446:
Why the two different doo-dads..? What's the diff between these two things..?
I'm sorta nooby. I think they were from the same year Camry, and they were both 2.2L
File Type: png Screen Shot 2019-04-14 at 5.18.33 PM.png (841.5 KB, 2 views)
post #3 of 19 Old 04-14-2019, 07:35 PM Thread Starter
gaijin666's Avatar
Quoted: 202 Post(s)
(Thread Starter)
BELOW is what I swapped out, but Jegs.com calls this item the "vacuum switching solenoid valve".
I think this is a different term for the same thing..?
https://www.jegs.com/i/Dorman/326/91...yABEgLXlvD_BwE
File Type: png Screen Shot 2019-04-14 at 5.34.41 PM.png (695.2 KB, 0 views)
post #4 of 19 Old 04-15-2019, 10:42 AM
Quoted: 131 Post(s)
The last VSV you are showing is for the EGR system not the evap system. You should have started with the simplest thing, which would be buying a new OEM gas cap. I have had 2 people at work get this code on their Toyota's and both times a new gas cap fixed their problem.
gaijin666 likes this.
Phils Camry is offline
The Following User Says Thank You to Phils Camry For This Useful Post:
gaijin666 (04-15-2019)
post #5 of 19 Old 04-15-2019, 11:04 AM Thread Starter
gaijin666's Avatar
Quoted: 202 Post(s)
(Thread Starter)
A cap from the dealership costs $44:
Can I simply use one from AutoZone..?
post #6 of 19 Old 04-15-2019, 03:42 PM
Quoted: 131 Post(s)
You can, but sometimes they don't work. You might get a junkyard cap in good condition for cheap. Dealerships really stink. I would bet it is probably your gas cap. A gal here at work got an Autozone cap. It worked for 2 months and then she got the same code. She broke down and got an OEM cap 2 years ago and hasn't had the code come back.
post #7 of 19 Old 04-15-2019, 06:11 PM
Wanna Fix It!
John Anthony's Avatar
Quoted: 669 Post(s)
Gas cap is one of those parts that really is best with the OE part. It shoud be $32.16 at your Toyota dealer. If they are saying it's $44, simply ask them if they will sell it for the Toyota retail price ($32.16). Whenever I've done this the dealer has always agreed to that price (only one exception was for the air filter at this one particular dealer). Also, you can replace just the rubber gasket on your cap (if the rest of the cap is in good condition). That should be $21.12 at your Toyota dealer. Try online and you might find even cheaper prices. Watch out for knockoffs/fakes sold on E-bay.
Did you check the wiring and connector for the vacuum switching valve at the charcoal canister? My son had a P0446 on his '96 Camry and when I inspected the wiring connector, one of the wires slipped right out of the back of the connector with hardly a tug. Got a new pigtail connector from the junkyard and soldered it on. P0446 fixed!
2004 Corolla LE 374K+ miles.
1987 Toyota Pickup base, 4spd 162K+ miles.
"There's always free cheese in a mousetrap."
John Anthony is online now
The Following 2 Users Say Thank You to John Anthony For This Useful Post:
Brit101 (04-19-2019), gaijin666 (04-15-2019)
post #8 of 19 Old 04-15-2019, 07:50 PM Thread Starter
gaijin666's Avatar
Quoted: 202 Post(s)
(Thread Starter)
Update #2:
Bought super cheap O'Reiley's non-branded gas cap, $10.
You can tell I'm poor, right..?
One bit of good news; today when I took off the old cap to put on the new white trash one, I heard no air re-pressurization,"WHOOSH..!" sound as you ordinarily would with a GOOD gas cap after almost totally driving down the tank after a high fill-up.
Because of that one clue I belieeeeeve that my whole problem might have been a BAD GAS CAP, in conformance with the assessment of the many Knowing Others in this thread. So perhaps it will turn out that I've been doing much needless work.
Cleared codes, drove a bunch, all drive cycles complete except EVAP.
Really hoping it finishes and no code but we'll see tonight or tomorrow.
I really wanted to buy the dealership cap but when I called ahead and they stuck with their $44 price
I've been screwd a bunch by the dealership so I just couldn't stomach that, plus I'm poor.
As long as the EVAP drive cycle clears tomorrow with no code I will get the car smogged (this used car is from Arizona), get that Calif DMV paperwork and be happy for a good long while, periodically checking with my OBD2 to check for overlapping codes, in case a stupid EVAP one recurs.
This is the first time I have bought an out-of-state used vehicle; is there some extra charge in California for that..? Legally I do not yet own this car, but have paid for it.
post #9 of 19 Old 04-15-2019, 08:55 PM Thread Starter
gaijin666's Avatar
Quoted: 202 Post(s)
(Thread Starter)
Guy lays the USUAL cause of the problem in this vid:
post #10 of 19 Old 04-15-2019, 11:07 PM
Wanna Fix It!
Quoted: 669 Post(s)
Originally Posted by gaijin666 View Post
I really wanted to buy the dealership cap but when I called ahead and they stuck with their $44 price.
They're inflating the price. Do you have other dealers in your area? I have several Toyota Dealerships here in the San Antonio area. They almost always agree to sell at the Toyota retail price, which is indeed $32.16. If you have other dealers, I would check with them (yeah, I know you already bought an aftermarket cap, but still....).
There's one dealership that tends to inflate the prices of the air filters for whatever reason, but they will agree to retail price on everything else I've proposed. Same for the other dealers I've tried. Sometimes I will get up to 15% less than retail price simply for asking.
Check out this online price:
Amazon Amazon
Brit101 and CamryFL like this.
The Following User Says Thank You to John Anthony For This Useful Post:
post #11 of 19 Old 04-16-2019, 07:12 PM Thread Starter
gaijin666's Avatar
Quoted: 202 Post(s)
(Thread Starter)
Update #3
I had replaced the gas cap with an Autozone cheap one but the code DID return. >
I cleared the code, drove around until I had just the EVAP drive cycle incomplete, then smogged my car since Calif still permits ONE devide to still read incomplete.
(Using a smogging technique I learned here at TN a year ago, I used 3 fluid ounces of WalMart TC-W3 outboard motor oil additive added to a full tank of regular unleaded gas and then drove that all the way down over the course of the past week, while trying to fix the root cause of this P0446):
For both HC and CO2 I didn't even rise to 10% of the max Calif. permissible levels on my 99 Camry, 203k miles; the TC-W3 technique seems to have worked very well.
I lucked out and the dreaded code returned juuuuust after I had completed smog. I had driven away just 1 block or so when it lit up.
I will still be checking on what's causing the P0446 code.
What should I try next..?
To summarize:
1. Gas cap replaced
2. Gas tank vapor pressure sensor replaced
3. Gas tank vapor purge valve replaced
I'm dubious I require a whole new canister. Should I change the harness next..?
post #12 of 19 Old 04-17-2019, 01:31 PM
Quoted: 131 Post(s)
Glad you passed smog. I live in SoCal and I hate the smog checks. I am not sure what the problem is but you now have 2 years to fix it. CEL's generally only apply to emissions and driving with a CEL wont hurt the car unless the CEL starts blinking. I am not sure which direction to go. Next smog check use premium gas and put an ounce of TCW-3 in the gas and your emissions should be almost non-existent. It might be your canister. I would try a junkyard one first since it would probably be dried out of most gas fumes and cheaper.
post #13 of 19 Old 04-17-2019, 04:07 PM
Daijoubu's Avatar
Quoted: 81 Post(s)
Genuine gas cap is $26 on Amazon
Amazon Amazon
Daijoubu is offline
post #14 of 19 Old 04-18-2019, 10:09 AM
Quoted: 131 Post(s)
Sometimes the hoses get clogged with bits of carbon from the charcoal canister. You made need to clear out your hoses or vacuum lines that connect all your evap stuff together. I have had his happen with my EGR system.
Daijoubu likes this.
post #15 of 19 Old 04-18-2019, 10:29 AM
Senior TN Member
Quoted: 223 Post(s)
No- Toyota OE only. Toyota EVAP system favors OE gas caps.
Brit101 likes this.
chuckoff is offline
The Following User Says Thank You to chuckoff For This Useful Post:
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
