P0420 and flex pipe exhaust leak - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 10 Old 04-15-2019, 02:23 PM Thread Starter
Quoted: 15 Post(s)
(Thread Starter)
I'm trying to get my Solara up and running. It has had a P0420 code for a while now. Brought it to the exhaust shop to have them inspect everything and they said the cats look physically good (not clogged), but they said my flex pipe is leaking.
Preliminary research online shows that an exhaust leak could cause a P0420. What would you say the chances are that my issue is an exhaust leak and not a bad cat?
Trying to see if the car is worth fixing.
Thanks in advance!
RapidPotato is offline
post #2 of 10 Old 04-15-2019, 02:37 PM
Senior TN Member
Vangm25's Avatar
Quoted: 557 Post(s)
Replace it and see what happens. Not much else you can do.
Help those who accept it, troll those who shun it
Vangm25 is offline
post #3 of 10 Old 04-15-2019, 03:29 PM
BMR
Sheriff of Mayberry
BMR's Avatar
Quoted: 1753 Post(s)
You could take it to a muffler shop and have them inspect it. Itíll probably not be free, but they should be able to tell you if itís leaking or not.
2015 RAV4 Limited, AWD, tech pkg, Barcelona red metallic, 61k miles
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 394k
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, totaled at 384k miles
BMR is offline
post #4 of 10 Old 04-15-2019, 04:08 PM
Quoted: 15 Post(s)
just an idea but you could pull the spark plugs and drop a little oil in each cylinder. somewhere in low light and using a flashlight if youre under the car it should be easier to see where the exhaust is leaking as it should be a white smoke that the light will help point out
03 corolla hmm is offline
post #5 of 10 Old 04-15-2019, 04:59 PM Thread Starter
Quoted: 15 Post(s)
(Thread Starter)
They are telling me the flex pipe is leaking.
What I’m wondering is: is it reasonable to believe the exhaust leak could also cause a P0420 code? (Catalytic converter below efficiency)
post #6 of 10 Old 04-15-2019, 06:10 PM
Senior TN Member
Vangm25's Avatar
Quoted: 557 Post(s)
What Iím wondering is: is it reasonable to believe the exhaust leak could also cause a P0420 code? (Catalytic converter below efficiency)
Vangm25 is offline
post #7 of 10 Old 04-15-2019, 06:16 PM
Wanna Fix It!
John Anthony's Avatar
Quoted: 623 Post(s)
To answer your question, yes, an exhaust leak can cause the P0420. If the flex pipe is leaking, you need to get that fixed anyway even if it doesn't fix the P0420.
2004 Corolla LE 371K+ miles.
1987 Toyota Pickup base, 4spd 162K+ miles.
"There's always free cheese in a mousetrap."
John Anthony is offline
post #8 of 10 Old 04-15-2019, 07:17 PM
Quoted: 283 Post(s)
A leaking flex pipe will increase the exhaust noise-- easy diagnosis. And increased chance of carbon monoxide -CO- poisoning inside the car.
Mergatroyd is offline
post #9 of 10 Old 04-16-2019, 08:38 AM
Wanna Fix It!
Quoted: 623 Post(s)
Originally Posted by Mergatroyd View Post
A leaking flex pipe will increase the exhaust noise-- easy diagnosis. And increased chance of carbon monoxide poisoning inside the car.
Yes, agreed. Our flex pipe was making the engine exhaust sound loud as well. CO2 leaking under the car isn't a good thing as well, and it should first be fixed for no other more important reason.
post #10 of 10 Old 04-16-2019, 04:52 PM
BMR
Sheriff of Mayberry
BMR's Avatar
Yes. Iíve seen quite a few threads where a leaking flex pipe caused a P0420. Doesnít mean the cat isnít also bad, but the odds are decent itís OK.
BMR is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
