Replacing valve spring seal and wt......f - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
 2Likes
post #1 of 21 Old 04-15-2019, 08:17 PM Thread Starter
Quoted: 25 Post(s)
(Thread Starter)
1.I am about replacing the valve spring seals and I cannot put the springs or coils back on the valves. I brought or borrowed NAPA and Advance tools but they were unhelpful at all. The NAPA tool has a larger nose that when the spring is compressed, you cannot push it back; it just won't sit. The Advance one is good when the head is separated from the block. I tried hammer and 14mm deep socket but too strong. Any home diy tool that I can use to push the coil back on? I don't want to buy the special tool off Amazon.
2. The two 1st exhaust lifters are stuck, but the others just came off easily. Any idea how to remove them?
3. If you notice from the pic, there is a shaving on the exhaust side. Why is it look like that? How to fix it?
1993 Toyota Camry LE 156k I4-Current vehicle...
Chris Samurai is offline
post #2 of 21 Old 04-15-2019, 09:17 PM
Senior TN Member
Quoted: 295 Post(s)
are using air or rope to hold up valve?
Lisle 36050 works great for this.
tedmich is offline
post #3 of 21 Old 04-15-2019, 10:12 PM
Senior TN Member
sdspeed's Avatar
Quoted: 326 Post(s)
Originally Posted by Chris Samurai View Post
1.I am about replacing the valve spring seals and I cannot put the spring or coil back on the valve. I brought or borrowed NAPA and Advance tools but they were unhelpful at all. The NAPA tool has a larger noise that when the spring is compressed, you cannot push it back; it just won't sit. The Advance one is good when the head is separated from the block. I tried hammer and 14mm deep socket but too strong. Any home diy tool that I can use to push the coil back on? I don't want to buy the special tool off Amazon.
Exhaust valves look burnt and may need to be replaced. What condition is the valve seat under those exhaust valves. As mentioned what method are you using to keep the valve up while attempting to compress the spring?
sdspeed is online now
post #4 of 21 Old 04-15-2019, 10:14 PM
イリジウム
Quoted: 987 Post(s)
Have you checked this DIY:
https://www.toyotanation.com/forum/1...djustment.html
This Toyota valve spring design is recessed. Therefore the typical valve spring tools at parts stores' free loaner list won't be able to compress them. The large C-clamp as you said is for changing the stem seals with the cylinder head off. So it's either the Lisle tool mentioned, or a lever type compressor from eBay. (Search eBay for item "E10501CP425S")
You might be able to rig your own, maybe with something like this and an oxygen sensor socket (with a side cutout)?? Not sure. Search eBay for item "00811652031294".
As far as the stuck valve bucket. Pour some engine oil over it, and use a magnetic pickup tool to wiggle it. Make sure the seals are properly seated. If they come loose, your engine will consume oil quickly.
Chris Samurai likes this.
JohnGD is offline
post #5 of 21 Old 04-15-2019, 11:24 PM
2010 Camry SE V6
BlackCamSe's Avatar
Quoted: 53 Post(s)
Those cam bearings look like they’re shot
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline
post #6 of 21 Old 04-15-2019, 11:37 PM
Toyota Collector
71Corolla's Avatar
Quoted: 2405 Post(s)
The valve fell into the cylinder, yes the journals in the head are baked you need at minimum a new cylinder head.
2000 Lexus ES300 Millenium Edition
1990 Camry LE V6 Anniversary Edition 5-Speed
1990 Camry LE V6 WAGON
1987 Camry LE I4 5-Speed
71Corolla is online now
post #7 of 21 Old 04-16-2019, 03:23 PM Thread Starter
Quoted: 25 Post(s)
(Thread Starter)
I already ordered this tool because I am stranded.
They may look shot, but the engine runs like a kitten. If I replace them, I might get the lifting noise.
Originally Posted by JohnGD View Post
Thanks for the thread, but I am an intermediate mechanic, and too long to read it.
post #8 of 21 Old 04-16-2019, 03:29 PM
Toyota Collector
71Corolla's Avatar
Can we see some of the other journals? That one looks wiped like the metal has been overheated and stressed/deformed. That Lisle tool is for installing the keepers it won't help when the valve has fallen into the cylinder.
post #9 of 21 Old 04-16-2019, 03:30 PM
2010 Camry SE V6
BlackCamSe's Avatar
Quoted: 53 Post(s)
The buckets are stuck because the cam bearing/journal is wiped to the point it mushroomed. That head is shot no matter what way you cut it.
post #10 of 21 Old 04-16-2019, 05:09 PM
BMR
Sheriff of Mayberry
BMR's Avatar
Quoted: 1819 Post(s)
+3, or whatever it is. That head is toast because the one camshaft journal is galled badly. They should look smooth as glass. Yours looks like it was polished with gravel. And there should be a small hole at the bottom of the journal for the oil feed. Yours has been so boogered up it’s closed off.
Doesn’t matter if the others are good (they probably aren’t), that one is in REALLY bad condition. If you build with it anyway, you’re building a bomb with a short fuse.
2015 RAV4 Limited, AWD, tech pkg, Barcelona red metallic, 62k miles
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 397k
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, totaled at 384k miles
BMR is offline
post #11 of 21 Old 04-16-2019, 06:10 PM Thread Starter
Quoted: 25 Post(s)
(Thread Starter)
Here are the rest of the cam bearings.
post #12 of 21 Old 04-16-2019, 06:27 PM
BMR
Sheriff of Mayberry
BMR's Avatar
Those are the valve lifters. The cam journals (aka: bearings) are what the cams rest in when they’re installed in the head.
BMR is offline
post #13 of 21 Old 04-16-2019, 06:44 PM
Toyota Collector
71Corolla's Avatar
Not that is matters the head is junk but you didn't label the buckets/shims.
post #14 of 21 Old 04-16-2019, 09:15 PM
Senior TN Member
Quoted: 295 Post(s)
There are a ton of better looking heads at my local Pick N Pull for about $80, maybe try one!
tedmich is offline
post #15 of 21 Old 04-16-2019, 10:44 PM Thread Starter
Quoted: 25 Post(s)
(Thread Starter)
I know what are you talking about. I will upload them tomorrow.
There are two junkyard close to me. I probably stop by tomorrow.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
