Blowing white smoke again - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
 1Likes
post #1 of 16 Old 04-18-2019, 07:25 PM Thread Starter
Quoted: 3 Post(s)
(Thread Starter)
I'm sorry if there is a thread on this but I looked and couldn't find anything. I have a99 Camry 2.2L automatic. I just got done replacing the head gasket my daughter blew while I was in the hospital. She insists she did nothing to it that it wasn't running hot or anything. Anyhow so I got it back to running (valves are a little noisy) and I went to drive it and it was doing good and out of no where. It started spewing white smoke out the exhaust again, it had cleared but at the same time it did that the check engine light came on. So is it possible that it blew another head gasket or what. I did have the head pressure tested and surfaced at a reputable machine shop so that was all good and it didn't get past halfway on the temperature. I'm at a loss here, any help would be greatly appreciated.
Smitheagle69 is offline
post #2 of 16 Old 04-18-2019, 07:55 PM
Senior TN Member
sdspeed's Avatar
Quoted: 326 Post(s)
Was the condition of the block checked (rare but happens). Also were the head bolts replaced with new ones? They have a tendency to stretch. Any stored codes after the CEL came on?
sdspeed is online now
post #3 of 16 Old 04-18-2019, 09:20 PM
BMR
Sheriff of Mayberry
BMR's Avatar
Quoted: 1819 Post(s)
The head bolts on these have a bit unusual torque requirement. First, torque to 36 ft-lbs. Then tighten them another 90 of rotation. Did you do that?
2015 RAV4 Limited, AWD, tech pkg, Barcelona red metallic, 62k miles
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 397k
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, totaled at 384k miles
BMR is offline
post #4 of 16 Old 04-19-2019, 07:49 AM Thread Starter
Quoted: 3 Post(s)
(Thread Starter)
Yes I replaced the head bolts I read they were torque to yeild so I replaced them and I went 36 ft lbs. And another 1/4 turn like it says.Ok so here is the thing I went over to my mom's where there car is and started it up and not one bit of smoke at all and when I shut it off the other night it was blowing white smoke like a chimney but now nothing. It had cleared up and then started smoking again and now it's clear again is this common after doing a head gasket on these????? Thanks for your help it's greatly appreciated
post #5 of 16 Old 04-19-2019, 07:52 AM Thread Starter
Quoted: 3 Post(s)
(Thread Starter)
Oh I'm sorry yes it had a code I can't remember exactly but it was o2 sensor circuit something bank 1 running lean I can't remember but I cleared the code and it is not back yet. I think it was a po110 or similar to that
post #6 of 16 Old 04-19-2019, 09:50 AM
Quoted: 131 Post(s)
Now you get to run a compression test. Lucky you. That is where I would start since it is fairly easy to do. That should tell you if you have head or block problems.
BMR likes this.
Phils Camry is online now
post #7 of 16 Old 04-19-2019, 11:27 AM
BMR
Sheriff of Mayberry
BMR's Avatar
+1 to that. He had the head professionally inspected, so thats not the prob unless they overlooked something. So that leaves a cracked block. Pretty darn rare to happen on these, but cant be ruled out.
BMR is offline
post #8 of 16 Old 04-19-2019, 11:57 AM
Toyota Collector
71Corolla's Avatar
Quoted: 2405 Post(s)
Spec is 90 after initial torque not 45.
2000 Lexus ES300 Millenium Edition
1990 Camry LE V6 Anniversary Edition 5-Speed
1990 Camry LE V6 WAGON
1987 Camry LE I4 5-Speed
71Corolla is online now
post #9 of 16 Old 04-19-2019, 01:52 PM
BMR
Sheriff of Mayberry
BMR's Avatar
1/4 turn = 90
BMR is offline
post #10 of 16 Old 04-19-2019, 02:15 PM
Toyota Collector
71Corolla's Avatar
Originally Posted by BMR View Post
1/4 turn = 90
My bad you are of course correct.
post #11 of 16 Old 04-19-2019, 03:43 PM
Quoted: 131 Post(s)
BMR is the Sheriff not the Deputy. He is always correct.
post #12 of 16 Old 04-19-2019, 04:23 PM
イリジウム
Quoted: 987 Post(s)
Any sign of coolant or oil seepage around the head gasket area externally? Oil or coolant consumption?
JohnGD is offline
post #13 of 16 Old 04-19-2019, 04:32 PM
Quoted: 39 Post(s)
Hopefully it's just leftover antifreeze from the big job you did. Drive it for a week and keep an eye on your coolant level.
2006 Corolla
2008 Limited Rav4 I4
2017 Camry
Kevin
kevcules46 is offline
post #14 of 16 Old 04-20-2019, 04:01 PM Thread Starter
Quoted: 3 Post(s)
(Thread Starter)
I drove it last night again and it seems to only blow smoke now when under heavy acceleration, for the most part it has stopped. Really weird situation.i am hoping now that the smoke that is coming out is left over from the job. And as far as the block goes it is running too smooth to be a cracked block, I would think it would at the very least have a small misfire if not a bigger one. I have to get it registered first before I go drive it to much but I'm thinking to take and run it up and down the freeway(doing the speed limit of course) and blow the junk out of it and go from there. I will let you know what happens after I do that in a couple of days. Once again thank you very much.
post #15 of 16 Old 04-20-2019, 08:52 PM
Quoted: 25 Post(s)
Drive it for a week and give us an update.
1993 Toyota Camry LE 156k I4-Current vehicle...
Chris Samurai is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
