1995 Camry Flex Pipe - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
 1Likes
  • 1 Post By Mike Gerber
post #1 of 4 Old 05-17-2019, 10:06 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
My '95 Camry's Flex Pipe in the exhaust system got opened up by a big rock in the road...really loud now. I'd like to try to replace it on my own, without welding. It appears original fitting is a weld so I'd have to cut it. Any one with experience in this fix? Would clamps do an adequate job after replacing? A shop repair is more than I want to spend.
dendiedas is offline
post #2 of 4 Old 05-17-2019, 10:14 AM
Senior TN Member
Vangm25's Avatar
Quoted: 680 Post(s)
Cut and weld and do it right or cut and get a pipe expander and clamp it. One is a life long fix as long as it is done right, the other one I consider the "domestic route".
Vangm25 is offline
post #3 of 4 Old 05-17-2019, 02:06 PM
☻Black Member
Blackness's Avatar
Quoted: 581 Post(s)
- ^ this..
- weld it on proper
- a muffler shop should charge $85-$165
- by the time you add up u-bolts/clamps, muffler cement, hardware, and all the bs trying to patch it together you could be in and out and done at a muffler/welder shop
- OR get a stick welder and DIY
1995 2.2L Camry 5sfe engine
Blackness is offline
post #4 of 4 Old 05-17-2019, 02:11 PM
Quoted: 124 Post(s)
^ What Vangm25 said. I helped a friend do the flexpipe/clamp fix a few years back. The fix lasted about 6 months. Have an aftermarket muffler shop cut out the old pipe and weld in a new flex pipe. That should run about $100 and last for a while.
Mike
Brit101 likes this.
Mike Gerber is offline
The Following User Says Thank You to Mike Gerber For This Useful Post:
Brit101 (05-21-2019)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
