DTC P1150 for 1999 Toyota Avalon V6 1mz-fe California - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 3 Old 05-20-2019, 08:57 AM Thread Starter
Quoted: 13 Post(s)
(Thread Starter)
My Avalon - Cali has a P1150 code, which is a Bank 2, Sensor 1 (A/F) sensor. Is there a way to confirm the A/F sensor is bad with the freeze frame data below showing fuel sys bank 2 - Open Loop and short and long fuel trim on bank 2 near zero? Or do am I best off using a data streaming scan tool to see the voltages and other parameters? Anything else I should check?
I/M readiness shows o2 sensors are OK , does this indicate a problem somewhere else in the system.
Freeze Frame Data
Fuel Sys1 CL
Fuel Sys2 OL-Drive
Load_PCT% 28.2
ETC 156
SHRTFT1 -1.6
LONGFT1 -3.1
SHRTFT2 0
LONGFT2 -2.3
RPM 1486
VSS 43
LAT 86
I/M Readiness
All systems OK including O2 sensors. (This vehicle has A/F sensor)
1999 Avalon XLS Platinum Edition
edge10 is offline
post #2 of 3 Old 05-20-2019, 03:01 PM
cj1
Senior TN Member
Quoted: 362 Post(s)
"Is there a way to confirm the A/F sensor is bad with the freeze frame data below showing fuel sys bank 2 - Open Loop and short and long fuel trim on bank 2 near zero?"
You can monitor the A/F sensor voltage it should read around 3.3v at idle and move to 2.5v and 4.0v when you do a snap throttle.
PCM apparently isn't seeing what it expects from B2S1 at ECT of 156.
Does bank 2 go into close loop at full operating temp around 190?
cj1 is offline
post #3 of 3 Old 05-20-2019, 10:29 PM Thread Starter
Quoted: 13 Post(s)
(Thread Starter)
I don't have the info at ECT 190. I may have to trick my scan tool to get freeze frame info at ECT 190 I think if I: start engine and get it to normal op temp, turn off engine, clear code, restart , MIL lights, read code, it should be able to get the data.
edge10 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
