Gushing Transmission Fluid - 5S-FE - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 6 Old 06-12-2019, 10:46 PM Thread Starter
Quoted: 12 Post(s)
(Thread Starter)
Angry Gushing Transmission Fluid - 5S-FE
Hey guys,
So today, when I left work my transmission starting shifting oddly. 1-2 shift came very late and when I let off the gas, it hit hard. 2-3 was softer, but when I would accelerate it would sometimes kick out of gear.
Now I've never changed the fluid since I had the car, so I figured a couple spill n' fills should do the trick. Picked up some Type 3 ATF, a 10mm Hex Bit and went to work. First drain was pretty dirty but it didn't smell burnt. Drained a little over 2 quarts. Filled per the spec 2.6 Quarts, then ran it for about 10 minutes. Did it again, another spill, another fill, another 2.6 quarts. Mind you I did this while it was hot, but I'm hoping this doesn't change the fact of what happened next.
Went on a test drive around the block, on my way up the hill it sounded like I was pre-detonating, so I went easy. When I pulled into the driveway, I left a trail of ATF all the way up the hill. Parked on the ramps and shut it off. It was pouring fluid.
I'm wondering if I accidentally overfilled, and if so, blew the Converter shaft seal? Or maybe the fluid was so dirty, putting in clean ATF ate away what ever was holding the seal together? It was dripping from the converter cover so I have a strong suspicion that the seal is gone.
Any help / advice is welcome!
Thanks.
nradonich is offline
post #2 of 6 Old 06-13-2019, 06:04 AM
2010 Camry SE V6
BlackCamSe's Avatar
Quoted: 58 Post(s)
It sounds like your transmission is in need of a rebuild regardless of the leak or not. If its leaking from the bellhousing its most likely the front pump seal that shit the bed. Id purchase a remanufactured transmission and call it a day
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline
post #3 of 6 Old 06-13-2019, 06:20 AM
Senior TN Member
Quoted: 661 Post(s)
lts detonation and not pre-detonating
Find the source of the leak. Drain plug loose? ATF cooler hose trashed? And, post some pictures.
It would take several thousand miles for the low detergent level of ATF to clean anything in a transmission. No way would new ATF do anything in a trip around the block. And, ATF doesn't eat anything.
Where did you find type-3 ATF? Post a picture of the type-3 ATF bottle.
So many trolls so little time
Greasymechtech is online now
post #4 of 6 Old 06-13-2019, 07:44 AM
DIY Dad: if it has things, I'll tinker with it
SFCamry's Avatar
Quoted: 1104 Post(s)
I agree with above, pics would be helpful. If I read your post right, at most you might have put in about 1 qt (or less) more than you drained, depending on what "little over 2 quarts" was. Don't know if that would blow a seal...?
Camry Mod
THIS
'15 4Runner SR5 (1GR-FE)
'09 Camry SE 2.4L (2AZ-FE)
'97 Tacoma XL 4x4 Ext Cab 2.7L (3RZ-FE) - Manual
'97 Ford Explorer XLT V6 SOHC 4.0L 4x4
SFCamry is online now
post #5 of 6 Old 06-13-2019, 04:22 PM
イリジウム
Quoted: 1006 Post(s)
Right, what’s Type 3 ATF? You should be using ATF for Dexron III, or the likes of Walmart Supertech Mercon V, Dexron VI or Valvoline MaxLife ATF.
First establish the existing ATF level before changing, then measure the drained amount to add the same amount of new ATF back in.
Read the DIY section on ATF/filter changes too.
JohnGD is offline
post #6 of 6 Old 06-16-2019, 03:03 AM
Kingdom934's Avatar
Quoted: 2051 Post(s)
I had gushing transmission fluid leak...
Check where it is coming from. In my case, it was coming from the driver side axle. It wasn't the axle seal, but a internal issue with the differential.
I know the fluid pump / torque converter has a seal but I don't think they would go bad to the point where it is gushing. I know transmissions has a breather valve on top. Maybe it was overfilled?
'85 Camry DLX 162K
'87 Cressida 78K
'04 Camry XLE V6 119K
'98 Camry LE AE V6 228K
'06 IS250 + sport pkg 153K
'04 Camry SE I4 5SPD 199K
Kingdom934 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
