help 2001 camry a/c not working mgclt pin 2 no ground - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 2 Old 06-15-2019, 12:26 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
USA help 2001 camry a/c not working mgclt pin 2 no ground
i have a 2001 camry i changed mg clt relay and the a/c light still blinks i know if i put a wire on pin 2 fuse box mgclt relay too negtive battery a/c kick in and it works i change the ecm the relay and the a/c button inside the car and what does a a/c ampflyer do i will add pics later
Ricky Espino is offline
post #2 of 2 Old 06-17-2019, 07:02 PM
'00 4 Cyl. Auto Camry LE
Quoted: 190 Post(s)
Hi Ricky,
The A/C Amplifier circuit is Toyota's implementation of an intelligent "A/C cut relay" controller. It accepts inputs from various sensors, compares values vs. expected parameters, and commands the A/C compressor clutch to engage / or disengage accordingly.
By (bypassing) the A/C Amplifier at the "last mile" @ the Magnetic Clutch Relay, you have verified the Magnetic Clutch engages on the A/C compressor (which is a good test, BTW), but have not diagnosed "why" the A/C Amplifier is not commanding proper A/C operation -> at the Magnetic Clutch Relay.
Common basic checks include serpentine belt tension, wiring @ the A/C compressor and Pressure switch, High / Low refrigerant pressure values in the system. Following are some links to TN posts that may be useful to you & help in diagnosing the issue:
https://www.toyotanation.com/forum/1...lickers-c.html
https://www.toyotanation.com/forum/1...r-problem.html
https://www.toyotanation.com/forum/1...ml#post3580175
* In addition to above - having the correct Field Service Manual (FSM) for your year/model vehicle is almost a "requirement" when diagnosing A/C issues, hope this helps.
CamryFL is online now
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
