2000 solara v6 wont start - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 16 Old 06-19-2019, 11:15 AM Thread Starter
Quoted: 3 Post(s)
(Thread Starter)
Ijust got a 2000 toyota solara with the 3mzfe in it when i got it the timing was off ive rest the timing and now it will staet and run for about 5 sec then dies and wont start back for a while it has spark and fuel.how can i tell if i have the timing right and not 180 off. Any help would be appreciated.
Azazel is offline
post #2 of 16 Old 06-19-2019, 11:31 AM
Senior TN Member
Quoted: 767 Post(s)
You'll have to set #1 cylinder to top dead center COMPRESSION (TDCC) then check the mechanical timing marks.
1995 Camry Wagon LE. 2.2 5S-FE, Auto, 250K
Stillrunning is offline
post #3 of 16 Old 06-19-2019, 11:57 AM Thread Starter
Quoted: 3 Post(s)
(Thread Starter)
Ok ive got it in time but it still wont start
Azazel is offline
post #4 of 16 Old 06-19-2019, 03:31 PM
Senior TN Member
Quoted: 767 Post(s)
After it stalls and won't start, spray starter fluid into intake and see if it fires. If so you don't have fuel - at least after 5 minutes.
If no fuel then could be plugged fuel filter or pump sock.
post #5 of 16 Old 06-19-2019, 05:18 PM Thread Starter
Quoted: 3 Post(s)
(Thread Starter)
Ove sprayed starting fuel in and it still doesnt start
Azazel is offline
post #6 of 16 Old 06-19-2019, 05:29 PM Thread Starter
Quoted: 3 Post(s)
(Thread Starter)
Ive
Azazel is offline
post #7 of 16 Old 06-19-2019, 05:45 PM
Toyota Collector
71Corolla's Avatar
Quoted: 2457 Post(s)
Does the security light go out when you put the key in the ignition?
2000 Lexus ES300 Millenium Edition
1990 Camry LE V6 Anniversary Edition 5-Speed
1990 Camry LE V6 WAGON
1987 Camry LE I4 5-Speed
71Corolla is online now
post #8 of 16 Old 06-20-2019, 05:42 AM
Senior TN Member
Quoted: 767 Post(s)
Did it at least fire a couple times?
How do you know it was getting spark?
post #9 of 16 Old 06-20-2019, 11:42 AM Thread Starter
Quoted: 3 Post(s)
(Thread Starter)
I checked for spark and it getting spark and fuel
Azazel is offline
post #10 of 16 Old 06-20-2019, 11:54 AM
Senior TN Member
Quoted: 767 Post(s)
What is needed for engine to run:
spark, fuel, compression, timing, air, no large vacuum leaks (too much air).
If engine has an EGR valve and the valve is not closing it will create a large vacuum leak that will cause the engine to stall.
post #11 of 16 Old 06-20-2019, 12:53 PM
Quoted: 18 Post(s)
This sounds really bad... how much was the timing off by? Can you check the compression? Wondering if the valves got damaged...
Backyard Mechanico Extraordinairre
2006 RAV4 4WD V6 Limited
2019 Corolla Hatch 2.0L XSE
igzy is offline
post #12 of 16 Old 06-20-2019, 08:24 PM Thread Starter
Quoted: 3 Post(s)
(Thread Starter)
It was off like 180 i will check the compression this weekend
Azazel is offline
post #13 of 16 Old 06-20-2019, 10:21 PM
Quoted: 126 Post(s)
Was this engine a replacement engine for this Solara? I ask because the first generation Solara (19982003) came with a 2.2L 5S-FE I4, 2.4L 2AZ-FE I4, or a 3.0L 1MZ-FE V6. The 3MZ-FE wasn't an option for the Solara until 2004.
The Stable:
'00 Camry (adult daughter's)
'03 Avalon (daily driver)
'04 Avalon (wife's)
'05 Solara (adult son's)
'01 Silverado
MacQ is offline
post #14 of 16 Old 06-21-2019, 06:34 AM Thread Starter
Quoted: 3 Post(s)
(Thread Starter)
Sorry i think it is the 1mzfe
Azazel is offline
post #15 of 16 Old 06-21-2019, 06:49 AM
Official PITA
Riick's Avatar
Quoted: 58 Post(s)
Someone asked if security light went out when key placed in ignition.
In many cars, if not correct electronic key, car will start, then die in a few seconds.
<<<<< Shrug >>>>>
Riick is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
