98' Camry still overheating after repairs - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
 2Likes
  • 1 Post By John Anthony
  • 1 Post By insightbrewery
post #1 of 7 Old 06-25-2019, 09:54 PM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
Hello fellow Camry enthusiasts, I was recently driving around and noticed my coolant was bubbling once I parked. I figured my coolant was getting old so I flushed it which made the issue much worse to the point it's actually overheating. That's when I replaced the thermostat temp sensor and the thermostat just in case, but that didn't work. The hot coolant wasn't leaving the block (lower radiator hose never gets hot) so Ive spent the last couple of days swapping out the water pump, but it's still overheating. I'm not even able to bleed the air out.. I'm convinced it's not a head gasket since there's no smoke coming from the exhaust and the oil is fine. Im completely stumped, any ideas?
Isaac Odom is offline
post #2 of 7 Old 06-25-2019, 10:13 PM
Wanna Fix It!
John Anthony's Avatar
Quoted: 682 Post(s)
What exact thermostat did you use? I recommend OEM thermostats only. I had a brand new aftermarket "Murray/Motorad" thermostat that was bad right out of the box. Caused me a lot of grief until I decided to suspect it and replaced it with an OE thermostat which resolved the problem.
Lift up the front of the car to help bleed out the air bubbles. I would still test for head gasket issues if you still have problems after confirming bleeding air bubbles out and verifying the thermostat quality. You can "rent" a chemical tester for free from some auto parts stores. You have to buy the chemical though.
97trophy likes this.
2004 Corolla LE 375K+ miles.
1987 Toyota Pickup base, 4spd 162K+ miles.
1996 Toyota Camry LE I4 (son's car) 230K+ kilometers.
2010 Toyota Camry LE I4 (mother's car). 162K+ miles.
"There's always free cheese in a mousetrap."
John Anthony is offline
post #3 of 7 Old 06-25-2019, 10:50 PM
short-throw dipstick
Quoted: 1808 Post(s)
+1 chemical block tester to check for blown head gasket. I'd also pull your new tstat and test it to see if it opens. If not, replace with OE Kuzeh or Tama (easiest way to get is to order an Aisin from NAPA or RockAuto, it's a reboxed Tama).
These cars are insanely easy to - and well-designed to - bleed. A spill-free funnel makes that even easier, but the bottom line is air in the system isn't really an issue unless you have an issue with the tstat, water pump, clog in system, or BHG.
John Anthony likes this.
00 Camry 5S-FE 184k smoooth
01 ES300 147k NEEDS TRANS WORK
01 Insight 137k BROKEN CAMSHAFT
02 Insight 178k DC-DC BELLY-UP
08 STS-V 67k 570 RWHP!
01 Viggen 112k 400 FWHP
insightbrewery is offline
post #4 of 7 Old 06-25-2019, 11:06 PM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
The tstat I used was a Murray, it is
labeled OE however..
post #5 of 7 Old 06-25-2019, 11:10 PM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
Everytime I turn it on to bleed the air, it'll start bubbling alittle but the air doesnt seem to come out until I actually turn. (It bubbles but the coolant doesn't go down till it's off)
post #6 of 7 Old 06-26-2019, 09:10 AM
Wanna Fix It!
Quoted: 682 Post(s)
Murray stinks and it is NOT an OE thermostat.
^^ One of the best posts I've read in a while.
post #7 of 7 Old 06-26-2019, 09:50 AM
Senior TN Member
Quoted: 766 Post(s)
Did the fans start when this happened?
That's when I replaced the thermostat temp sensor...
Do you mean the fan switch in the bottom of the rad?
To test flow remove the t-stat, gut the internals (use the Murray for that). Then replace the stat housing and fill the system with coolant then start the engine. Remove the rad cap (cold engine) and observe the flow of coolant. If it's not flowing then maybe you have a plugged rad.
1995 Camry Wagon LE. 2.2 5S-FE, Auto, 250K
Stillrunning is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
