EGR where are the most common leaks? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
 1Likes
  • 1 Post By JohnGD
post #1 of 6 Old 07-11-2019, 06:40 PM Thread Starter
Quoted: 4 Post(s)
(Thread Starter)
I have an exhaust leak in the EGR system. No leak in the upper tube coming into the EGR itself. There are two steel tubes. One feeds into the EGR and an aluminum fixture on the block. The other is a flexible tube that comes out of the aluminum fixture and goes into the exhaust manifold. Just curious which tubes/fixture are most likely to leak? What is that aluminum fixture mounted on the block that the tubes feed into? Thanks in advance for all the advice/suggestions.
john is offline
post #2 of 6 Old 07-11-2019, 07:00 PM Thread Starter
Quoted: 4 Post(s)
(Thread Starter)
Oops. 1996 Camry V6
john is offline
post #3 of 6 Old 07-11-2019, 08:13 PM
Wanna Fix It!
John Anthony's Avatar
Quoted: 684 Post(s)
I'm very familiar with the I4, but not the V6 system which is a bit different. It has a coolant passage that runs through it to open/close a valve instead of a vacuum switching valve that the I4 has. Anyway, the aluminum fixture you're referencing is the intake manifold (unless I'm misunderstanding you).
How do you know there is a leak? Are you getting a check engine light code? If yes, which specific code is it? P0401 is a common one (at least for the I4).
2004 Corolla LE 375K+ miles.
1987 Toyota Pickup base, 4spd 162K+ miles.
1996 Toyota Camry LE I4 (son's car) 230K+ kilometers.
2010 Toyota Camry LE I4 (mother's car). 162K+ miles.
"There's always free cheese in a mousetrap."
John Anthony is online now
post #4 of 6 Old 07-11-2019, 08:29 PM
イリジウム
Quoted: 1033 Post(s)
That aluminum thing on the block sounds like the EGR gas cooler.
When you say leak do you mean into the intake when not commanded or out into the air?
John Anthony likes this.
JohnGD is offline
post #5 of 6 Old 07-12-2019, 06:21 PM Thread Starter
Quoted: 4 Post(s)
(Thread Starter)
Failed inspection for very slight exhaust leak. Checked the exhaust from the manifold to the muffler. No leaks. It sounds as though it is coming from the engine compartment. This weekend I will get an inspection mirror on the 2 tubes and the gas cooler.
john is offline
post #6 of 6 Old 07-12-2019, 08:22 PM
イリジウム
See also:
JohnGD is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
