REALLY bad mileage 2000 Camry LE V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 6 Old 03-31-2012, 05:16 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Unhappy REALLY bad mileage 2000 Camry LE V6
OK, so it's a V6.. 98K miles, purchased at 95K, timing belt at
60K so that's OK, but the mileage is A-TROCIOUS.
Can you say "15 MPG? WTF?!"
Plugs OK, had injectors cleaned, not much improvement.
? Trans problem ? ie slippage?
? Computer problem ?
How can I (or a mechanic) diagnose what's happening, there's
no codes apparent. Did replace front O2 sensor, no help there, either.
I am bummed!
Am in Chicago, North side. Anyone know a GOOD mechanic there?
thanks, guys.
Zeng is offline
post #2 of 6 Old 03-31-2012, 07:16 PM
T100 Road Warrior...
BamZipPow's Avatar
Quoted: 887 Post(s)
Are you doing a lot of stop and go traffic?
Are you carrying any extra weight in the car/trunk?
How quickly are you coming off the line when the light turns green?
What make/model of plugs do you have in there? What about the the wire set? How old are they? What brand are those?
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, dual oil catch jars, AC mod, aero cap, lower aero package, 67% grill block, aero single wheel trailer
BamZipPow is offline
post #3 of 6 Old 03-31-2012, 10:37 PM
Quoted: 0 Post(s)
it could be the gas your buying, the shitier gas the shitier the mileage thats what was the problem with my 1994 camry se v6 coupe
willV6 is offline
post #4 of 6 Old 04-01-2012, 01:56 PM
イリジウム
Quoted: 1007 Post(s)
Besides the engine it could be brakes or the transmission. It may help to get an eBay OBD-II reader for a laptop. It's about $15 shipped and use freeware to check engine performance.
https://www.toyotanation.com/forum/10...ml#post3581392
JohnGD is offline
post #5 of 6 Old 04-01-2012, 02:24 PM
BMR
Sheriff of Mayberry
BMR's Avatar
Quoted: 1851 Post(s)
Originally Posted by Zeng View Post
there's no codes apparent.
Are you sure the check engine light bulb is working?... Does it light up when the key is first turned to the "ON" position?
2015 RAV4 Limited, AWD, tech pkg, Barcelona red metallic, 63k miles
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 398k
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, totaled at 384k miles
BMR is offline
post #6 of 6 Old 04-01-2012, 11:22 PM
Quoted: 0 Post(s)
try running fuel injector cleaner through it the next time you fill up
willV6 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
Tags
mileage , slipping , trans
User Tag List
Linear Mode Linear Mode
