2000 V6 Interference engine or not? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
 1Likes
  • 1 Post By Cyorke
post #1 of 11 Old 05-29-2005, 07:21 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
4th Generation 2000 V6 Interference engine or not?
My understanding was that the v6 in a 2000 Camry is a non-interference engine. But I see in Gates' timing belt replacement manual they indicate it is an interference engine.
Who knows for absolute sure if it is or not?
1996 Turbocharged Camry 5S-FE (4 cyl)
http://www.meisners.net/camry
Meisner is offline
post #2 of 11 Old 05-29-2005, 08:38 AM
96 3MZ M/T
chronoti's Avatar
Quoted: 0 Post(s)
your engine is non-interference
^ and leaving it that way!
chronoti is offline
post #3 of 11 Old 05-29-2005, 08:40 AM
The Other White Meat
terrastrife's Avatar
Quoted: 0 Post(s)
retyt sure its not, but thres a chance i read somewhere that hte newest 1mz's were inteference -- not too sure... does it really matter? ya don tplan on getting the timing wrong do you?
terrastrife is offline
post #4 of 11 Old 05-29-2005, 12:15 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
No, don't plan on screwing up the t-belt install. It's my wife's car and she just passed 60K miles and she's all over me about replacing the belt. I keep telling her Toyota says 90K miles on these engines. I just don't want to be wrong about the belt lasting AND valves land up getting bent! Then she'll be able to tell me I told you so!
Meisner is offline
post #5 of 11 Old 05-29-2005, 07:56 PM
Senior TN Member
bronzemaxell's Avatar
Quoted: 23 Post(s)
i think v6 1mz-fe is 90k interval for timing belt
and i4 5s-fe is 60k internval, no damage to engine if timing belt broke
but i am not sure if the broken belt will mess up the pulley and other mechanic parts along the way.
bronzemaxell is offline
post #6 of 11 Old 05-31-2005, 10:24 AM
Moving Forward
Quoted: 0 Post(s)
Typically if the belt breaks you are not going to have any major damage done to anything. Now that is not to say that when you go to replace it you wont have other things that need replacing. You may still ahve to replace seals and waterpump and pulleys jsut due to age and normal wear. I have never seen a d Toyota engine with a timing belt do damage to the valve train when the belt broke. I was a mechanic for about ten years and specifically a Tyota mechanic for about 3 1/2 of those and never saw one damaged. Now as we all know anything is possible but I think you would have to be turning some really high RPM's to do any major damage if the belt were to break.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline
post #7 of 11 Old 05-31-2005, 10:58 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
^^ That is exactly what I was thinking. Of course things do wear out...and if I'm the T-belt due to age, I will change the water pump as well.
As I mentioned earlier, I just don't want any serious damage if the belt lets go. It will be enough of a pain to get everything retimed.
Meisner is offline
post #8 of 11 Old 05-31-2005, 01:54 PM
Moving Forward
Quoted: 0 Post(s)
Actually timing any of the toyota engines is prety easy. They give you all the marks that you need jsut line the marks up and put it together you are ready to go.There are marks on the head and the cam gear you line up then marks on the crank gear and the oil pump housing to line up and you are ready to go.
N2 Toyota likes this.
Chris
Cyorke is offline
The Following User Says Thank You to Cyorke For This Useful Post:
N2 Toyota (12-11-2018)
post #9 of 11 Old 06-20-2019, 04:29 AM
Quoted: 8 Post(s)
I can tell you the answer to this question for absolutely sure. Here it is.
merryfrankster2 is offline
post #10 of 11 Old 06-20-2019, 02:40 PM
Senior TN Member
Quoted: 230 Post(s)
https://www.youtube.com/watch?v=0o-TXIWVHwg
Looks like they pulled that engine out of a lake!
chuckoff is offline
post #11 of 11 Old 06-25-2019, 01:08 AM
Senior TN Member
Quoted: 301 Post(s)
I bet the valves cleared by like 2 thousandths and at REAL rotational speed.....KA-BLEWEE!
tedmich is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
