Rear Strut Torque Question - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 11 Old 06-23-2014, 01:02 PM Thread Starter
Newbie
Quoted: 0 Post(s)
(Thread Starter)
Hello all,
Over a year ago, a local shop told me I needed the rear struts replaced to pass inspection. It sounds like they replaced only the struts, not the springs or any of the hardware. Before I took it in, the car was making a "clunk" noise when going over bumps in the back. I'd gotten used to it, however, after the strut replacement, I expected this to be fixed. It wasn't.
I'd read on this forum that clunking can result if the large bolt on top of the strut (the one visible inside the car) is not tightened properly. The Hayne's manual lists this as 188ft-lb, which is a lot. Guess what--when checking it today, I had to twist to get either of them to 50.
Now I have a few questions on this:
1. When attempting to get one to about 100, the bolt began and the rubber thing that is also visible around the bolt began to turn. Did I make a mistake in attempting to tighten this from within the car? Is there something that needs to be held with a wrench underneath this bolt in order to get the desired torque?
2. The Hayne's manual also lists the three nuts surrounding this large bolt ("strut to body nuts") as 83ft-lbs. This seems really excessive for the size of the bolts. Can anyone confirm this? I didn't want to strip one so I didn't tighten it this much.
3. This is over a year later, so I don't know that I can expect anything from the shop. However, what are my options? I don't possess the know-how or tools to do a tear down of the rear suspension, and don't want to pay for another alignment.
Thanks very much guys!
1994 Camry LE 5SFE
160,000 miles[12/2/08]
94cylcamry is offline
post #2 of 11 Old 06-23-2014, 03:04 PM
Dave in KCMO
OraDBAforPsoft's Avatar
Quoted: 15 Post(s)
Originally Posted by 94cylcamry View Post
Hello all,
I may be interpreting the Haynes manual differently to you. Page 10-1:
Rear Suspension:
Strut upper mounting bolts = 29 Ft-lbs. I think these are the 3 bolts you refer to.
Strut to suspension support (Damper shaft nut) = 36 Ft-lbs. I think this is the one bolt in the middle at the top, that you refer to.
on page 10-1 the only high torque value is for the strut to AXLE carrier nut/bolts at 188 Ft/Lbs.
on page 10-2 the only high torque values are for the suspension arms at 134 ft-lbs.
I am open to correction.
Dave in KCMO
2003 Camry I-4 Auto (2nd Toyota, gift Sept 2015)
Triumph Motorcycles
OraDBAforPsoft is offline
post #3 of 11 Old 06-23-2014, 09:41 PM Thread Starter
Newbie
Quoted: 0 Post(s)
(Thread Starter)
You are absolutely correct. I'm not sure what I was looking at earlier, but it's plain as day to me now. Got everything at the correct torque, glad I didn't damage anything.
Thanks for taking the time to look that up.
1994 Camry LE 5SFE
post #4 of 11 Old 04-16-2019, 02:31 AM
Quoted: 28 Post(s)
Originally Posted by OraDBAforPsoft View Post
I
this Bolts can be tight without need to remove the struts from the car!
Good Wishes is offline
post #5 of 11 Old 04-16-2019, 06:28 AM
Quoted: 42 Post(s)
in answer to the first question:
"1. When attempting to get one to about 100, the bolt began and the rubber thing that is also visible around the bolt began to turn. Did I make a mistake in attempting to tighten this from within the car? Is there something that needs to be held with a wrench underneath this bolt in order to get the desired torque?"
The end of the stud should have a hex recess into which you can put a hex wrench to hold the stud while you tighten the nut with a box end wrench.
norm356 is online now
post #6 of 11 Old 04-16-2019, 06:47 AM
Quoted: 28 Post(s)
then have to remove it from the car!
https://www.youtube.com/watch?time_c...&v=NGyCE9Gqm4o
post #7 of 11 Old 04-16-2019, 06:49 AM
Quoted: 42 Post(s)
no need to remove, it is accessible from inside, when the rear package tray trim is removed
post #8 of 11 Old 04-17-2019, 06:34 AM
Quoted: 28 Post(s)
Is this do the job !
Schwaben 003046SCH01A-02 Strut Nut Socket (19Mm) https://www.amazon.com/dp/B01DFMVDUU..._S4WTCb05B3GR6
post #9 of 11 Old 04-17-2019, 11:10 AM
Quoted: 42 Post(s)
very neat tool! Allows allen wrench to be held in the end of the stud while using a torque wrench on the nut.
post #10 of 11 Old 04-17-2019, 04:11 PM
Quoted: 28 Post(s)
Is the 2000 v6 camry used 19 mm or 20 .mm
post #11 of 11 Old Yesterday, 10:50 PM
Quoted: 28 Post(s)
This is what in my rear strut 21mm nut ! That what comes with KYB strurts.
File Type: jpg Screenshot_20190420-205240_Gallery_1555818779252.jpg (693.7 KB, 5 views)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
