TPMS sensor won't reset - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2004-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 9 Old 07-08-2015, 03:28 PM Thread Starter
bootcamper's Avatar
Quoted: 9 Post(s)
(Thread Starter)
Gen6 TPMS sensor won't reset
hi TN,
My friend bought two new tires for her car, and had all the wheels rotated. When she went to the toyota, they said they need $100 bucks, just to reset my TPMS sensor.. which is something so simple. There are few videos on YouTube that details how to reset the TPMS sensor...
So I followed all the steps. I bought a tire pressure sensor (*a nice digital one), I put air in the tires (30 on all 4), i put the car ignition on ON, put the parking brakes on, and pressed the TPMS switch, saw the three blinks,.. and I thought it would stop coming after that... But Nope. It started right back on and started blinking.
Now I am not sure what to do?
Has this happened to anyone here before. Her car is a 2007 Camry.
Thanks!
~bootcamp
Camry 99, V6 LE Black (previous)
2017 Tacoma DCLB TRD Sport 4x4 (current)
bootcamper is offline
post #2 of 9 Old 07-08-2015, 03:43 PM
TN User
DemonicZia's Avatar
Quoted: 6 Post(s)
try putting a little more air in. if that doesn't work possible battery or bad sensor.
DemonicZia is offline
post #3 of 9 Old 07-08-2015, 05:03 PM
Toyota Fanatic
hardtopte72's Avatar
Quoted: 2089 Post(s)
It's possible whoever changed the tires damaged the sensor.
My Toyota List:
1982 Corolla SR-5 (Shell Right Now)
2005 Corolla CE 1ZZFE M/T
2005 Sequoia Limited 2UZFE A/T
2008 LS460 SWB RWD 1URFSE A/T
If I helped out in any way please hit the Thanks button under my post.
hardtopte72 is offline
post #4 of 9 Old 07-08-2015, 06:09 PM
Senior TN Member
2011SEV6's Avatar
Quoted: 182 Post(s)
Gen6
Originally Posted by bootcamper View Post
hi TN,
I recently changed the front two tires of my gf 's car, and had all the wheels rotated. There are few videos on YouTube that details how to reset the TPMS sensor...
When I went to the toyota, they said they need $100 bucks, just to reset my TPMS sensor.. which is something so simple. But now I am not sure what to do?
Thanks!
~bootcamp
After you picked up the car, did it start to blink? If its flashing on a toyota usually means its a bad sensor.
2011SEV6 is offline
The Following User Says Thank You to 2011SEV6 For This Useful Post:
bootcamper (07-09-2015)
post #5 of 9 Old 07-08-2015, 07:15 PM
Senior TN Member
Quoted: 378 Post(s)
Could be one of those cars that has a sensor in the spare tire if it's a full size spare. Check the spare tire.
1986 Toyota Pickup Xtra Cab 4WD SR5 22RE
2002 Toyota Corolla LE
Justice619 is offline
post #6 of 9 Old 07-09-2015, 06:49 PM Thread Starter
bootcamper's Avatar
Quoted: 9 Post(s)
(Thread Starter)
Is it possible to change the sensor ourselves? or does it require going to the shop? I have the tire iron etc to remove the wheel, not sure which sensor is broken,. How do I find that? Is there a DIY here on how to change the sensor?
post #7 of 9 Old 07-09-2015, 07:17 PM
Senior TN Member
Quoted: 378 Post(s)
The sensor is inside the wheel itself. So, no. you would be able to change it out on your own. You need to dismount and mount the tire from the rim to change the sensor.
You need a $1200 scan tool to transmit and receive signals from each sensor to find out which one is bad.
Have you check the spare tire yet?
post #8 of 9 Old 07-10-2015, 01:01 PM
Quoted: 126 Post(s)
If it started immediately when your friend picked the car up after the 2 tires were replaced, take it back to the shop that replaced the tires. They probably did break one of the sensors on the wheels they were working on. Let them deal with the problem.
Mike
Mike Gerber is offline
post #9 of 9 Old 07-10-2015, 03:26 PM
Toyota Fanatic
The only Toyota vehicles with spare tire sensors are the SUVs/Trucks and the Avalon.
My Toyota List:
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008)
Tags
tpms
User Tag List
Linear Mode Linear Mode
