2002 Camry Flex Pipe install look correctly done? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2004-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
 1Likes
  • 1 Post By Vangm25
post #1 of 13 Old 05-22-2019, 08:17 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
does this look like it was installed correctly? I took the car to a second muffler shop and they told me the previous shop did it incorrectly and should have put in more pipe at the ends. They said it will probably come off after 6 months.
firstofficer is offline
post #2 of 13 Old 05-22-2019, 08:18 PM
2010 Camry SE V6
BlackCamSe's Avatar
Quoted: 62 Post(s)
Those are some shitty welds
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now
post #3 of 13 Old 05-22-2019, 08:39 PM
Senior TN Member
Quoted: 226 Post(s)
Who the hell did that? What, did they pay you to let them do it? Dude, that is horrible work. It looks like they just crammed the one end into part of the old flex pipe braid pr. something. It is hard to tell. So, NO it does not look correctly done at all! Never go with the low bid. It should have been cut off further out (see yellow lines). Go find a shop that has a clue and get it done correctly.
You asked.
chuckoff is offline
post #4 of 13 Old 05-22-2019, 08:59 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
The shop asked for $175 for this. I ended up paying $120. The muffler shop has been in business for decades so im surprised everyone is stating this was done wrong. Will this come apart much sooner than later?
post #5 of 13 Old 05-22-2019, 10:45 PM
Senior TN Member
Vangm25's Avatar
Quoted: 681 Post(s)
As long as you don't hear any other noises, the flex pipe "is installed correctly". The weld can be a lot better and the pipe itself could be a straighter BUT if it holds it will hold. How long will it hold, I can't say. When it goes bad, you will hear it. Personally while I hate the way it looks, I'd live with it until the time comes for me to take it to a DIFFERENT shop. It's the same job either way. Cut, clean, replace, weld. It's your choice in the end.
somick likes this.
Vangm25 is online now
post #6 of 13 Old 05-22-2019, 10:49 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
VANGM
Do you think i should go back there and show them these photos? The job was done last week. Will they most likely redo it with a new flex pipe? I don't mind showing them my proof but just don't want anyone to poke at any other car components out of ego revenge or anything of that sort.
post #7 of 13 Old 05-23-2019, 12:50 AM
Senior TN Member
Vangm25's Avatar
Quoted: 681 Post(s)
It's your choice. If they can do it for free, do it. If you have to pay, live with it til it goes bad. I'd personally would just wait with till it goes bad. My old shop I used to work at does plenty of welding work so I am guaranteed to go there (along with no labor tire installs).
post #8 of 13 Old 05-24-2019, 09:52 AM
Quoted: 34 Post(s)
Canada
Hi
Last summer 2018, I replace an flex pipe on a 05 Camry V6 at an muffler shop. The shop show me two type of flex pipe the economy one with single braided and last 2-3 years max and a heavy duty one with double braided mesh and interlocking inside. Both are made in china but the heavy duty look more robust and the welder told me it could last more than 5 years. Price was $120 CDN tax in for economy flex pipe and $140 for the heavy duty and I opted for the heavy duty one. Here's a sample pic of the heavy duty flex pipe and i suggest you to re-do it, it was a very bad job. Usually when they weld you could stand beside your car and watch the welder do and supervise the job and if anything your not ok just tell him and they will correct it.
Edit: 1st pic is normal flex pipe and inside is mesh type braided.
Pic #2 is heavy duty one.
File Type: jpg 54005-Stainless-Steel-Double-Braided-Flex-Pipe-Extender-Adaptor-Piping-1.jpg (16.0 KB, 23 views)
mcgill_redmen is offline
post #9 of 13 Old 05-25-2019, 09:07 AM
Senior TN Member
Quoted: 226 Post(s)
Originally Posted by mcgill_redmen View Post
Hi
They let you watch? The let you watch WELDING? Really? Can you still see? Did they charge you double??
chuckoff is offline
post #10 of 13 Old 05-25-2019, 09:21 AM
Quoted: 45 Post(s)
Brutal work. Flex portion looks short as well, but I could be wrong. If it's too short you'll experience severe vibration at idle with ac on. Shop probably won't swallow that, so, lesson learned; don't use that shop.
Cheers
2009Camry1 is offline
post #11 of 13 Old 05-25-2019, 09:43 AM
Quoted: 34 Post(s)
@chuckoff
The shop i went in Montreal is called Kiko Muffler. Is located at an area that plenty of repair, body shop and exhaust repair and modification. I'll inclued a link of their website so you could have an general idea / examples how it look. Their garage is clean and have 12 bay lift. On weekend is super busy and at least 1h of waiting and on weekday is less busy. They have a lots of chair place beside front of your car so you sit and wait while they fix and your able to check the welder's job free of charge. That muffler shop, the owner and welder speak mostly spanish and not much english and Ok french and i assume they from Latino America.
http://www.kikomuffler.ca/
post #12 of 13 Old 05-25-2019, 10:17 PM
DIY Dad: if it has things, I'll tinker with it
SFCamry's Avatar
Quoted: 1107 Post(s)
Welcome to the site firstofficer.
The weld job looks awful, looks like inclusions and slag in the weld; you should consider a leak test. If you have a shop vac that will reverse direction, or a leaf blower, you can jam it into the tail pipe (engine off) and make a tight seal, then blow into the exhaust system. Take a bottle of soapy water and spray along the weld areas, drenching it good. If bubbles appear then it is a bad, bad job. If you click my CAMRY MOD link you will see where I did this test to identify where I had some loose connections from my header to my front pipe.
Camry Mod
THIS
'15 4Runner SR5 (1GR-FE)
'09 Camry SE 2.4L (2AZ-FE)
'97 Tacoma XL 4x4 Ext Cab 2.7L (3RZ-FE) - Manual
'97 Ford Explorer XLT V6 SOHC 4.0L 4x4
SFCamry is offline
post #13 of 13 Old 05-27-2019, 04:55 PM
Quoted: 6 Post(s)
Looks tacky, and you can see pinholes where the weld hasn't completely sealed the joined parts; I'm surprised you're not hearing a repetitive hissing noise. Also, they do have a bolt-on replacement pipe; I would have splurged for that instead of a cut-and-weld pipe.
Mannyjb90 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008)
Tags
exhaust , flex pipe , muffler
User Tag List
Linear Mode Linear Mode
