2002 to 2009 TOYOTA CAMRY 2.4L 2AZ-FE 4-CYLINDER - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2004-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 4 Old 06-12-2019, 09:46 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
About 3 months ago I bought this engine on Ebay.
My engine was shipped to the USA from Japan with low mileage.
Only problem is the Knox sensor has different wire connectors in the Japanese built model.
My car was built in the USA. The check engine light came on and the scan says there is a Knox sensor issue.
The knox sensors of the two cars apparently have different wire connectors. Anyone know what must be done to clear the error codes for good? Please help.
Shane Woodruff is offline
post #2 of 4 Old 06-13-2019, 11:16 AM
Senior TN Member
Vangm25's Avatar
Quoted: 673 Post(s)
Compare and contrast the different connectors.
Vangm25 is offline
post #3 of 4 Old 06-13-2019, 07:25 PM
Quoted: 37 Post(s)
I would think that when installing a rebuilt/used engine and using the existing ECM (you are, aren't you?), you would install the sensors (like the knock sensor) and actuators (like the coils & injectors) consistent with the ECM (i.e. from the original engine). So I would try and install the knock sensor from your original engine (or that replacement part) and it should plug right into your existing engine wiring harness. I think that's the way it should work....maybe others can comment.
Buckaroo
2000 T4R SR5 V6 4WD
2002 Camry XLE 4 cyl
2004 Accord EX 4 cyl
2010 Mazda MX-5 Touring
2017 Camry XLE 4cyl
2017 Tundra Limited DC 3.5L 4WD
Buckaroo5 is offline
post #4 of 4 Old 06-13-2019, 09:20 PM
DIY Dad: if it has things, I'll tinker with it
SFCamry's Avatar
Quoted: 1104 Post(s)
Agree with Buckaroo. I am surprised they set you an engine with sensors attached.
Camry Mod
THIS
'15 4Runner SR5 (1GR-FE)
'09 Camry SE 2.4L (2AZ-FE)
'97 Tacoma XL 4x4 Ext Cab 2.7L (3RZ-FE) - Manual
'97 Ford Explorer XLT V6 SOHC 4.0L 4x4
SFCamry is online now
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008)
User Tag List
Linear Mode Linear Mode
