2005 Toyota Solara front strut/ball joint torque specs. - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2004-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 3 Old 06-17-2019, 08:49 AM Thread Starter
Quoted: 4 Post(s)
(Thread Starter)
Hi, tried to you the search but could not find the info I need. Putting front struts and ball joints on my Solara and need the torque specs for the strut mount to strut, strut mount to body, lower strut bolts to steering knuckle, ball joint nut to steering knuckle and the 3 ball joint bolts to control arm. Thanks for looking
499/506 is offline
post #2 of 3 Old 06-17-2019, 11:38 AM
Senior TN Member
Quoted: 253 Post(s)
From Toyota "Repair Manual" 2004 Camry, I think your 05 Solara should be the same. Front suspension support to strut nut=36 ft lbs. Strut mount to body=59 ft lbs. Strut to steering knuckle=155 ft lbs. Ball joint to steering knuckle=36 ft lbs. Ball joint to control arm=55 ft lbs. Stabilizer to strut=55 ft lbs. Hope this helps. Far as I know Solara is same platform as Camry.Another member may have 05 Solara shop manual. Regards
Donald E George is offline
post #3 of 3 Old 06-17-2019, 12:21 PM Thread Starter
Quoted: 4 Post(s)
(Thread Starter)
Thanks so much Don
499/506 is offline
The Following User Says Thank You to 499/506 For This Useful Post:
Donald E George (06-19-2019)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008)
User Tag List
Linear Mode Linear Mode
