2011 Toyota Camry Evaporator Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2004-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 12 Old 06-22-2019, 09:13 PM Thread Starter
Jason
Quoted: 0 Post(s)
(Thread Starter)
I did the UV dye test on my AC system and I can't find the leak in the engine compartment implying it is the evaporator. The evaporator is buried in the dash.
I have a 5-year subscription to AllDatadiy.com for my 2011 Camry because I could not find where to purchase a Factory Service Manual. AllDatadiy.com does not have the disassembly procedure to get the evaporator. What Alldatadiy.com has is pictured below in the screenshots. I went to the Toyota dealer and they just told me that the FSM cannot be purchased. E-bay has nothing. I need to get a manual to do this repair. What do I do?
JAwffANftQ is offline
post #2 of 12 Old 06-22-2019, 09:49 PM
2010 Camry SE V6
BlackCamSe's Avatar
Quoted: 70 Post(s)
I’d look for a little more concrete evidence before tearing into that. I did an evaporator on a Hyundai Accent at work, only after finding the dye coming out of the ac evaporator drain. It was very obvious with the UV light and yellow glasses on. Check both of your schrader valves and make sure they’re tight. Check all your ac lines where the metal lines meet rubber (at the crimps) you’ll see more of an oily residue with dirt stuck to it. And check the condenser out in front of the car for some obvious impact damage.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline
The Following User Says Thank You to BlackCamSe For This Useful Post:
JAwffANftQ (06-24-2019)
post #3 of 12 Old 06-22-2019, 11:47 PM
Toyota Fanatic
hardtopte72's Avatar
Quoted: 2086 Post(s)
You can view and download the entire FSM for the car at techinfo.toyota.com. It's $15 for a 2 day subscription which is literally 48 hours to open, click print, and save as a pdf. I just downloaded over 3K pages of the manual for my LS460 (it's probably a 4-5K page manual), including around 95% of the wiring diagram.
My Toyota List:
1982 Corolla SR-5 (Shell Right Now)
2005 Corolla CE 1ZZFE M/T
2005 Sequoia Limited 2UZFE A/T
2008 LS460 SWB RWD 1URFSE A/T
If I helped out in any way please hit the Thanks button under my post.
hardtopte72 is offline
The Following User Says Thank You to hardtopte72 For This Useful Post:
post #4 of 12 Old 06-22-2019, 11:59 PM
Senior TN Member
Vangm25's Avatar
Quoted: 744 Post(s)
Last time I said this my post got deleted. Otherwise TIS will have everything needed to do just about anything on a early 80s Toyota and higher.
Vangm25 is offline
post #5 of 12 Old 06-23-2019, 12:09 AM
Toyota Fanatic
When was that? Posting an actual FSM or link to oneis against the rules, unless it's Toyota themselves (which TIS is).
My Toyota List:
post #6 of 12 Old 06-23-2019, 12:13 AM
Senior TN Member
Vangm25's Avatar
Quoted: 744 Post(s)
PM sent, don't wanna move the thread to something unrelated.
Vangm25 is offline
post #7 of 12 Old 06-24-2019, 08:41 AM Thread Starter
Jason
Quoted: 0 Post(s)
(Thread Starter)
You are right. I will gather a little more evidence before I replace the evaporator.
post #8 of 12 Old 06-24-2019, 08:42 AM Thread Starter
Jason
Quoted: 0 Post(s)
(Thread Starter)
Good idea. I will look into this. Thank you!
post #9 of 12 Old 06-24-2019, 12:32 PM
Mechanic by Necessity!
Quoted: 4 Post(s)
Do a real good inspection of the condenser. On my son's 2007, I did the dye test and I could just faintly see two 1" spots of "glow" on the condenser fins. There was no real obvious damage to it. Replaced condenser, pulled a vacuum on the system (no leaks), and refilled with the specified amount of refrigerant and its been great since (at least 3 years ago). Cheers!
2007 Camry LE, 2.4L, 160k miles
2008 Avalon LE, 3.5L, 240k miles
cprcubed is offline
post #10 of 12 Old 06-24-2019, 02:57 PM
イリジウム
Quoted: 1021 Post(s)
Is the evaporator drain tube undercard showing dye?
JohnGD is offline
post #11 of 12 Old 06-24-2019, 10:30 PM Thread Starter
Jason
Quoted: 0 Post(s)
(Thread Starter)
The reason I doubt the condenser is because a full charge is gone 1-2 days. The leak is really bad. I would expect to see the UV dye on the condenser but I haven't as of yet.
post #12 of 12 Old 06-24-2019, 10:31 PM Thread Starter
Jason
Quoted: 0 Post(s)
(Thread Starter)
I haven't had a chance to explore this yet. I plan to look into this soon.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008)
User Tag List
Linear Mode Linear Mode
