How do I change the "check battery" bulb 2008 Toyota Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2004-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
 1Likes
  • 1 Post By Onionsayswhat
post #1 of 6 Old 06-25-2019, 12:00 PM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
Is there a way to get at the bulb for the "check battery" light that shows up in the dashboard?
Onionsayswhat is offline
post #2 of 6 Old 06-30-2019, 01:36 AM
Toyota Fanatic
hardtopte72's Avatar
Quoted: 2089 Post(s)
What is the issue? Is the bulb stuck on or not turning on?
If it's stuck on, your alternator is likely not charging correctly.
My Toyota List:
1982 Corolla SR-5 (Shell Right Now)
2005 Corolla CE 1ZZFE M/T
2005 Sequoia Limited 2UZFE A/T
2008 LS460 SWB RWD 1URFSE A/T
If I helped out in any way please hit the Thanks button under my post.
hardtopte72 is online now
post #3 of 6 Old 06-30-2019, 04:09 AM
Senior TN Member
Pvt-Public's Avatar
Quoted: 234 Post(s)
I believe it is an LED not a bulb. That would require that you remove and disassemble the instrument cluster de-solder and re-solder the LED.
2013 Camry XLE 3.5L A/T
2017 Camry LE 2.5L A/T
Pvt-Public is offline
post #4 of 6 Old 07-02-2019, 08:33 PM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
The "check battery" light will not go out.
The alternator and battery are fine. The light has been on for half a year and the car always starts and the battery never goes dead.
I was using a implement that plugs into the cigarette lighter that allows a 2 prong plug to be plugged into it.
It blew out the cigarette lighter so that there was no longer any power from the cigarette lighter.
I checked all of the fuses inside the passenger compartment as well as inside the engine compartment - none were blown.
However, I found there is a fuse underneath the lighter that might need to be replaced.
However, after I wiggled the large square fuses inside the engine compartment - attempting to get them out to check - is when the CHECK BATTERY light came on.
I did not force those big square fuses but just gently tried to wiggle them out.
I gave up when the large square fuses would not come out and never did get the large square fuses out - but all of the other types of fuses were checked and are good fuses.
post #5 of 6 Old 07-12-2019, 08:33 AM
nationalyoda's Avatar
Quoted: 10 Post(s)
Put a piece of black electrical tape over the annoying light
nationalyoda is offline
post #6 of 6 Old 07-12-2019, 10:15 AM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
Brilliant! I'm sure the person I sell the car to won't notice that!
nationalyoda likes this.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008)
Tags
check battery bulb
User Tag List
Linear Mode Linear Mode
