Hybrid battery replacement - Page 12 - Toyota Nation Forum : Toyota Car and Truck Forums
 3Likes
post #166 of 198 Old 07-09-2017, 10:40 PM
Quoted: 1 Post(s)
Thanks for the help. do you have pin map for OBD port?
bojia88 is offline
post #167 of 198 Old 07-10-2017, 12:06 PM
Moderator
ukrkoz's Avatar
Quoted: 829 Post(s)
Here's data link connector map
Click image for larger version
ukrkoz is offline
post #168 of 198 Old 07-10-2017, 07:47 PM
Quoted: 1 Post(s)
no voltage can be measured between pin 4 and 16. Where is the next hop that I can check?
bojia88 is offline
post #169 of 198 Old 07-10-2017, 08:14 PM
Bitter's Avatar
Quoted: 2071 Post(s)
Bitter is online now
post #170 of 198 Old 07-11-2017, 10:04 PM
Quoted: 1 Post(s)
I wanted to check fuse #38 which is in the big blue case on the left. How do I get it out? tried to pull, but not moving.
bojia88 is offline
post #171 of 198 Old 07-12-2017, 01:34 PM
Moderator
ukrkoz's Avatar
Quoted: 829 Post(s)
I'd guess those are black plastic clips holding it in place, on each end.
I'd have been VERY careful from this point on, you start messing with expensive things to fix.
ukrkoz is offline
post #172 of 198 Old 07-12-2017, 03:40 PM
Quoted: 1 Post(s)
I'm having the same issue with my wifes 07 Camry Hybrid. Mine problem started while replacing the battery pack I grounded the black wire on top of the battery pack and tried to start the car. I'm told that black wire is actually the positive to the 12V battery. Now I just get a Check Hybrid Battery on the dash and no readout from the OBDII connector. I'm going to replace the blue Fusible Block on the left in your picture p/n 82620-07050. It comes out by removing the nut on the right of it and there's 2 tabs or tits on the blue fuse itself that lock it in place about 1 inch from each end (between the 2 blue fusible blocks) and one on the top looking at your picture which you can see with a flashlight. I used 3 really small flat blades and a pair of pliers. It takes a little more force than one would think but when it comes out prepare for the screwdrivers to go flying! Let me know if you make any progress and I'll let you know where replacing that fusible block takes me.
Thanks and good luck!
golfeus is offline
post #173 of 198 Old 07-12-2017, 05:31 PM
Quoted: 1 Post(s)
Thank you guys for the help. I was able to remove both blue fuse links and found both of them had a burn out. It was not easy job to pull them out because of tight space and 3 screws that I have to remove instead of 2, which holds down the 82620-33030. I ordered the replacement parts from amazon.
ID:	135706   Click image for larger version
snookwhaler likes this.
bojia88 is offline
post #174 of 198 Old 07-12-2017, 07:10 PM
Bitter's Avatar
I sure hope that fixes it for you!
bojia88 likes this.
The Following User Says Thank You to Bitter For This Useful Post:
bojia88 (07-12-2017)
post #175 of 198 Old 07-12-2017, 08:09 PM
Quoted: 1 Post(s)
golfeus: before you start removing the blue fuse link, there is a obd fuse under instrument panel you may want to check first.
bojia88 is offline
post #176 of 198 Old 07-13-2017, 08:17 AM
Quoted: 1 Post(s)
golfeus is offline
post #177 of 198 Old 07-13-2017, 08:18 AM
Quoted: 1 Post(s)
Where were the screws to get 82620-33030 out? I've got to take that out next myself.
Thanks!
golfeus is offline
post #178 of 198 Old 07-13-2017, 10:56 AM
Quoted: 1 Post(s)
Yep, I metered every fuse under the hood and dash, all good.
Thanks.
golfeus is offline
post #179 of 198 Old 07-13-2017, 11:17 AM
Quoted: 1 Post(s)
follow instructions from this link: http://sparkys-answers.com/2011/09/2...ulti-fuse.html
bojia88 is offline
post #180 of 198 Old 07-13-2017, 12:13 PM
Quoted: 1 Post(s)
Thanks!
golfeus is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Hybrid Forum > Camry Hybrid
User Tag List
Linear Mode Linear Mode
